firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
Post by firegrafik »
No, I just suggested the gearbox is still needed the K-line to be connected to the OBDII socket like can-bus. And the possible issue could be is in K-line wire is connected to the BCM's T73b/37 as well so it could cause the reading faults because of 7E0 BCM sends LIN data packets through the T73b/37 to the K-line.
As you wrote T73b/37 is not connetcet at all, so that could not be the reason of reading inability for the 02 addres, so for now I dont have another suggestion...
I think I did it... I replaced all control modules from my car originally came with, with another module. And added some.
- Installed 1.6 TDI engine
- Installed DSG gearbox + gear selector
- Installed K-Line from T25/11 to T16/7 (OBD)
- Adapted immobiliser
- Coded various modules to work in accordance with DSG gearbox
Friday,20,August,2021,14:33:16:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4544.4
Data version: 20210318 DS325.0
www.Ross-Tech.com
Dealer/Shop Name: iichel retrofitting
Workshop Code: 470 31889 031889
VIN:   License Plate:
Mileage:   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55
          56 57 61 65 69 6C 77 0B
VIN:   Mileage:
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 DR    HW: 03L 906 023 A
   Component: R4 1.6l TDI   H23 9978
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00254036032401080000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM16TDI02103L906023DR 003016
   ROD: EV_ECM16TDI02103L997557Q.rod
   VCID: 79AF10A5095BB703C8D-802C
Readiness: 0 0 0 0 0
Address 02: Auto Trans
Cannot be reached
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Coding: 21DD2885412500C5841A146E825500521504
   Shop #: WSC 31889 470 31889
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: N/A
   VCID: 0F7B4E7D27DF89B3069-805A
No ASAM data for: "EV_Brake1ESP90iBOSCH" (VW36)
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   Shop #: WSC 31889 047 31889
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSYPQ35G_A02_VW31.rod
   VCID: 372BD69D7FCF61737E9-8062
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E0B773-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 173171327
   Coding: 3EB82BBFA8EB3400B33807F0BFCB9FF0FF8067EFE08D78D031E400030800
   VCID: 2B03FAEDB307D5930A1-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0214DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027011200011418
   Coding: 58BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391528804191
   Coding: 0031195101
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: km
                    Date: 2021.08.20
                    Time: 14:30:19
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F691C3DEC9B117-801E
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140F01
   Shop #: WSC 12345 123 12345
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 3333E28D6BB78D53421-8066
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042204
   VCID: 688945E162713E8B273-803C
   Revision: AA001001
   Coding: 0404000000000000010000
   VCID: 2E05F3F98095A0BB2DF-807A
   Component: IMMO          H04 0709
   Coding: 000007
   VCID: 6A8D3FE97CFD0C9B317-803E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F3BEEFD879FA9B3269-807A
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 3635DB997845987B65F-8062
   Subsystem 1 - Part No: 1T0 051 859 AS
   Component: EU West V17  8557
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02756 790 00000
   VCID: 2F3BEEFD8B1FA9B3269-807A
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ÿ
   Subsystem 4 - Serial number: H21982ÿ
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AD    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3124
   Serial number: CF3F0205
   Coding: 001F00
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_014.rod
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 280905E1A271FE8BE73-807C
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D4A000001000000
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2DCFA94CDD7C1B817-806E
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 57: TV Tuner        Labels: None
   Part No SW: 3C0 919 148 B    HW: 3C0 919 148
   Component: R78 DTV-JP          0250
   Revision: R0H14000    Serial number: 80100800042102
   Coding: 0000816
   Shop #: WSC 01324 020 00200
   VCID: 280905E1AEF1FE8BE73-807C
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0010
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030F7A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
   Serial number: 40000000058319
   ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9B3269-807A
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65974CD5996323E31C5-8030
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 25170CD5D563E3E3DC5-8070
End----------(Elapsed Time: 02:50, VBatt start/end: 12.8V/12.8V)-----------
01-Engine -- Status: OK 0000 --> CFWA to CAYC
02-Auto Trans -- Status: OK 0000 --> manual to DSG7 DQ200
03-ABS Brakes -- Status: OK 0000 --> ESP8.2i to ESP9.0i
04-Steering Angle -- Status: OK 0000 --> 6R0 to 6C0
05-Acc/Start Auth. -- Status: OK 0000 --> retrofitted kessy
08-Auto HVAC -- Status: OK 0000 --> manual to climatronic
09-Cent. Elect. -- Status: OK 0000 --> 6R0 937 088B to 7E0 937 090 C
+ WRM front, to folding mirror
+ WRM rear, from manual to electric
+ RLS retrofitted
+ DWA retrofitted
+ MFSW retrofitted
10-Park/Steer Assist -- Status: Malfunction 0010 --> retrofitted
15-Airbags -- Status: OK 0000 --> changed for passenger airbag deactivation
17-Instruments -- Status: OK 0000 --> 6R0 midline to 2H0 highline
19-CAN Gateway -- Status: OK 0000 --> 6R0 to 7E0
20-High Beam Assist. -- Status: OK 0000 --> retrofitted
25-Immobilizer -- Status: OK 0000 --> from normal to kessy
2B-Steer. Col. Lock -- Status: OK 0000 --> retrofitted kessy
2E-Media Player 3 -- Status: OK 0000 --> retrofitted
37-Navigation -- Status: OK 0000 --> RCD210 to RNS510 DAB
3C-Lane Change -- Status: OK 0000 --> retrofitted
44-Steering Assist -- Status: OK 0000 --> from electrohydraulic to electromechanic
47-Sound System -- Status: OK 0000 --> retrofitted dynaudio
4B-Multifunc. Module -- Status: Malfunction 0010 --> retrofitted
55-Headlight Range -- Status: OK 0000 --> retrofitted AFS
56-Radio -- Status: OK 0000 --> RCD210 to RNS510 DAB
57-TV Tuner -- Status: OK 0000 --> retrofitted
61-Battery Regul. -- Status: OK 0000 --> 6R0 to 7E0
+ BDM J367 from 6R0 to 6C0 GTI
65-Tire Pressure -- Status: OK 0000 --> retrofitted
69-Trailer -- Status: OK 0000 --> retrofitted
6C-Back-up Cam. -- Status: OK 0000 --> retrofitted
77-Telephone -- Status: OK 0000 --> retrofitted
ag69
Drives: 1.2TSi 77Kw 7DSG
Re: iichels Polo 6R 1.6TDI DSG Bluemotion --> OEM++ R-Line conversion
Post by ag69 »
Amazing iichel...
i am sure you would have a peaceful weekend ;)
Waiting for a photo and video/s
There are still some small jobs to do, to put the car back into perfect condition.
But for now, I'm pretty f*****g happy
Beautiful work 😍👍
ag69
Post by ag69 »
iichel -- nice video. thank you. now we can see how much time and efforts it must have taken.
Also i liked the naming you used : Racing, No Racing & Super Speed
Great job again. Tons of efforts.
GeoffThe9NPolo
Drives: 2013 1.2 6R in Flash Red
Post by GeoffThe9NPolo »
Hi iichel, just found this thread, I've read nearly all of it. Absolutely amazing work done to a humble Polo. Its a long way back, but I'm especially interested in your suspension that you mention on the first page.
"OEM 6R sports suspension springs
Koni FSD shock absorbers all around--> 2100-4122
OEM 1J Rear spring mounts from Cupra -10mm --> 1J0512149"
Do you have the part numbers for the springs? I assume they are OEM GTi springs? Also the Cupra rear spring mounts are something I've not seen before. Is it just a case of swapping the spring mounts and the rear is 10mm lower? I really want to lower my Polo a bit but I can't install aftermarket parts due to my insurance so this really interests me. One other thing, does anyone know if the GTI shock absorbers are different to the normal Polo? Or would I need GTI shocks as well if I was to install GTI springs?
Sorry for all the questions, would love to know more.
No, the springs are not OEM GTI springs, that wouldn't make sense since that's a lot heavier than the 1.2 TDI.
It really depends on the engine and gearbox. And GTI dampers are not specific to the GTI. They also appear on i.e. the 1.6 TDI.
If you do lower, I'd suggest to replace the rear dampers for i.e. Bilstein B4/B6 since 25+mm lowering on the rear will quickly demolish your standard dampers.
You can have a look here for genuine lowering springs --> viewtopic.php?p=444680#p444680
The cupra rear spring mounts will indeed drop you about 10mm.
GeoffThe9NPolo
Wow, thanks for the quick reply.
I wasn't aware of the OEM Sports springs so I was just assuming they were for a GTI. Do you know if the sports springs are designed to be used with the original shock absorbers? Or are there OEM sports dampers available too? I can't fit any aftermarket parts, only OEM stuff so it's a bit difficult to figure stuff out.
If anything the sports springs lower the car too much, the GTI springs lower about 15mm but they are unsuitable due to the weight difference between a 1.8T and my 1.2. Are there any OEM options that lower about 15mm but would work on my 1.2 6R?
I don't think there is an OEM solution for 15mm lower. GTI springs will probably make your car higher instead of lower since you're putting 1200kg springs on a 900kg car...
Usually insurance companies don't really mind non-OEM shock absorbers since you can simply put an aftermarket shock like a Bilstein, Eibach, etc in there instead of a Sachs.
It's not a 'listed' part, so to say. Springs on the other hand are a different matter. But that's based on my own experience with German, Belgian and Swiss legislation. I don't know about the UK but I suspect they are probably just as strict or less strict.
GeoffThe9NPolo
Maybe I will abandon plans to lower it for now then. Going back to the Cupra rear spring seat, is it a straight swap with the standard spring seat? Also, are they the lower or upper spring mount? I assume the one on the left in that picture is the Cupra part?
Yes, it's the left one. It's a straight swap at the bottom.
GeoffThe9NPolo
Would you happen to have a link to where you bought it? I'm only finding them with letters on the end of the part numbers, e.g 1j0512149b,c,g
i always buy my stuff at the dealership
