Skills and experience are required for the perfect manual crimp of terminals, as well as knowledge of each type of terminal and wires.
I have about 10 different crimp tools, one of my favorites is not the most expensive ...
The same can be said for removing terminals from plastic connectors.
There is only one way to extract a terminal smoothly, you have to find it, then everything will be child's play ...
KamilPL
Drives: Seat Ibiza 6j1
Post by KamilPL »
I'm stupid 😅 success works, the windows counter works all right 😅 we can go to the next step, I think I know where I would have the error that it did not work before 😅 connected T32/28 -> T72/57 | T32/29 -> T72/59 so the other way around 😂
Cornering light does not work
Don't worry, we've all done more stupid stuff than this. Happy you found it.
KamilPL
Post by KamilPL »
Sorry for the lack of EN language in VCDS I only have PL language
Typ podwozia: 6J-SE25 (6N0)
Skanowanie: 01 03 04 08 09 15 17 19 25 2E 44 4B 56 77
VIN: VSSZZZ6JZDR026882   Przebieg: 163670km
01-Silnik -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
04-Kąt skrętu kierow. -- Stan: OK 0000
08-Klimatyzacja -- Stan: OK 0000
09-Centr.zesp.elektr. -- Stan: Usterka 0010
15-Airbag -- Stan: OK 0000
17-Zest.wskaźników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
25-Immobiliser -- Stan: OK 0000
2E-Media Player 3 -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: OK 0000
4B-Moduł wielofunkc. -- Stan: OK 0000
56-Radio -- Stan: OK 0000
77-Telefon -- Stan: OK 0000
Adres 01: Silnik        Plik etykiet: 03C-906-024-BXW.lbl
   Oznaczenie elementu SW: 03C 906 024 CD    HW: 03C 906 024 CD
   Komponent:       CGGB  MM4HV G 8548
   Weryfikacja: --H09---    Numer seryjny:
   Kodowanie: 0000071
   Kod serwisu: WSC 00200 935 12345
   VCID: 62CB1F8FBE4FB89BB5-515A
Nie znaleziono błędów.
Kody gotowości: 0000 0000
Adres 03: ABS/hamulce (J104)       Plik etykiet:. 6R0-907-37x-ESP82.clb
   Oznaczenie elementu SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Komponent: ESP8.2i front H05 0002
   Weryfikacja: --------
   Kodowanie: 110224DB216F00B8882D24EA84D300401100
   VCID: 000F350797030A8BC3-8054
Adres 08: Klimatyzacja (J255)       Plik etykiet: 6R0-907-044.clb
   Oznaczenie elementu SW: 6J0 820 043 D    HW: 6J0 820 043 D
   Komponent: Climatronic   H08 0707
   Weryfikacja: S0000000
   VCID: 254144932CE10FA390-8070
Adres 09: Centr.zesp.elektr. (J519)       Plik etykiet:. 7H0-937-08x-09.clb
   Oznaczenie elementu SW: 7H0 937 090     HW: 7H0 937 090
   Komponent: BCM PQ25 Max4 H72 0708
   Weryfikacja: B9072001    Numer seryjny: 0531 063131236
   Kodowanie: 7C8829F8C861010001200EF07EA80EC8F0C042FF608D2040200000000000
   VCID: 6BD572AB8A85F9D306-803E
   Podsystem 1 - Oznaczenie elementu: 1K0 955 559 AH  Plik etykiet: 1K0-955-559-AG.CLB
   Komponent: RLS 120315 05  54  0403
   Kodowanie: 07302D
   Podsystem 2 - Oznaczenie elementu SW: 6R0 959 801 AK    HW: 6R0 959 801 AK  Plik etykiet: 6R0-959-801.CLB
   Komponent: J386__TSG_FT  007 5110
   Numer seryjny: --------------------
   Kodowanie: 020000
   Podsystem 3 - Oznaczenie elementu SW: 6R0 959 802 AR    HW: 6R0 959 802 AR  Plik etykiet: 6R0-959-802.CLB
   Komponent: J387__TSG_BT  007 5110
   Kodowanie: 020000
2 - ilość znalezionych błędów. Oto one:
01516 - Zacisk 30 po lewej stronie
            011 - Przerwa w obwodzie
             Ramka zamrożona:
                    Stan błędu: 01101011
                    Priorytet błędu: 3
                    Częstość błędu: 1
                    Wew.licznik błędów: 167
                    Przebieg: 163671 km
                    Wskaźnik czasu: 0
                    Data: 2016.01.22
                    Czas: 02:37:51
00927 - Zacisk 30 po prawej stronie
             Ramka zamrożona:
                    Priorytet błędu: 3
                    Częstość błędu: 1
                    Przebieg: 163671 km
                    Wskaźnik czasu: 0
                    Data: 2016.01.22
                    Czas: 02:37:51
Adres 15: Airbag (J234)       Plik etykiet:| 5K0-959-655.clb
   Oznaczenie elementu SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Komponent: VW10AirbagA01 H10 0020
   Weryfikacja: --------    Numer seryjny: 003GX016A6B0
   Kodowanie: 003031
   Kod serwisu: WSC 06401 785 00200
   Zbiór danych ASAM: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9BD72FEDBF00DB5D-801E
   Czujnik zderzenia bocznej poduszki bezpieczeństwa kierowcy:
   Numer seryjny: 3495RRB406316Q1G31E
   Czujnik zderzenia bocznej poduszki bezpieczeństwa po stronie przedniego pasażera:
   Numer seryjny: 3505RRB405117HSIJ13A
Adres 17: Zest.wskaźników (J285)       Plik etykiet:| 5K0-920-xxx-17.clb-SRI1
   Oznaczenie elementu SW: 6J0 920 804 K    HW: 6J0 920 804 K
   Komponent: KOMBI         H03 0507
   Numer seryjny: 00000000000000
   Kodowanie: 110A00
   Kod serwisu: WSC 12345 123 01234
   Zbiór danych ASAM: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 326BAFCF652F681B05-8066
Adres 19: CAN Gateway (J533)       Plik etykiet:. 6N0-909-901-6R.clb
   Oznaczenie elementu SW: 6N0 909 901     HW: 7H0 937 090
   Komponent: GW-K-CAN TP20 H72 0708
   Kodowanie: 422000
   VCID: 70EF65C7A3A31A0B33-8024
Adres 25: Immobiliser (J334)       Plik etykiet:| 5K0-920-xxx-25.clb
   Oznaczenie elementu SW: 5K0 953 234     HW: 5K0 953 234
   Komponent: IMMO          H03 0507
   Numer seryjny:
   Kodowanie: 000000
   Kod serwisu: WSC 00000 000 00000
   Zbiór danych ASAM: EV_Immo_UDS_VDD_RM09 A03009
   VCID: 6ADB77AF8D7FE0DB7D-803E
Adres 2E: Media Player 3 (J650)       Plik etykiet:. 5N0-035-342.lbl
   Oznaczenie elementu SW: 6J0 035 342 E    HW: 6J0 035 342 E
   Komponent: SG EXT.PLAYER H13 0240
   Weryfikacja: A1001003    Numer seryjny: 7662260740
   Kodowanie: 020000
   Kod serwisu: WSC 64564 324 38760
   VCID: 2643439F51E704BB99-8072
Adres 44: Wsp.kierownicy        Plik etykiet: 6Q0-423-156.clb
   Oznaczenie elementu: 6R0 423 156 B
   Komponent: LenkhilfeTRW        V277
   Kodowanie: 11211
   Kod serwisu: WSC 06402
   VCID: 2F6DA6BBEA1D45F36A-807A
Adres 4B: Moduł wielofunkc.        Plik etykiet: 6J0-959-441.clb
   Oznaczenie elementu: 6J0 959 441 A
   Komponent: MF-Modul       0007 0001
   Kodowanie: 0000002
   Kod serwisu: WSC 77005 000 00000
   VCID: 3169A0C3A82953037C-8064
Adres 56: Radio (J503)       Plik etykiet:. 6J0-035-153.clb
   Oznaczenie elementu SW: 6J1 035 153 G    HW: 6J1 035 153 G
   Komponent: Radio         H15 0204
   Weryfikacja: R0000000    Numer seryjny: SEZAZ2M4042195
   Kodowanie: 0001040002
   Kod serwisu: WSC 04941 000 00000
   VCID: 295948A340F92BC3B4-807C
Adres 77: Telefon (J412)       Plik etykiet:| 7P6-035-730.clb
   Oznaczenie elementu SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Komponent: TELEFON       H09 2730
   Weryfikacja: 1B001001    Numer seryjny: 00007662181617
   Kodowanie: 0E00000001010110
   Kod serwisu: WSC 06402 785 00200
   Zbiór danych ASAM: EV_UHVNA A01015
   ROD: EV_UHVNA_A01_VW25.rod
   VCID: 356194D394417F2320-8060
Znaleziono 1 błąd:
0022 - Radio
          U1066 00 [000] - Brak komunikacji
          [Nowa funkcja - rozszerzone informacje o kodach błędów (protokół UDS) - jest dostępna wyłącznie przy użyciu najnowszych interfejsów, oferowanych na VCDS
          Sporadyczny - Niepotwierdzony - Testowany od skasowania kodów błędów
KamilPL wrote: Tue Aug 31, 2021 5:05 pm I'm stupid 😅 success works, the windows counter works all right 😅 we can go to the next step, I think I know where I would have the error that it did not work before 😅 connected T32/28 -> T72/57 | T32/29 -> T72/59 so the other way around 😂
Perfect 💎, as we suspected, the communication issue was resolved.👌
And do not worry, it is better to make a mistake at the beginning to stay alert in the following works/steps,
you can start with them whenever you want. :arrow: viewtopic.php?p=585264#p585264
KamilPL wrote: Tue Aug 31, 2021 5:05 pm Cornering light does not work
I'll take a look at the BCM coding.
Warning:
I will do the new BCM coding based on the Autoscan with the original BCM 087, which seems more reasonable to me than the Autocan with 7H0 BCM (with some inappropriate changes).
Later you can modify what you think is convenient, but remember that the one I provide should be your starting point for the BCM Max 7H0.
My recommendation is that you do not touch the new BCM coding that I provide you during the installation process (as if you were a magician's apprentice 🧙‍♂️ :lol: ), otherwise, we will not be able to know what is happening in case of faults.
KamilPL
Post by KamilPL »
now I have to do everything you gave in this link viewtopic.php?p=585264#p585264 and everything will work?
leaving home machine works, coming home machine does not work / traffic light lever
Yes, ... if you don't make mistakes, everything will work perfectly.
The process is:
Installation ---> Coding ---> Troubleshooting in case of mistakes. (step by step)
KamilPL
Post by KamilPL »
And why does coming home not work by pulling the high beam lever / via the RLS sensor?
We will stop the topic temporarily, I will return to the topic as the electrician will take over the electrician, because I gave advice to drag 2 cables and then I will give it to the electrician 😅
I'll post your new BCM Max coding shortly, stay tuned ...
KamilPL wrote: Tue Aug 31, 2021 8:42 pm And why does coming home not work by pulling the high beam lever / via the RLS sensor?
In the parameterization data that I have for BCMs PQ25 (factory), this function is not contemplated.
ciclo wrote: Tue Aug 31, 2021 7:49 pm Warning:
read my quote again ⬆
7C8829F88861010001200EF06EEB9EC85FC067FF608D30C1200000030000
That is, the next autoscan must be with all new wires installed and with this BCM coding. Good luck!
KamilPL
Post by KamilPL »
in the meantime, another question rain closing does not work despite activating bcm / rls + locked car from the key, any advice?
Is it possible in Ibiza 6j window motors to program the mirrors to close / open when opening / closing the car with the remote control?
How to install the washer fluid level sensor? no sensor no wiring loom
Update : 13.09 ibiza goes to an electrician, around a week it will be constant so +/- 20.09 we come back to the topic 😎
I'm afraid that your WRMs don't support those functions, they must be with a higher SW. However, once you code the BCM and RLS to "rain closing active" the WRMs must learn the new coding by setting the "comfort function" again with the window switches (owner manual). Try it.
I do not recommend activating this feature.
As for the G33 Ibiza 6J, this is the diagram:
Once installed, it must be activated in the IC.
You may be inspired to install it with this info:
https://www.youtube.com/watch?v=pG7Rn7XDffA ...the sensor is the same. (Ali)
In addition to ciclo's excellent post above, the brown/white wire can also be replaced by a 'normal' ground wire to chassis.
KamilPL
Post by KamilPL »
translator twists sentences and I don't understand everything exactly
We let go of the washer fluid level topic
It is not possible to close / open the mirrors when locking / opening the car in ibiza?
What do I need to do for Active Rain Shutdown to work?
