6C Full LED Headlights number
Re: 6C Full LED Headlights number
Thanks for the input my dear doctor, I asked in this forum if the TinyQ parameters for LED headlights were also correct for 6R hatchback and people finally told me YES. I have to say that it was very strange that people were intentionally hiding this info, maybe no one had enough knowledge about it.
The file on VCP specifies that it is for xenon, not for LED, look above in one of the images of my previous post. I was also checking it yesterday.
As you all know, I did not install the LED headlights, I preferred not to follow the trends, and to continue with my factory bixenon headlights. I think I was right.
By the way, in Ali this module is available for 6R in at least two stores, with coupons 11-11 perhaps its price is reasonable for all budgets.
- Drives: Polo 6R 1.6 TDI
Thank you to all for the information. I will order new module - 6R0 907 357 C Z09 and i hope that my suffering will end with it! I will publish the results as soon as possible. Till then will try to connect and install all components for HBA with little help from a friend here
The HBA can wait until you resolve the issue from control unit 55.
All the information you need for HBA is in the thread of my 6R.
I summarize it for you:
https://www.uk-polos.net/viewtopic.php?p=503577#p503577
With front fog lights:
https://drive.google.com/file/d/0B2nv91 ... B_5OxyUh0Q
Without front fog lights:
https://drive.google.com/file/d/0B2nv91 ... 57A3T1S71w
The automatic lights wiring I made for you should be replaced by the wires indicated in the diagrams.
I will only step in when everything is installed.
Expected date of expedition: 26.11.2021 / TNT Economy express
Until then I have only to wait and drive my other car...boring.
Brrr, from that shop what me to send VIN number of the car, explain them that i am doing retrofit, they still want VIN number of the car which have that control unit 6R0 907 357 C Z09..... So please Help someone
ZahariGeorgiev wrote: ↑Wed Nov 10, 2021 4:05 pm Brrr, from that shop what me to send VIN number of the car, explain them that i am doing retrofit, they still want VIN number of the car which have that control unit 6R0 907 357 C Z09..... So please Help someone
https://vk.com/market-82401118?w=produc ... 18_3819500
After waiting for the delivery of the new "6R0 907 357 C Z09", I received the same result - refuses any coding and I can not make the basic settings.... I am really disappointed
Now have to figure out where is the problem... and i don't know what to do and from where to start....
Please, if it is not a problem for you, could you tell us where you bought the new unit?
Your best option would have been the one posted by patil. (from Russia, with love)
Have you parameterized the unit with the TinyQ parameters?
Yep, that was the 1st thing i do
viewtopic.php?p=587217#p587217
Firegrafik is highly likely to find out what is going on in your 6R with these units, something is not being done correctly.
Re: 6C Full LED Headlights PRoblems
Hello and Happy new year to all!
After a big waiting i finally receive the new headlight range module from Russia, and finally manage to code it and do the basic settings for the headlights. No more errors in autoscan and no yellow lamps on the dashboard !
Unfortunately my problem with strange behavior of the headlights is still remaining and i really dont know what more to do. I try with new BCM 090, same results, even worst (cannot learn keys, and parking lights are totally out, only drls working)
I am starting to wonder if it is some coding issue or it is something connected with the steering module.
Any help will be appreciated !
factory mode disabled??
If you are talking for factory mode of the BCM, this was the first thing i do.
