Bixenon headlights with AFS For polo gt Tsi 2015
hmthakur
Drives: Polo gt tsi 1.2 dsg
Re: Bixenon headlights with AFS For polo gt Tsi 2015
Post by hmthakur »
iichel wrote:I think it will also depend on what sensor you're planning to put on the rear axle. As far as I understood, there are several types of sensor with different sampling frequencies. This needs to match with the AFS control module.
What about this sensors
Afs sensors 6R0 941 273 B
Polo 6R (Not Sedan/Vento)
:arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
6R0907357 Z03
with
6R0941273B
hmthakur
Post by hmthakur »
Got these t10-t14 adapter wiring loom from car-systems.
Is there LHD AND RHD in wiring loom??
It has 6 xtra pins
Where these pins go in bcm??
Will i have to de-pin cornering light pins from Bcm??
I guess you'll have to ask carsysems about their hardware.
From the driver's seat the right headlight is the right one and the left headlight is the left one ... ... :lol:
A clue for pin assignment:
Good luck!
Ask the right questions by providing correct information. We do not know if you want to install an elephant, Bixenon headlights or LED headlights.
It's amazing how easily people change their minds. :lol:
The electrical installation of cornering lights is not the same for bixenon as for LED headlights.
Please confirm.
hmthakur
Post by hmthakur »
I am installing bixenon headlights and had got the wiring for same from you (cicolo)[emoji848]
I see that the sense of humor shines by its absence. (not to consider, my mind is very different, worse or better it doesn't matter, it's just different)
In this case (bixenon) and if your 6R has the cornering lights in the fog lights:
- Yes, you have to de-pin the present cornering lighs wires from bcm, replacing them by those of Carsystems harness.
- and you have to make a new installation for the fog lights. (without BCM controll).
I think I've written everything correctly. Good luck!
hmthakur
Post by hmthakur »
ciclo wrote:I see that the sense of humor shines by its absence. (not to consider, my mind is very different, worse or better it doesn't matter, it's just different)
Thanks Master, was just confirming [emoji5]
hmthakur
Post by hmthakur »
Got following module for direct TPMS and ready wire loom from AliExpress.
Which is can high and can low in the module??
Which slot should i use from fuse box??
I have open can lines near instrument cluster after installing bcm high, which is can high and can low?!
Use the powertrain CAN (i.e. at PDC, steering angle sensor)
hmthakur
Post by hmthakur »
iichel wrote:Use the powertrain CAN (i.e. at PDC, steering angle sensor)
My car is 2015 make it dont have CAN connections in PDC. isolated wires near instrument cluster are powertrain can lines ??
I'm not sure, they could be if you had an 087/086/085 BCM before. The new lines are not powertrain CAN but a new IC Can for 7E0 BCM. Don't use those.
I guess the old CAN wires could be powertrain CAN. Otherwise, you could try to make a splice at the BCM or the steering angle sender.
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
hmthakur wrote: Wed Aug 15, 2018 6:55 pm
Yes the old wires removed from cluster are Canbus power train orange Black is can high and orange brown is can low you can extend and use those wires to connect TPMS Module
hmthakur
Post by hmthakur »
smg_shardul wrote: Wed Aug 15, 2018 7:35 pm Yes the old wires removed from cluster are Canbus power train orange Black is can high and orange brown is can low you can extend and use those wires to connect TPMS Module
+1
