BCM High to BCM Max, AFS, LED Headlights and HBA
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Re: BCM High to BCM Max, AFS, LED Headlights and HBA
Post by firegrafik »
Ok, second question!
Could it be possible if you provided new wires from wrong A (black) socket instead of B (white)?
federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
No, I already checked this two wires. They are plugged in B (white connector). Now I check again this wires with multimeter. I'll do some photos.
Free help:
Factory mode, BCM channel 99, to 0.
http://wiki.ross-tech.com/wiki/index.ph ... ctory_Mode
Read but pay attention to what you are reading.
http://wiki.ross-tech.com/wiki/index.ph ... l_Matching
Start Matching new/additional Remote Controls by entering 0, then Test and Save the New Value.
Press and hold the Unlock button for at least one second on the Remote Control you want to add, the Blinkers will light up to confirm the Adaptation Process of each Remote Control.
If matching several remotes, the control module may only learn one remote per Adaptation 01 session. Read channel 01 again to do additional remotes.... by entering 0
If matching several remotes the one in the ignition during the adaptation may be the only one that confirms with the blinkers. If this is the case, repeat the process after swapping the key used in the ignition to match the next one.
federicodrdpro
I checked the wires with multimeter. They are ok. Here the photos:
@ciclo: Factory mode already set to "0". I try to register the keyfob again.
that indeed looks correct.
According Autoscan the IC can not be reached.
Check that the IC connector is properly inserted and secured with lock mechanish.
You have many wires near to this area, do the tests without fit the IC in its place. Maybe there are little gnomes behind the IC doing tricks with the connector when you fit the IC in its place.
federicodrdpro
After plugged again the GND battery, tacho work correctly and I registered the keyfob.
Congrats!
federicodrdpro
ciclo wrote: Mon Jan 29, 2018 5:53 pmCongrats!
Thanks :D
Now LED position don't work and when I flashing with High Beam the indicator light check appear on the tacho.
This is a new autoscan:
Monday,29,January,2018,19:14:40:00001
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY020628   License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 44 55 0B
VIN: WVWZZZ6RZCY020628   Mileage: 82830km-51468miles
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021     HW: 03P 907 425 A
   Component: R3 1.2 DCM3.7 H06 8410
   Revision: 11002001    Serial number:
   Coding: 00114014002400080000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM12TDI03103P906021 001010
   ROD: EV_ECM12TDI03103P906021.rod
   VCID: 65C089086461C76E19-8030
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416F00B2842B14E482D900421700
   Shop #: WSC 00788 648 00255
   VCID: 071CA380B22D357ECB-8052
3 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
                    Fault Status: 00100101
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x1219
                    Hex Value: 0x1498
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF9
01317 - Control Module in Instrument Cluster (J285)
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 11
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x1211
                    Hex Value: 0x2598
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF9
00474 - Control Module for Immobilizer
                    Fault Priority: 0
                    Fault Frequency: 11
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x1232
                    Hex Value: 0x1498
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF9
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326A22546D2F60D64C-8066
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 128171814
   Coding: 3CB02BBF08E3260092380C006D6F9CD00088672F60860000300000020000
   Shop #: WSC 18752 008 00032
   VCID: 2B543F304A05311E0F-807E
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU030051100011446
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU025051100015419
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: K8 951 171 A    HW: K89 511 71A
   Serial number: ÿK8951171A  °103
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027051100012627
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU027051100013292
   Coding: 08BC32
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00NWXFQ
   Coding: 003232
   VCID: 4A9A5AB4EDBF081614-801E
   Serial number: 3575HRB40550INGS999T
   Serial number: 3585HRB40570INGSBHPF
   Serial number: 3515RRB40510JNPM7P50
   Serial number: 3525RRB404P0K4DOA8O1
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 140A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3A7A0A74BD5F989684-806E
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002200
   VCID: 68DE803C9B73DA0622-803C
   Component: IMMO          H03 0505
   Serial number:
   VCID: 6ADAFA348D7FE81634-803E
   Part No: 6R0 423 156 B
   Coding: 11210
   Shop #: WSC 00788
   VCID: 2F6C2B20EA1D4D3E23-807A
1 Fault Found:
            49-10 - No Communications - Intermittent
   Revision: --------    Serial number: --------------
   Coding: 0202000001000000
   Shop #: WSC 02757 790 50316
   VCID: 77FCD340CECD45FEBB-8022
2 Faults Found:
5256213 - Front Vehicle Height/Level Sensor
          C114D 15 [137] - Open or Short to Plus
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 82835 km
                    Date: 2018.01.29
                    Time: 00:32:25
5256725 - Rear Vehicle Height/Level Sensor
          C114E 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 82835 km
                    Date: 2018.01.29
                    Time: 00:32:25
End-------------------------(Elapsed Time: 03:07)--------------------------
federicodrdpro
Latest autoscan:
Monday,29,January,2018,21:17:41:00001
www.Ross-Tech.com
   Revision: --------
   Revision: 0002S 02
   Coding: 18BC30
   Coding: 08BC30
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003232
   Coding: 140A01
   Revision: B9082001
   Coding: 002200
   Serial number:
   Coding: 11210
   Shop #: WSC 00788
2 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 82835 km
                    Date: 2018.01.29
                    Time: 02:32:35
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 0
                    Mileage: 82835 km
                    Date: 2018.01.29
                    Time: 02:32:35
End-------------------------(Elapsed Time: 03:04)--------------------------
Which is the coding of LED headlights?
LED positions don't work now.
3CB02BBF08E3260092380C006C6F9CD00088732F60871440300000020000
I'd start with something like this
Based on the information provided
3CB02BBF08E3260092380C916C6F9CD05A88732F60851040200000030000
From here, all faults that arise have to be corrected physically.
I suspect you'll have several faults for what was said before.
federicodrdpro wrote: Mon Jan 29, 2018 6:20 pm
Thanks :D
www.Ross-Tech.com
   Revision: --------
3 Faults Found:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x1219
                    Hex Value: 0x1498
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF9
                    Fault Priority: 0
                    Fault Frequency: 11
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x1211
                    Hex Value: 0x2598
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF9
                    Fault Priority: 0
                    Fault Frequency: 11
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x1232
                    Hex Value: 0x1498
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF9
   Revision: 0002S 02
   Coding: 18BC30
   Coding: 08BC30
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003232
   Coding: 140A01
   Revision: B9082001
   Coding: 002200
   Serial number:
   Coding: 11210
   Shop #: WSC 00788
1 Fault Found:
2 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 82835 km
                    Date: 2018.01.29
                    Time: 00:32:25
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 82835 km
                    Date: 2018.01.29
                    Time: 00:32:25
federicodrdpro
Thanks iichel! Now LED positions works fine. Parking lights work fine and with low intensity. But when I flashing with the High beam, low beam turn off for a second and then turn on again.
Then Low beam don't turn off when I activate turn signal. (with Byte 23 bit 7).
Actually coding: 3CB02BBF08E3260092380C007C6F9CD00088732F608714C0300000020000
@ciclo: Now I only have the 55 Xenon range errors. Now I try your coding.
P.S. I tried to change the coding of the module 55. I can change all bit of the coding but not byte 1 (Polo/Multivan). Now when I turn on the ignition, the "headlights regulation presentation" start :lol:
EDIT:
ciclo, with this coding: 3CB02BBF08E3260092380C916C6F9CD05A88732F60851040200000030000 , I have the same results of iichel coding and appear the lights check on the tacho.
P.S.2: Today I received VCP cable, but disk driver is broken :roll:
I am waiting the driver via mail.
Some connection to the BCM :mrgreen:
federicodrdpro wrote: Mon Jan 29, 2018 10:00 pm EDIT:
IMPOSSIBLE :wink:
Good luck!!!
Bye.
So, your current coding:
I would maybe try some adjustments, but keep the coding ciclo provided as the best reference.
3CB02BBF08E3260092380C906C6F9CD05A88732F60851040200000030000
setting byte 11 to 90 will disable byte 11 bit 0 (high beam via xenon shutters)
you can have a look whether byte 21 on HEX 85 or HEX 87 makes a difference for the parking lights
a very crude way to disable the malfunction light is to set byte 16 to HEX FF but this simply kills all the light diagnostics.
I would not recommend that.
just to verify, the high beams are still via the high beam stalk and the fuse box SB34 15A, and both high beams work, and the fuse is intact?
