CNK wrote:One more question .. Is the BCM 6R0 937 087 K is compatible with cruise control?
Yes. :wink:
CNK wrote: Could you tell me, if the wires are the same as here: https://drive.google.com/file/d/0B2nv91 ... 90WHc/view :?:
Greetings! ;)
I do not understand what you mean exactly.
What wires?
CNK
Drives: 6R
Post by CNK »
ciclo wrote: I do not understand what you mean exactly.
What wires?
I was thinking about CCS wiring to my 1.4 85 like yours to 1.2 TSI.
It's possible to 1.4 85KM: https://www.youtube.com/watch?v=UT2Jkb77uZ8 :)
It's the same wiring set?
The cruise control system of my R-line is from factory.
And yes, the wiring you need to install CCS on your 1.4 has to be in the same way as you see in the previous link (made by ciclo :wink: ).
1.4 85ps july 2011
ECU :arrow: http://www.uk-polos.net/viewtopic.php?f ... 45#p502036
CNK
Drives: 6R
Post by CNK »
ciclo wrote: 1.4 85ps july 2011
Thanks!
My car is from July 2011, but the tenth letter of VIN is C, so it's 2012 model. Can I check my ECU number in VCDS?
sendoc
Drives: polo match 1.4 (6R) & Toyota Avensis T3
Post by sendoc »
ciclo wrote:sendoc, normally 1.4 petrol (non BlueGT, non GTI) have a 80-pin ECU.
The cruise control pin in the ECU 1.4 is the T80 / 24.
engine code (CGGB) and model year B 1.4 6R.
Hi cilco
6RD 953 503 J - I saw this on aliexpress website.
Will this stalk fit my Polo ?
Hi cilco
Hi snedoc... :lol:.
Do not know, we need to know more information about your 6R.
Thanks!
All 6R which are manufactured in July is the following MY.
Yes, you can check the ECU with the VCDS.
CNK
Drives: 6R
Post by CNK »
ciclo wrote: All 6R which are manufactured in July is the following MY.
So probably it's my ECU number: 03C 906 024 CN
Address 01: Engine
   Protocol: KWP2000
   Part No: 03C 906 024 CN
   Component:       CGGB  MM4HV   8994
   Coding: 0000071
   Shop #: WSC 00788
I bought this stalks: https://www.dropbox.com/s/e9uq7sm179t7r ... 8.jpg?dl=0
6R0953521B + ring 6R0959654, according to your instructions ;)
I hope that this stalks will work properly.
But first I need to go to my friend to coding my new instrument cluster :D
(In Poland it is not possible to coding new instrument cluster in Volkswagen Dealership.. :| )
hmthakur
Drives: Polo gt tsi 1.2 dsg
Post by hmthakur »
Hi CNK,
From where did u order these stalks ?? Are they new or used?? I have to order them for my tsi
CNK
Drives: 6R
Post by CNK »
hmthakur wrote:Hi CNK,
Hey. They are used (from Polo GTI 2013). I bought them on online auction ( http://www.allegro.pl/show_item.php?item=5126319702) ;-)
CNK
Drives: 6R
Post by CNK »
Could you help me? I changed the instrument cluster and stalks, plugged cruise control and now I have error:
Error stabilisation control (ESC) when I press the gas pedał.. :-(
https://www.dropbox.com/s/d8xmj4r4tbs9y ... 5.jpg?dl=0
i think you need to re-calibrate the steering angle sensor
http://wiki.ross-tech.com/wiki/index.ph ... Bosch_5.7)
CNK
Drives: 6R
Post by CNK »
iichel wrote:i think you need to re-calibrate the steering angle sensor
Thanks, I tried this, but it didn't work...
my log from VCDS:
VCDS Version: Release 12.12.3 (x64)
Data version: 20140905
Friday,11,December,2015,00:29:44:30570
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
VIN: WVWZZZ6RZCY019098
37-Navigation -- Status: Malfunction 0010
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 CN    HW: 03C 906 024 BH
   Component:       CGGB  MM4HV G 8994
   Revision: --H09---    Serial number:
   Coding: 0000071
   Shop #: WSC 00788 648 00255
   VCID: 6CD1B4F24CFC9D7E575-5072
1 Fault Found:
18038 - Accelerator Position Sensor (G79)
            P1630 - 000 - Signal too Low - MIL ON
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 127
                    Mileage: 43261 km
                    Time Indication: 0
                    Date: 2064.00.00
                    Time: 00:00:00
                    Bin. Bits: 00000100
                    Load: 0.0 %
                    Lambda: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 78.0°C
                    Absolute Pres.: 1009.8 mbar
                    RPM: 0 /min
Readiness: 0010 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3216E00BB842524EB84D900401300
   VCID: 871B6B5E325ADE265A7-80D2
2 Faults Found:
18265 - Load Signal
            P1857 - 008 - Error Message from ECU
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 127
                    Mileage: 43357 km
                    Time Indication: 0
                    Date: 2000.14.00
                    Time: 00:24:10
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3310
                    Hex Value: 0x13B6
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
01314 - Engine Control Module
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 127
                    Mileage: 43357 km
                    Time Indication: 0
                    Date: 2000.14.00
                    Time: 00:24:10
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3367
                    Hex Value: 0x13B6
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045.clb
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326D6A8A6D580B8E5D9-8067
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0256
   Revision: BF046001    Serial number: 0434 158110732
   Coding: 3CB02BBF08F32400923808002C2B0CD100C0410F60040000200000000000
   Shop #: WSC 85046 004 02308
   VCID: 45872156CCD68C36E8B-8010
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 1K8 951 171 A    HW: K89 511 71A
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 08BC32
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00NXZLZ
   Coding: 003232
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9D126AEDC8634E059-801F
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB40570INGS61HS
   Crash sensor for side airbag; passenger side:
   Serial number: 3585HRB405R0ILP041NW
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515RRB404P0K4DOJGD6
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525RRB404P0K4DOM92Z
   Part No SW: 6R0 920 870 CX    HW: 6R0 920 870 CX
   Component: KOMBI         H05 0608
   Coding: 140A00
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 8D1759765C26B47660B-80D8
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0256
   Revision: BF046001
   Coding: 002200
   VCID: F0E9208223D4F99EEBD-80A5
   Component: IMMO          H05 0608
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADD32EA0D08034EA59-80BF
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7660186144
   Coding: 010000
   VCID: 295F8DE6408E4856EC3-807C
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Component: RNS-MID       H23 6276
   Revision: AB001001    Serial number: VWZ6Z7P2234584
   Coding: 00000400000000A20000
   VCID: 3D7749B6A406C4F6B0B-8068
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V12  8195
1 Fault Found:
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 27
                    Reset counter: 127
                    Mileage: 43256 km
                    Time Indication: 0
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6B63FEEA6A2666327-807A
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
1 Fault Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 27
                    Reset counter: 127
                    Mileage: 43256 km
                    Time Indication: 0
Address 77: Telephone (J412)       Labels: None
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105249241
   Coding: 020100010101010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: N/A
   VCID: 254781D624966C36C8B-8070
No ASAM data for: "EV_UHVPremi" (VW25)
End   ---------------------------------------------------------------------
I suppose that firstly was installed the instrument cluster and at this moment had no problem. :?:
What ring of steering column has installed, the original or the which was bought with the stalks?
Check the ECU connector, all the contact terminals must be firmly seated in its slot.
... also verifies that all cables for Cruise Control System (T41, BCM, ECU) are in the correct slot.
