Page 5 of 7
Re: Polo 6R 09 1.4 85KM
Posted: Wed May 06, 2020 1:32 pm
by iichel
Ah yes, installation of G85
OEM:
T41/5 goes to SB20 (red/yellow)
T41/6 goes to SB9 (blue/black)
If there is space, you can splice to these wires. I expect that there are already wires going to these fuses.
Posted: Wed May 06, 2020 2:05 pm
by dcgumis
iichel wrote: Wed May 06, 2020 1:32 pm
OEM:
thank you, yes, I have Sat 20 cables I have a Ciclo cable
I'm a bit lost
Posted: Wed May 06, 2020 2:06 pm
by dcgumis
OEM:
thank you, yes sb 20 and sb 9, I have Sb 20 cables I have a Ciclo cable
I'm a bit lost
Can I use SB 58?
Posted: Wed May 06, 2020 2:15 pm
by iichel
You can connect T41/5 to SB58 in this case. That will also work.
Posted: Wed May 06, 2020 7:09 pm
by dcgumis
Thank you for your help iichel
I did the installation according to Ciclo instructions
In 03 ABS I can not calibrate the steering wheel sensor in the basic settings an error appears.
after selection
Bit 21-2.7
Bit 12-6
Bulb failure warning is also active on the instrument clusters.It may not work with ABS without ESP, or I have too old cable.
Wednesday,06,May,2020,19:09:14:05031
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WVWZZZ6RZAY License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 55 56
VIN: Mileage: 173390km-107739miles
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AC HW: 6R0 907 379 AC
Component: ABS8.2 front H04 0001
Revision: --------
Coding: 200228E3016F00B2042C14E280D800000200
Shop #: WSC 02069 123 12345
VCID: 7F0A9BD3EAEEDBC624-802A
Address 08: Auto HVAC (J30˙˙) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 HW: 6R0 820 045
Component: Climatic 23 0500
Revision: 00 09 23
VCID: 6BD25F838A96576698-803E
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 014162029
Coding: 3DB02BB828F3240092380010FC2B1DD00BC0670F608530C1200000030000
Shop #: WSC 02737 022 00190
VCID: 68D8208F9B607C7EF5-803C
Subsystem 1 - Part No SW: 6R0 959 801 H HW: 6R0 959 801 H Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 0803
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 802 K HW: 6R0 959 802 K Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 0803
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H04 0103
Coding: A4FFFF
Subsystem 7 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 002 0803
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Coding: 08BC32
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 31
Mileage: 173392 km
Time Indication: 0
Date: 2020.05.06
Time: 19:01:55
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231602503915
Coding: 100001
Shop #: WSC 35759 001 104857
ROD: N/A
VCID: 3B72AFC3B27607E648-806E
No ASAM data for: "EV_VW75XParkAssis8K" (VW25)
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag005 H09 0018
Revision: -------- Serial number: 003DW003YHK-
Coding: 003035
Shop #: WSC 124697 483 00190
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 428CD227D59C762E0B-8016
Crash sensor for side airbag; driver side:
Serial number: 3572SRB40000911C8A98
Crash sensor for side airbag; front passenger side:
Serial number: 3582SRB4000091185980
Crash sensor for side airbag; rear; driver side:
Serial number: 3516GRB401V9F7IH9SA3
Crash sensor for side airbag; rear; passenger side:
Serial number: 3526GRB40219F7IH1K1-
Part No SW: 6R0 920 870 B HW: 6R0 920 870 B
Component: KOMBI H05 0607
Coding: 140E00
Shop #: WSC 00788 648 00255
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 346084FF9F28C89E89-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 042200
Component: IMMO H05 0607
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADC5A878D6C4E6EE3-803E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 1T0 035 680 R
Component: RNS-MID H24 6276
Revision: AB001001 Serial number: VWZ6Z7S0418589
Coding: 00010000010000A00001
Shop #: WSC 01357 011 00200
VCID: 3D76A1DBA46209D676-8068
Subsystem 1 - Part No: 1T0 919 859 C
Component: EU East V15 8522
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 00000
VCID: 2E549697ED04E24EFF-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D4D000001000000
Shop #: WSC 12345 123 12345
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A7CAAC7BD4C3EEE53-806E
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:08)--------------------------
Posted: Wed May 06, 2020 7:12 pm
by iichel
The bits and bytes are for cornering lights. You can put them back.
Did you select 04 in the CAN gateway installation list? Can you open the module with VCDS?
Posted: Wed May 06, 2020 7:18 pm
by dcgumis
iichel wrote: Wed May 06, 2020 7:12 pm
YES 04 CAN gateway installation list
I can't see it after entering the Select module.
Only when I make Autoscan can I enter Steering Angle I have too old cable.I am thinking about buying OEM VCDS, I have bought OEM VCP for now
Posted: Wed May 06, 2020 7:23 pm
by iichel
What happens if you write 04 in the bottom (direct entry) and select GO in the 'select module' screen?
Posted: Tue May 12, 2020 11:34 am
by dcgumis
iichel wrote: Wed May 06, 2020 7:23 pm
Hi iichel
, I bought OEM VCDS,There is a very big difference between OEM and clone
now I can see 04 control tables in module 04.
In 04 basic settings, I cannot calibrate the sensor because you must have an access code.
Whereas 03 ABS
basic settings in group 060 I write that it is not available
In the evening I will try to do it
"[Select]
[03 - ABS Brakes]
[Security Access - 16]
Enter 40168
[Do It!]
Turn steering wheel full lock to lock then center out so front wheels are straight ahead, steering wheel is level.
[Basic Settings - 04]
[IDE02284-ENG98502] Steering angle sensor: carry out zero calibration
[Go!]
I believe you should get a message of "Finished Correctly".
[Stop]
[Done, Go Back]"
thank you for help
Posted: Wed May 13, 2020 9:38 am
by dcgumis
dcgumis wrote: Tue May 12, 2020 11:34 am
Hi iichel
Whereas 03 ABS
"[Select]
[03 - ABS Brakes]
Enter 40168
[Do It!]
[Go!]
[Stop]
[Done, Go Back]"
thank you for help
I did as above, unfortunately I do not see the G85 sensor in ABS.
There are no errors in automatic scanning
It looks like it works
Wtorek,12,Maj,2020,22:06:01:12281
VCDS -- Emulator VAG/VAS pracujący w środowisku Windows, uruchomiony na Windows 7 x64
Wersja VCDS: AKP 19.6.2.1 HEX-V2 CB: 0.4508.4
Wersja danych: 20200101 DS308.0
www.vcds.pl
VIN: vwvwvw Numer rejestracyjny:
Typ podwozia: 6R-VW25 (7E0)
Skanowanie: 01 03 04 08 09 10 15 17 19 25 37 44 55 56
VIN: WVWZZPrzebieg: 173450km
01-Silnik -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
04-Kąt skrętu kierow. -- Stan: OK 0000
08-Klimatyzacja -- Stan: OK 0000
09-Centr.zesp.elektr. -- Stan: Usterka 0010
10-Asyst.park./kierow. -- Stan: OK 0000
15-Airbag -- Stan: OK 0000
17-Zest.wskaźników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
25-Immobiliser -- Stan: OK 0000
37-Nawigacja -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: OK 0000
55-Zasięg świateł -- Stan: OK 0000
56-Radio -- Stan: OK 0000
Adres 01: Silnik
Nie może być osiągnięty
Adres 03: ABS/hamulce (J104) Plik etykiet: Brak
Oznaczenie elementu SW: 6R0 907 379 AC HW: 6R0 907 379 AC
Komponent: ABS8.2 front H04 0001
Weryfikacja: --------
Kodowanie: 200228E3016F00B2042C14E280D800000200
Kod serwisu: WSC 02069 123 12345
VCID: 7F5B06D127BF836FB0C-802A
Nie znaleziono błędów.
[b]Adres 04: Kąt skrętu kierow. (G085) Plik etykiet:* 6R0-959-654.clb
Oznaczenie elementu SW: 6R0 959 654 HW: 6R0 959 654
Komponent: LENKW.SENSOR H06 0070
Numer seryjny: 19121204650811
Kodowanie: 01
Kod serwisu: WSC 12345 123 12345
Zbiór danych ASAM: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FBD520758A67BBA-802A
Nie znaleziono błędów.[/b]
Adres 08: Klimatyzacja (J30˙˙) Plik etykiet: 6R0-820-045-9AP.clb
Oznaczenie elementu SW: 6R0 820 045 HW: 6R0 820 045
Komponent: Climatic 23 0500
Weryfikacja: 00 09 23
VCID: 6B83C28143870FCF0C4-803E
Adres 09: Centr.zesp.elektr. (J519) Plik etykiet:. 7E0-937-BCM-V1.clb
Oznaczenie elementu SW: 7E0 937 090 HW: 7E0 937 090
Komponent: BCM PQ25 Max4 H80 0736
Weryfikacja: B9080001 Numer seryjny: 0771 014162029
Kodowanie: 3DB02BB828F3240092380010BC2B1DD00BC0670F600530C1200000030000
Kod serwisu: WSC 02737 022 00190
VCID: 6889BD8D527124D7616-803C
Podsystem 1 - Oznaczenie elementu SW: 6R0 959 801 H HW: 6R0 959 801 H Plik etykiet: 6R0-959-801.CLB
Komponent: J386__TSG_FT 002 0803
Numer seryjny: KU0-KU016.06.0911474
Kodowanie: 08BC30
Podsystem 2 - Oznaczenie elementu SW: 6R0 959 802 K HW: 6R0 959 802 K Plik etykiet: 6R0-959-802.CLB
Komponent: J387__TSG_BT 002 0803
Numer seryjny: KU0-KU019.06.0912110
Kodowanie: 08BC30
Podsystem 3 - Oznaczenie elementu: 1K8 951 171 A
Komponent: DWA-Sensor 00 001 0103
Kodowanie: 000000
Podsystem 4 - Oznaczenie elementu: 1K8 951 605
Komponent: LIN BACKUP HO H09 9002
Kodowanie: 000000
Podsystem 5 - Oznaczenie elementu: 1K8 951 171 A
Kodowanie: 000000
Podsystem 6 - Oznaczenie elementu SW: 1K8 959 442 HW: 1K8 959 442
Komponent: E221__MFL-DC1 H04 0103
Numer seryjny: 29190000541900099111
Kodowanie: A4FFFF
Podsystem 7 - Oznaczenie elementu SW: 6R0 959 811 B HW: 6R0 959 811 B
Komponent: J388__TSG_HL 002 0803
Numer seryjny: KU0-KU015.06.0913043
Kodowanie: 08BC32
Podsystem 8 - Oznaczenie elementu SW: 6R0 959 812 B HW: 6R0 959 812 B
Komponent: J389__TSG_HR 002 0803
Numer seryjny: KU0-KU015.06.0914644
Kodowanie: 08BC32
Znaleziono 1 błąd:
01134 - Syrena alarmu (H12)
000 - -
Ramka zamrożona:
Stan błędu: 01100000
Priorytet błędu: 6
Częstość błędu: 1
Wew.licznik błędów: 44
Przebieg: 173453 km
Wskaźnik czasu: 0
Data: 2020.05.12
Czas: 22:02:55
Adres 10: Asyst.park./kierow. (J446) Plik etykiet:| 7E0-919-475.clb
Oznaczenie elementu SW: 7E0 919 475 L HW: 7N0 919 475
Komponent: PARKHILFE 8K H06 0106
Weryfikacja: -------- Numer seryjny: 28231602503915
Kodowanie: 100001
Kod serwisu: WSC 35759 001 104857
Zbiór danych ASAM: EV_VW75XParkAssis8K 001003
VCID: 3B2332C173E75F4FDC4-806E
Adres 15: Airbag (J234) Plik etykiet:| 5K0-959-655.clb
Oznaczenie elementu SW: 6R0 959 655 C HW: 6R0 959 655 C
Komponent: VW10Airbag005 H09 0018
Weryfikacja: -------- Numer seryjny: 003DW003YHK-
Kodowanie: 003035
Kod serwisu: WSC 124697 483 00190
Zbiór danych ASAM: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 42DD4F25140D2E879F2-8016
Czujnik zderzenia bocznej poduszki bezp.po stronie kierowcy:
Numer seryjny: 3572SRB40000911C8A98
Czujnik zderzenia bocznej poduszki bezp.po stronie pasażera:
Numer seryjny: 3582SRB4000091185980
Czujnik zderzenia bocznej poduszki bezp.z tyłu po str.kierowcy:
Numer seryjny: 3516GRB401V9F7IH9SA3
Czujnik zderz.bocznej poduszki bezp.z tyłu po str.przedn.pasaż.:
Numer seryjny: 3526GRB40219F7IH1K1-
Adres 17: Zest.wskaźników (J285) Plik etykiet:| 5K0-920-xxx-17.clb-SRI1
Oznaczenie elementu SW: 6R0 920 870 B HW: 6R0 920 870 B
Komponent: KOMBI H05 0607
Numer seryjny: 00000000000000
Kodowanie: 140E00
Kod serwisu: WSC 00788 648 00255
Zbiór danych ASAM: EV_Kombi_UDS_VDD_RM09 A04716
VCID: 343119FD5EB990371DE-8060
Adres 19: CAN Gateway (J533) Plik etykiet:. 7E0-909-901.clb
Oznaczenie elementu SW: 7E0 909 901 HW: 7E0 937 090
Komponent: GW-K-CAN TP20 H80 0736
Kodowanie: 002200
Adres 25: Immobiliser (J334) Plik etykiet:| 5K0-920-xxx-25.clb
Oznaczenie elementu SW: 5K0 953 234 HW: 5K0 953 234
Komponent: IMMO H05 0607
Numer seryjny:
Kodowanie: 000000
Kod serwisu: WSC 00000 000 00000
Zbiór danych ASAM: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8DC7854CFD16C7772-803E
Adres 37: Nawigacja (J0506) Plik etykiet:. AKP\1T0-035-680.clb
Oznaczenie elementu SW: 1T0 035 680 R HW: 1T0 035 680 R
Komponent: RNS-MID H24 6276
Weryfikacja: AB001001 Numer seryjny: VWZ6Z7S0418589
Kodowanie: 00010000010000A00001
Kod serwisu: WSC 01357 011 00200
VCID: 3D273CD96D73517FE20-8068
Podsystem 1 - Oznaczenie elementu: 1T0 919 859 C
Komponent: EU East V15 8522
Adres 44: Wsp.kierownicy Plik etykiet: 6Q0-423-156.clb
Oznaczenie elementu: 6R0 423 156 A
Komponent: LenkhilfeTRW V275
Kodowanie: 10150
VCID: 2E050B95B955BAE76BA-807A
Adres 55: Zasięg świateł (J431) Plik etykiet:. 6R0-907-357.clb
Oznaczenie elementu SW: 6R0 907 357 C HW: 6R0 907 357 B
Komponent: AFS-ECU 005 0050
Weryfikacja: -------- Numer seryjny: --------------
Kodowanie: 0D4D000001000000
Zbiór danych ASAM: EV_HeadlRegulVWLWRCC 002006
VCID: 3A2D37C57CDD6647C72-806E
Adres 56: Radio (J0506) Plik etykiet:. AKP\1T0-035-680.clb
Koniec (Skanowanie trwało: 01:39, Napięcie akumulatora - na początku skanowania / przy końcu skanowania: 12.1V/11.8V. VIgn 11.8V)
Posted: Wed May 13, 2020 10:18 am
by iichel
I guess, I don't really speak Polish...
Easiest way to check is to try your cornering lights
Posted: Wed May 20, 2020 2:54 pm
by dcgumis
iichel wrote: Wed May 13, 2020 10:18 am
Hello
I am sorry now I have in my language VCDS
The cornering lights do not come on.In position 03 abs the g85 sensor is not visible.so it probably won't work for me
after selection
Bit 21-2.7
Bit 12-6
Bulb failure warning is also active on the IC.
Wednesday,20,May,2020,14:47:35:12281
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
www.Ross-Tech.com
VIN: WVWZZ License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 44 55 56
VIN: WVWZ Mileage: 173810km-108000miles
Address 01: Engine
Cannot be reached
Revision: --------
VCID: 7F5B06D127BF83632A1-802A
Component: LENKW.SENSOR H06 0070
Serial number: 19121204650811
Coding: 01
VCID: 7EA5FBD520758A6B217-802A
Revision: 00 09 23
VCID: 6B83C28143870FC3969-803E
VCID: 6889BD8D527124DBFBB-803C
Serial number: KU0-KU016.06.0911474
Coding: 08BC30
Serial number: KU0-KU019.06.0912110
Coding: 08BC30
Serial number: 29190000541900099111
Coding: A4FFFF
Serial number: KU0-KU015.06.0913043
Coding: 08BC32
Serial number: KU0-KU015.06.0914644
Coding: 08BC32
1 Fault Found:
000 - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 62
Mileage: 173813 km
Time Indication: 0
Date: 2020.05.20
Time: 14:45:28
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Coding: 100001
VCID: 3B2332C173E75F43469-806E
Coding: 003035
VCID: 42DD4F25140D2E8B05F-8016
Coding: 140E00
VCID: 343119FD5EB9903B873-8060
Revision: B9080001
Coding: 042200
Serial number:
VCID: 6A8DC7854CFD16CBEDF-803E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
VCID: 3D273CD96D73517378D-8068
Coding: 10150
Shop #: WSC 00000
VCID: 2E050B95B955BAEBF17-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
VCID: 3A2D37C57CDD664B5DF-806E
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
End----------(Elapsed Time: 01:39, VBatt start/end: 13.5V/13.6V)-----------
[/codde]
Posted: Wed May 20, 2020 5:59 pm
by Pipefoto
Hi, I wanted to know where I can buy the automatic lights cable kit. Thank you.
Posted: Wed May 20, 2020 6:57 pm
by Pipefoto
ciclo wrote: Fri Dec 06, 2019 1:51 pm
Hi Piotrek, thanks for sharing the images of your 6R.
You will have a nice 6R RED when you finish the installations, LED headlights,
R-line bumpers, etc ...
Your wiring looms 'B': viewtopic.php?f=62&t=69223&start=105#p563747
The installation guide, download the PDF document.
I will send you a private message to contact me by email. (soon, wait a little please
I mean this Thank you
Posted: Thu May 21, 2020 5:16 am
by ciclo
dcgumis wrote: Wed May 20, 2020 2:54 pm
They will work for you when the SCLs wiring is installed correctly.
You can be absolutely sure.
I wonder if you installed the wiring for automatic lights.
According to iichel's instructions for installing the SCLs wiring, he is referring to the T17 connector of the old light switch, and it is not correct with the automatic lights wiring.
On the other hand, I notice that you do not want to have the automatic lights activated in the BCM coding.
Note:
You cannot make any kind of correction, modification, calibration, basic setting or adaptation of your new G85 retrofitted sensor in YOUR ABS unit --->
WITHOUT ESP system ..
no problem for this reason. Your ABS unit is not involved in the operation of SCLs at all. (G85 and BCM only)
However, you can check with VCDS if the steering wheel angles (steering column) reach the BCM at the advanced values (or meas values). If the angle values change when you move the steering wheel, the installation of your new G85 sensor ring is correct. Which is correct according to your last Autoscan.
Good to know that the TinyQ parameterization worked correctly for your AFS unit (6R Europe).
