Upgrading BCM (body control module) in my polo 6r
Re: Upgrading BCM (body control module) in my polo 6r
Your wiring looms for BCM Max adaptation and Automatic lights + CH / LH.
Corrections to the vento2013 installation guide for your 6R. With priority over the guide.
The rest of the guide is totally useful for you (except the part of the anti-dazzle mirror and RLS wiring, logicaly).
Vinayak185
Drives: 6R Polo GT 1.6 TDI
Post by Vinayak185 »
Thank you very much. You have prepared wiring very nicely. Can you please include the terminal remover tool? I don't have it. Electric bridge seems missing.
I don't have terminal removal tools, you can buy it here :arrow: https://www.ebay.co.uk/sch/i.html?_from ... ol&_sop=15
or buy it at a local store. I'm sorry I can't help you with this.
In the previous images of your wiring looms look in the hermetic bag and you will see the electric bridge in two images ... :)
I'm glad you like my wiring looms, they are TOP quality, they just need to be installed properly.
I will send you a private message shortly with my email so that you can contact me for the payment and shipping processes.
I used to charge 135 euros + shipping costs for these wiring looms + etc ... (as indicated in the forum sales section), but I will charge you 120 euros + shipping costs.
Payment is by Paypal, paypal fees and packaging is already included in the price, the shipment is certified with tracking number.
Vinayak185
Ok thank you. Will wait for private message. I will need your help during installation because I'm new to these things. I have read the installation guide and trying to understand it properly. I will have to wait till dimmer and auto switch arrive. Then I can start installation.
Please, check your inbox. :wink:
Don't worry about when your other orders will arrive, there were people here on the forum who did the installation 6 months after receiving my wiring looms. :lol:
I will be to help you when you need it, either here or by email.
Vinayak185
Ok sure thanks
Vinayak185
I have few doubts regarding wiring. After installation of new wiring. My headlight parking light u shaped. Will they act as DRLs?? I saw vento 2013 wiring of reverse light. There u gave crimp butt for auto dimming mirror. So the mirror and camera connected to BCM?
Both the anti-dazzle mirror and the RVC receive the reverse gear activation signal through the reversing light wire.
I have crimped two butt terminals on the reverse light wire so that you can take the reverse signal for both devices.
In no case does the reversing light wire feed the mirror or RVC, these two devices must get their power from the fuse box.
- Mirror = +15
- RVC = +30
The aftermarket headlights you installed on your 6R are most likely not DRL ready.
A separate electrical circuit from the Parking/side lights is required.
If the U LED lights in your aftermarket headlights do not have separate terminals, one for DRLs and one for Parking/Side lights, DRLs are not possible on those NON-OEM headlights.
Vinayak185
Ok thank you so much. :)
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
ciclo wrote: Fri Dec 18, 2020 10:24 am The rest of the guide is totally useful for you (except the part of the anti-dazzle mirror and RLS wiring, logicaly).
ciclo,
i just admire these images.
hats off to your attention to details and dedication.
Thank you, it is only the bridges to the possible. :)
Hello Vinayak,
...in response to your email question.
:arrow: viewtopic.php?p=578472#p578472
+30 or +15 (original wire / bar) will be used depending on the requirements of the new device.
- Mirror = +15
- RVC = +30
Recommendation: if you are not able to understand this, which is very simple, it is better that you hire someone to do your electrical installation.
Vinayak185
I understood. Thank you
Vinayak185
Hello Everyone, I had installed the BCM Max Adaptation and auto lights wiring this week on my Polo 6R.
It took me 5 days to complete the installation. Everything works beautifully. The wiring provided by ciclo sir is of excellent quality and perfect. I finished all the installation today and posting here the final Autoscan.
Friday,26,February,2021,17:05:36:00233
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: WVWC14608ET069582 License Plate: 4259
Mileage: 85490km-53121mi Repair Order: 4
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: WVWC14608ET069582 Mileage: 85490km-53121miles
Address 01: Engine (J623-CLNA) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9971
Revision: --H33--- Serial number: 00000000000000
Coding: 00110016032500080000
Shop #: WSC 36792 002 104857
ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
ROD: EV_ECM16TDI02103L906023CR_003.rod
VCID: 050BCCD68421CFAE38-8050
Readiness: 0000 1000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0001
Serial number: --------------
Coding: 60DD2763412918C90619E471825318020000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 030FD2CE8A15F19E16-8056
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40851DC2D3832A864B-8014
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 9000 238150833
Coding: 3AB82FB848A10000013806D03CCB9E90F08067FF60002001200400030000
Shop #: WSC 12345 123 12345
VCID: 2F674E7E7E1DA5FEA2-807A
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 260215 03 37 0059
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Serial number: 13202576131205051351
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13202579131210074912
Coding: 010000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 2771621065102472AB2B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13202580131212230948
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581131127234117
Coding: 020000
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00PX2AZ
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 499300E6E8B9EBCE9C-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140C00
Shop #: WSC 11802 938 12345
VCID: 479706DEFEAD1DBE8A-8012
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 002300
VCID: 70E58D02A3A3FA06FB-8024
Component: IMMO H04 0805
VCID: 6AD19F6A8D7F00D6B5-803E
Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 54AD21923FFBA626FF-8000
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 09475GD0078320
Coding: 0000044004000A
Shop #: WSC 00081 790 00133
VCID: 458B0CD6CCA10FAE78-8010
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 174
Mileage: 85499 km
Time Indication: 0
Date: 2021.02.26
Time: 11:42:02
End-------------------------(Elapsed Time: 02:17)--------------------------
The BCM max coding given by ciclo sir worked perfectly. BCM threw error of heated mirrors. It was my mistake that i kept on that feature unnecessarily. later it went off when i disabled it through vcds.
Thanks Ciclo sir for all the help and support during installation. I learned alot from you. You are a Genius.
patil
Post by patil »
Congratulations Vinayak. 8)
I am sorry to see your private message late, I was extraordinarily busy with work. :|
Happy to know that you soughted out the issues you faced.👍
Interesting to see that 7H0 BCM Max being installed.
Now you have cleared the way for few new mods in future. :mrgreen:
