GOLF 7.5 FL R-LINE
dcgumis
Re: GOLF 7.5 FL R-LINE
Post by dcgumis »
Hello the heated steering wheel button works :D but the "VIEW" button does not work for me :P
I installed PLA 3.0 :) works very cool :P
https://youtu.be/MUoZFf2Khyo
5G0919398A
5G0919397A
5G0919400F
5G0919399F
Module 5q0919298d
Sensor:
5Q0919297B 2x
5Q0919275B 2x
Plug:
4h0973703 2x
4h0973703A 2x
Will the TMPS module do well in this place?
I am thinking of colored lighting, but I would have to change bcm :x
Thanky You
My scan
Saturday,29,January,2022,22:15:32:12281
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WV License Plate: LOG
Mileage: 111250km-69127mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 29 2B 39 3C 42 44 4B 52 5F
          A5 D6 D7
VIN: WV  Mileage: 111250km-69127miles
05-Acc/Start Auth. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---    CVN: 65239CB2
   Coding: 0119003223441D083000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D87CC997D1301F37C7-8038
   VINID: 9E69EAAAA465A9A9C00C41C724A2CA081E
   Center armrest control head 1:
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 61697000000550
   Coding: 01FA6AA124232170477E060740CC2980562484E26002947334205078C042430000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
   VCID: 76B5E3F50845C22B8DD-8022
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0446157189
   Coding: 032C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   ROD: EV_KessyHellaMQBAB_002.rod
   VCID: 3C2131DD76E9587BBB9-8068
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3CC 907 044 M    HW: 3CC 907 044 M
   Component: Climatronic   H01 0204
   Coding: 03020004200400011105002D0018542E
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 001049
   ROD: EV_AirCondiBHTCMQB3rTranc_001_VW48.rod
   VCID: 3E253BD560F54A6B95D-806A
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001717600072
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 08499D0D72B1C4DBEF1-805C
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    170527  043 0551
   Serial number:         170614011659
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S5Y17M06D30H07M48S00
   Coding: 00A8DD
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY171438524
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000038591932
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417617199
   Coding: 0271165841
   Shop #: WSC 05744 128 28888
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF7069C16BC51378F-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 2B0D60615DFFCF28949C810560400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
   Component: AirbagVW21    005 0336
   Serial number: 003VVR3382S7
   Coding: 98CCC000000000005C0000CF000800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002158
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 074B9E317FAFCBA3E6B-8052
   Subsystem 1 - Part No SW: -----------    HW: 480 002 906 17
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000990355429
   Coding: 2D2D2D
   Subsystem 2 - Part No SW: -----------    HW: 480 002 906 17
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000002F138852H
   Coding: 2D2D2D
   Subsystem 3 - Part No SW: -----------    HW: 480 402 706 17
   Component: SideSensor_Dr  000 6149
   Serial number: 3510001C725EAC250766
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 402 606 17
   Component: SideSensor_Pr  000 6149
   Serial number: 3520001B525EAC24E38F
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 402 606 17
   Component: FrontSensor_D  000 6149
   Serial number: 3550001A326441E417A.
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 JC    HW: 5Q0 953 549 D
   Component: Lenks. Modul  004 0120
   Revision: --------    Serial number: 02041604402092
   Coding: 0400
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 0059852D5A81FC9BA71-8054
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         407 3193
   Coding: 072531126F8C0008078BFA0B5401000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2A0D07858C7DD6CBD95-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006491645
   Coding: 030100047F085700EA000248080F00010001070000000000000000000000
   Shop #: WSC 00046 000 00000
   GVL: 01563C000000060040CC80000000480000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF_VW37.rod
   VCID: 33331AE15BB797036A3-8066
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 B    HW: 1EA 959 442 B
   Component: MFL  H03 0217
   Serial number: 17036218093442000254
   Coding: AF0100
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 8278644404
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
   VCID: 47CB5E313F2F0BA326B-8012
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A
   Component: ELV-MQBA      H01 0120
   Revision: 00000000    Serial number: 17000162827003
   Coding: 5500000000000000
   ASAM Dataset: EV_ELVMarquMQB 004111
   ROD: EV_ELVMarquMQB.rod
   VCID: 343119FD5EB9903B739-8060
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0529643199
   Coding: 01011203
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D273CD96DF351738C7-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0530250202
   Coding: 010112
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 100417EDA04515
   Coding: 003F1220D000040000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 43D34A210B172783FA3-8016
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0007
   Serial number: 00000000000015283780
   Coding: 110000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 1307
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D75439052319B3D47-8010
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 16061710800232
   Coding: 00000005090016C200205F43020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BDDFE5642DDE0BA15-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 100617EFA19347
   Coding: 003F1020DE00040000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 42DD4F25140D2E8BF15-8016
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000015370221
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 043 A    HW: 5NA 035 043
   Component: MU-H-N-EU     H54 1121
   Serial number: A848F0HS010420
   Coding: 02731001FF0000005111000100080A001F0106F401200400FF
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_VW37.rod
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZHT1793170
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 806 N    HW: -----------
   Component: ECE 2020/2021  --- 0187
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1016
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 19091712K13094
   Coding: 0003070300000400002623548156890098000E300040
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB_001_VW36.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F28C979DB6D53A0F-806C
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----(Elapsed Time: 01:30, VBatt start/end: 12.6V/12.2V. VIgn 0.0V)------
Image Image Image
Image Image Image
Image Image Image Image Image Image
If you try...
Byte0 Bit3
Your original buttons were of the "MODE" model instead of the "Assistants" or Travel Assist model, ... and phone instead of "VIEW"
And currently you have installed the buttons for Travel Assist ... 🤪
Too many deficiencies... steering wheel with DSG paddles in a vehicle with manual gearbox, inadequate capacitive buttons, ... 🤦‍♂️ :lol:
Poles have a habit of doing exceptional things 🤭, one day you will discover the origin of the universe and you will not be aware of what you have done... 😁
dcgumis
Post by dcgumis »
Travel assistant is turned off :)I coded "VIEW" once, but the steering wheel heater button went off -https://www.youtube.com/watch?v=_E4x9LoisnI
Everything works except for the VIEW button
But how warm in winter :P In time, I will change to normal steering wheel without DSG :P
dcgumis wrote: Sun Jan 30, 2022 12:52 pm Everything works except for the VIEW button
... and the lamp failure that shows the AID? Everything? trying to distort reality never had a good ending...
dcgumis
Post by dcgumis »
ciclo wrote: Sun Jan 30, 2022 3:24 pm
"turn on the lights;"-)
I forgot the great meaning of that message in the AID, although honestly I did not pay enough attention to your previous post with the messy images and without any information about the work done.
Sorry I was enjoying the magnificent final of the Australian Open.
Good luck with the "VIEW" button. ;-)
raduss
Drives: Passat b8
Post by raduss »
"VIEW" button done?
raduss
Drives: Passat b8
Post by raduss »
Do you know how to solve my problem on Passat B8?
IMG-20211211-WA0025 (2).jpg (115.27 KiB) Viewed 26648 times
Zrzut ekranu 28-03-2022 00.17.33.jpg (353.53 KiB) Viewed 26648 times
Zrzut ekranu 27-02-2022 14.28.00.jpg (513.56 KiB) Viewed 26648 times
Zrzut ekranu 20-02-2022 12.08.48.jpg (406.35 KiB) Viewed 26648 times
