Vento ~ Polo Sedan 1.5 Tdi RHD
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Re: BCM Max upgrade in Polo Sedan (Vento in india) manual highline
Post by sshakthi123 »
ciclo wrote: Thu Feb 21, 2019 1:47 pm Since your new BCM Max 7E0937090D (last model 7E0) is manufactured for LED headlights (8IT), it is new for all of us.
It is not the first time that a BCM PQ25 is parameterized differently to the previous ones.
Clarified. Thank you 8)
ciclo wrote: Thu Feb 21, 2019 1:47 pm 3A904BFF48A10000013806507CEB96904D80600F608C2141220000030000
I will try this in next 2 hours and revert back.
I understand you are helping me in your crunch time, but I really wanted a help to fix rain closing of windows. Help may be in terms of sourcing the right part / right coding, etc. This is one of the primary reason for me to update the BCM.
Clear like the water:
Subsystem 2 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU021021440523980
Coding: 1400B3
Subsystem 3 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU004101300011381
Coding: 0400B3
... and all the functions will work like a charm!... auto folding mirror function too.
sshakthi123
ciclo wrote: Thu Feb 21, 2019 2:51 pm Clear like the water:
Coding: 1400B3
Coding: 0400B3
Nope. Changing the RLS coding to 0728DD made rain closing windows are working now.
Tried the following,
1. keep windows down -> locked the car -> pour water immediately -> and it rolled up the windows
2. keep windows down -> DIDN't LOCK the car -> pour water immediately -> and it rolled up the windows
3. followed same procedure of #1 and #2 but pour the water after 5 to 10 mins -> THIS DIDN'T ROLL THE WINDOWS
4. car running(on) -> windows down -> pour water -> this also didn't roll up the windows
Please confirm this is the right behavior.
This made no changes. Still the back-up light error continues.
here is the latest scan,
Thursday,21,February,2019,22:18:25:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXJ1760XJT075118   License Plate: 8854
Mileage: 18080km-11234mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXJ1760XJT075118   Mileage: 18080km-11234miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXC)       Labels: None
   Part No SW: 03L 906 023 RS    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110116032500080000
   Shop #: WSC 00000 000 08192
   ASAM Dataset: EV_ECM15TDI02103L906023RS 001002
   ROD: EV_ECM15TDI02103L906023QT.rod
   VCID: 081F2E22B3333D0450-805C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CA    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0004
   Serial number: --------------
   Coding: 60DD2F63212A04C50615F46A845920020000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 7F0DB5FEE6FD7ABC61-802A
   Serial number: 03111813470922
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF348FAE1F773B46A-802A
1 Fault Found:
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 3
                    Mileage: 18081 km
                    Date: 2015.06.02
                    Time: 10:12:59
                    Voltage terminal 15: 13.70 V
                    Voltage terminal 30: 13.95 V
                    Terminal 15 status: On
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8601 222180856
   Coding: 3A904BFF48A10000013806507CEB96904D80600F608C2141220000030000
   Shop #: WSC 12345 123 12345
   VCID: 2C57B2B24F0B312494-8078
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 290617 04  42  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2521
   Serial number: 13202848170704050535
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2521
   Serial number: 13102849170705002249
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 1811713320101504AB1B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1522
   Serial number: 13102728170704212031
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1522
   Serial number: 13102729170630002341
3 Faults Found:
00901 - Back-Up Lamps
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:21:31
02745 - Bulb for Daytime Running Light; Left
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:12:53
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 18063 km
                    Time Indication: 0
                    Date: 2015.05.30
                    Time: 14:12:53
   Part No SW: 7E0 919 475 K    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231325304021
   Coding: 308002
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 3A7B84EABD5F9F9416-806E
   Revision: --------    Serial number: 003GW01BGFS-
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RF 920 862 B    HW: 6RF 920 862 B
   Component: KOMBI         H01 0217
   Coding: 1208000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 4B95D12EE2C5161CBD-801E
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 002300
   VCID: 68DF0EA29B73DD04B0-803C
   Component: IMMO          H01 0217
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5515
   Revision: --------    Serial number: VWZ7Z2R8103103
   Coding: 0E000440000010
   Shop #: WSC 12345 123 08192
   VCID: 4999EB26E0B9040C8F-801C
End-------------------------(Elapsed Time: 02:27)--------------------------
I see that you have copied my RLHS coding. Congrats.
Actually no one knows what is the "Rain Closing" behavior on the PQ25. Maybe the one you describe is correct.
Your BCM 090D has an unusual behavior for lights diagnostic. It is currently coded so that it does not detect faults in DRLs or reverse light.
Well, let's start from 0, try the following coding:
3A904BFF48A10000013806007CEB96900980600F608C2141220000030000
Other way,
Reverse light
Play with the following combinations in BCM Byte11 Bit4 and Bit6.
00, 01, 10, 11
0 = disable
1 = enable
Remember, the previous stored faults always must be cleared before or during functional tests for new coding/condition.
DRLs
The same but in BCM Byte16 Bit2 and Bit6
sshakthi123
ciclo wrote: Fri Feb 22, 2019 1:35 am Other way,
Reverse light
00, 01, 10, 11
0 = disable
1 = enable
DRLs
Tried both the ways. It didn't help. The errors continuing,
Friday,22,February,2019,08:26:20:00006
www.Ross-Tech.com
Readiness: 0 0 0 0 1
   Coding: 01
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 18081 km
                    Date: 2015.06.02
                    Time: 20:06:02
                    Voltage terminal 15: 12.50 V
                    Voltage terminal 30: 12.70 V
   Revision: V0000000
   Coding: 3A904BFF48A10000013806007CEB96900980600F608C2141220000030000
   Coding: 0714DD
   Coding: 350000
   Coding: 040000
   Coding: 240000
3 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 18081 km
                    Time Indication: 0
                    Date: 2015.06.02
                    Time: 20:06:03
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 18081 km
                    Time Indication: 0
                    Date: 2015.06.02
                    Time: 20:06:03
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 18081 km
                    Time Indication: 0
                    Date: 2015.06.02
                    Time: 20:06:03
   Coding: 308002
   Coding: 003036
   Coding: 1208000000
   Revision: B9082001
   Coding: 002300
   Serial number:
End-------------------------(Elapsed Time: 02:34)--------------------------
sshakthi123
ciclo wrote: Thu Feb 21, 2019 6:56 pm
sshakthi123 wrote: Thu Feb 21, 2019 6:14 pm Tried the following,
1. ignition on -> windows down -> locked the car -> pour water immediately -> and it rolled up the windows
2. ignition on -> windows down -> DIDN't LOCK the car -> pour water immediately -> and it rolled up the windows
Please clarify on the rain closing behavior? does it not close if we try pouring the water after sometime OR if rain comes an hour after the car parked with windows down?
Re: BCM Max upgrade in Vento IND manual transmission
Clarifications about the behavior of the "Rain closing"
In your country there are the ideal climatic conditions (rain and heat) for someone to leave or forget a baby or small child inside the car and dies. Unfortunately it happens in many countries of the world.
A car closed under the sun can reach extreme temperatures for human life.
I will not give you any more explanations or evasive for the "Rain closing".
I hope your understanding and reasoning about it, strongly recommend that you deactivate the "Rain closing" function.
Show me an image of the tail light connector for the reverse light.
I want to see how many cables reach it and the colors of them.
You haven't yet done the steering ring calibration... what are you waiting for?
sshakthi123
ciclo wrote: Fri Feb 22, 2019 3:29 am Clarifications about the behavior of the "Rain closing"
:shock: forgetting and leaving a baby/child in a car is not an ideal thing. We cannot complain the features of a car for this :P
Anyway, leaving the car in Polo/sedan will not harm them as it will NOT work as per 3. followed same procedure of #1 and #2 but pour the water after 5 to 10 mins -> THIS DIDN'T ROLL THE WINDOWS I shared above.
sshakthi123 wrote: Fri Feb 22, 2019 1:08 pm ...
... with the right software/hardware it works p-e-r-f-e-c-t-l-y.
I'll not provide free help/support/info to others retrofits not related to the BCM adaptation or automatic lights.
Let's go to solve your 'problem' with the reverse light. (7E0937090D 8IT)
I understand that your reverse light works and that you don't have any warning light on the IC ... and yet the fault is detected on the vcds scan. :?
Please, try this BCM coding and tell me the result:
3A904BFF48A10000013806407CEB96904980630F608C2141220000030000
I'll send you a new wire depending on the result, everything will be solved regardless BCM coding for reverse light.
Please post the resquested image as soon as possible. Thanks...viewtopic.php?f=56&t=72122&p=550674#p550588
sshakthi123
ciclo wrote: Sat Feb 23, 2019 1:12 am
Let me know how you can help with this including the cost. I would like to get this set up.
ciclo wrote: Sat Feb 23, 2019 1:12 am Let's go to solve your 'problem' with the reverse light. (7E0937090D 8IT)
This coding didn't help, the error continues.
Saturday,23,February,2019,09:17:33:00006
www.Ross-Tech.com
   Coding: 01
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 18085 km
                    Date: 2015.06.03
                    Time: 21:03:42
                    Voltage terminal 15: 13.30 V
                    Voltage terminal 30: 13.85 V
   Revision: V0000000
   Coding: 3A904BFF48A10000013806407CEB96904980630F608C2141220000030000
   Coding: 0714DD
   Coding: 350000
   Coding: 040000
   Coding: 240000
3 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 18081 km
                    Time Indication: 0
                    Date: 2015.06.03
                    Time: 20:13:11
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 18081 km
                    Time Indication: 0
                    Date: 2015.06.02
                    Time: 20:26:19
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 18081 km
                    Time Indication: 0
                    Date: 2015.06.02
                    Time: 20:26:19
   Coding: 308002
   Coding: 003036
   Coding: 1208000000
   Revision: B9082001
   Coding: 002300
   Serial number:
End-------------------------(Elapsed Time: 02:26)--------------------------
here are the images,
Image Image
Nikhil
Drives: 1.6 tdi
Post by Nikhil »
As per my experience in manual transmission polo sedans in India, Backup lamp is controlled by the gear shifter not by the BCM, although BCM get input signal of reverse lamp from gear shifter.
So T73b/12 to Backup Lamp connection need to be done. Old wire you can cut and insulate. I hope this will solve Backup lamp error.
I had done mentioned procedure in one other car as per ciclos instructions in installation guide.
Best way to see if backup light is now connected to BCM or not is to take output test in BCM for backup light. If it dosent get on in output test means it is Not connected to Bcm. So BCM gives the error of Backup Light.
Nikhil wrote: Sat Feb 23, 2019 5:35 am So T73b/12 to Backup Lamp connection need to be done.
It's the way but it is not absolutely necessary.
Nikhil wrote: Sat Feb 23, 2019 5:35 am Best way to see if backup light is now connected to BCM or not ...
The best way ... is to check the wiring diagrams or have extensive experience and know that in this case it is not connected to terminal T73b/12 , but is connected to terminal T73b/48.
...this doesn't necessarily have to show the fault, depends on the BCM coding.
In this new BCM 7E0 ... D and according to the reports, remove the diagnosis by coding does not work.
Nikhil
Drives: 1.6 tdi
Post by Nikhil »
ciclo wrote: Sat Feb 23, 2019 5:53 am
T73b/48 is input signal to Bcm for Backup light from gear selector. It dosent give any output to reverse light.
T73b/12 is output of Backup lamp.
Is BCM able to do backup lamp diagnostics from input terminal?
