LED headlamp retrofit
Scotty_boy vw
Re: LED headlamp retrofit
Post by Scotty_boy vw »
Today I retro fitted the genuine LED headlights to my polo.
These things are awesome 🤩
Scott
emb961
Drives: 2019 AW
Post by emb961 »
Scotty_boy vw wrote: Mon Jun 14, 2021 1:31 pm Today I retro fitted the genuine LED headlights to my polo.
Scott
Hi Scott,
Love the new LED’s on your Polo! Could you please share how the install went from factory halogens?
As far as I have been made aware they aren’t plug and play. Very interested in doing this for my Polo!
kieranhendy
Drives: Polo AW R-Line 2019
Post by kieranhendy »
Wow those look brilliant! Out of curiousity, do they turn and stuff as you steer like the ones on the Tiguan? Many thanks
AndrewBarnett99
Drives: MK6 2019 Polo GTI
Post by AndrewBarnett99 »
Hello, I have a 2019 Polo GTI that was factory spec'd with the standard halogen lights, i am trying to upgrade them to the DRL LED headlights that come with the GTI plus. I have bought the genuine VW DRL LED headlights that were made in March 2019 although when i tried to switch them the cable connector did not fit. Any idea on where i can get an adapter for the connection and will i need to rewire the cables & recode for the upgraded headlights?
Scotty_boy vw
AndrewBarnett99 wrote: Thu Aug 05, 2021 2:15 pm Hello, I have a 2019 Polo GTI that was factory spec'd with the standard halogen lights, i am trying to upgrade them to the DRL LED headlights that come with the GTI plus. I have bought the genuine VW DRL LED headlights that were made in March 2019 although when i tried to switch them the cable connector did not fit. Any idea on where i can get an adapter for the connection and will i need to rewire the cables & recode for the upgraded headlights?
Hi andrew send me a PM and i can get you in touch with my mate who did all my looms for my LED RetroFit
scott
AndrewBarnett99
Hello Scott, that would be perfect thanks, cheers will do. :)
emb961
Drives: 2019 AW
Post by emb961 »
Scotty_boy vw wrote: Thu Aug 05, 2021 4:36 pm
scott
Gday Scott,
Sorry can’t seem to be able to PM you on here. I’d love to know how you went about the LED unit fit too!
Cheers Brendan
Scotty_boy vw
AndrewBarnett99 wrote: Fri Aug 06, 2021 11:21 am Hello Scott, that would be perfect thanks, cheers will do. :)
Hi andrew you maybe cant send a pm yet so put your mobile number on here and i will WhatsApp you
cheers
scott
RS250PS
Drives: 1.0 115ps mk6
Post by RS250PS »
Hello again!
After about 6 months, my headlamps, I bought from aliexpress, work flawlessly! Their light is bright and strong.
Recently I noticed that in your headlights, both DRLs (the upper strip and the bottom strip) keep being lighten up after some time. In my headlamps, they light up when I turn the lights on, bit after some seconds (not even a minute) the upper DRL strip turns off. So, the car looks like this:
So, it differs from the original LED Headlamps. Do your DRL upper strips also turn off after a minute, or they keep being turned on?
It is not a problem, as it turns on as it should with a blue tint at the start and then becomes clear white.
German_Fartbox
Drives: Polo GTI 2.0 DSG (2020)
Post by German_Fartbox »
Did you have to adjust the beam angle at all on either light? Mine are way out and no matter amount how much I try and adjust them they will not align. You see two horizontal lines in front of me where the two beams are out. I actually think the left light adjustment screw part is broken as it doesnt shift at all when I turn it either way.
Is there a second adjustment screw on them do you know aside from the one on top of the light?
RS250PS
Post by RS250PS »
German_Fartbox wrote: Thu Aug 19, 2021 12:59 pm Did you have to adjust the beam angle at all on either light? Mine are way out and no matter amount how much I try and adjust them they will not align. You see two horizontal lines in front of me where the two beams are out. I actually think the left light adjustment screw part is broken as it doesnt shift at all when I turn it either way.
These lights have no aligning motor, so you have to align them using the screw they have. In my occasion, they were fine aligned and didn't have to align them. Took my car to an electrician, to check the alignment using the special tool for this job, but told me that they are fine.
You should have in mind that the right beam is shining higher than the left (in left-hand driven cars), so that the left won't blind the coming drivers from the opposite direction.
German_Fartbox
RS250PS wrote: Fri Aug 20, 2021 9:35 am
Yeah I tried using the screw on top of the headlight, the right light does move but the left doesn't. Maybe it's faulty, I'll have to have another go at it.
emb961
Drives: 2019 AW
Post by emb961 »
Hi Andrew,
Did you end up hearing back from Scott? Still really interested in doing this for my 2019 115ps R-line!
william_
Drives: POLO 2G GTI
Post by william_ »
Hey,
I found good alternative for genuine led light's. Germany have legal led h7 light's it's osram 64210DWNB. I have this "bulbs" in my polo aw and light geometry is really good! and i dont have bulb error. Here is video with test https://www.youtube.com/watch?v=hbQBokg ... ilVerliebt
Flashredpolo
Drives: 2018 AW GTI
Post by Flashredpolo »
Hi, any more news on this?
I'm interested in a set of these aliexpress lights on my UK spec car
Can anyone link me to a set they bought?
Also what was required to install
