Page 43 of 45
Posted: Sat Nov 18, 2023 1:40 pm
by Mick yeates1
Hi am finally back after having problems with getting the right terminals, I have installed the new Bcm code the keys and done the wiring. So am just ready for the coding now I think. Thanks
Posted: Sat Nov 18, 2023 2:51 pm
by Mick yeates1
Am in need of help it doing some weird stuff now 🤦🤦
Posted: Sat Nov 18, 2023 7:22 pm
by ciclo
Feel free to comment on any circumstance of the events that occurred during the installation of your bi-xenon/bcm-max/wiring, a full Autoscan is essential to be able to develop a corrective action plan.
Posted: Sun Nov 19, 2023 9:46 am
by Mick yeates1
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZFH036427 Mileage: 317930km-197552miles
08-Auto HVAC -- Status: Not registered 0011
10-Park/Steer Assist -- Status: Not registered 0011
13-Auto Dist. Reg -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
69-Trailer -- Status: Not registered 0001
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GH HW: 03L 907 309 M
Component: R4 2,0L EDC H45 6303
Revision: 26H45--- Serial number: 00000000000000 CVN: 18CB76B8
Coding: 01194012233400080000
Shop #: WSC 65535 123 12345
ASAM Dataset: EV_ECM20TDI01103L906019GH 003004
ROD: EV_ECM20TDI01103L906019FM_003.rod
VCID: 77AA1E63BF4123121E9-8022
VINID: 9E606AAAA1D8A966000C61021C5A6BCCA8
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 508724AD89A70A9B24A69173A96510
Shop #: WSC 02737 790 49152
VCID: 3A2CC757CC53FE7A217-806E
5 Faults Found:
01314 - Engine Control Module
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:59
Count: 16384
Count: 1
Count: 8194
Count: 762
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:60
Count: 16384
Count: 257
Count: 8193
Count: 762
00778 - Steering Angle Sensor (G85)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Time Indication: 0
Date: 2018.03.29
Time: 12:05:30
Count: 16384
Count: 1
Count: 8214
Count: 764
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
Count: 16512
Count: 2305
Count: 128
Count: 762
01299 - Diagnostic Interface for Data Bus (J533)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 16448
Count: 1
Count: 8233
Count: 764
Serial number: 24071404652032
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA40B47907B125A5DF-802A
3 Faults Found:
136194 - Supply voltage
U1011 00 [00001000] - Voltage too Low
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 15: 7.20 V
Voltage terminal 30: 7.25 V
Terminal 15 status: On
Entprellzeit: 90000 ms
332660 - Databus
U1121 00 [00001000] - Missing Message
Fault Priority: 6
Fault Frequency: 5
Reset counter: 60
Voltage terminal 15: 10.90 V
Voltage terminal 30: 5.00 V
Terminal 15 status: not coded/not installed
117060 - Databus
Fault Priority: 6
Fault Frequency: 5
Reset counter: 60
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
Shop #: WSC 02737 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 7CA0014F8667004A73B-8028
5 Faults Found:
13701408 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
13701424 - Function Restricted due to Missing Message(s)
[Steuergerät für Bordnetz - kein Signal/Kommunikation]
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
[Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
Fault Priority: 6
Fault Frequency: 11
Reset counter: 20
Date: 2000.00.00
Time: 00:00:00
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Fault Priority: 6
Fault Frequency: 19
Reset counter: 20
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
9481748 - High Pressure Sensor
B10AE 14 [00001000] - Open or Short to Ground
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:11:50
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 322171666
Coding: 20A4303A0A21203100280F712C2B8451C284668F60855160320400030800
Shop #: WSC 02739 022 156892
VCID: 2B02F213330957F2AA1-807E
Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8653
Serial number: KU0KU005081442171296
Coding: 1000B0
Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8653
Serial number: KU0KU018081442302458
Coding: 0000A0
Subsystem 3 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 7E1 951 172
Subsystem 6 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Serial number: 70000000000000124169
Coding: E20000
8 Faults Found:
00886 - Turn Signal Switch (E2)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 6
Reset counter: 20
Time Indication: 0
00077 - Windshield Wiper Stop Switch (F229)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 20
Time Indication: 0
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
01504 - Bulb for License-Plate Light (X)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Priority: 3
Fault Frequency: 3
Reset counter: 20
Time Indication: 0
04194 - Vehicle Status with Under-Voltage
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32901415406603
Coding: 118001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A2CC757CCD3FE7A217-806E
4 Faults Found:
1080083 - Rear Parking Aid Sensor(s)
B107B 13 [00001000] - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Date: 2023.11.05
Time: 18:39:26
13635840 - Supply voltage
[Versorgungsspannung - zu niedrig]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12664832 - Function Restricted due to Missing Message(s)
[Steuergerät für Gateway - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 5
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Address 13: Auto Dist. Reg
Cannot be reached
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00S3ZU8 Dataset Number: 7E0003v____ 0471
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3536D46BE5CD1102CC5-8060
Part No SW: 7E0 920 970 N HW: 7E0 920 970 N
Component: KOMBI H03 0805
Coding: 460A00
4 Faults Found:
12605440 - Databus
U1201 00 [00001000] - No Communications
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 4
Reset counter: 20
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
[Supply voltage too low]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
13654640 - Function Restricted due to Missing Message(s)
[Steuergerät für Abstandsdistanzregelung Low: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 20
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042305
VCID: 68884D1FE27FBCEA873-803C
7 Faults Found:
000 - -
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 153604 km
Time Indication: 0
Date: 2015.04.13
Time: 13:25:41
00470 - Company Comfort Databus in Single Wire
012 - Electrical Fault in Circuit - Intermittent
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 60
Time Indication: 0
01336 - Company Data Bus for Comfort System
Fault Priority: 2
Fault Frequency: 15
Reset counter: 59
Time Indication: 0
01319 - Control Module for Distance Control (J428)
Fault Priority: 2
Fault Frequency: 2
Reset counter: 19
Time Indication: 0
00381 - Databus Instrument Cluster
Fault Priority: 2
Fault Frequency: 55
Reset counter: 20
Time Indication: 0
03406 - Control Module for Battery Monitoring
Fault Priority: 2
Fault Frequency: 7
Reset counter: 60
Time Indication: 0
03158 - Control Module for Information Electronics 1 (J794)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
Component: IMMO H03 0805
Serial number:
VCID: 6A8C3717FCF38EFA917-803E
1 Fault Found:
13762816 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030B7A73
Shop #: WSC 02739 790 00000
3 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
Fault Priority: 2
Fault Frequency: 1
Posted: Sun Nov 19, 2023 9:49 am
by Mick yeates1
The first link I got sent to follow. Don’t really understand what I needed to do with that the one with the VW Polo so I haven’t done that but the second link with wiring the headlights and running new cables. Keep the main beam on that’s all done. Thanks 4 the help
Posted: Sun Nov 19, 2023 12:35 pm
by ciclo
You deserve an award for the Autoscan with the most faults in the forum history.🤭
It is obvious and evident that you have omitted some instructions from the links indicated in previous posts for the BCM replacement.
1- Please, now that you have 10 posts on the forum, post a complete Autoscan from when you had the BCM 087 installed with the halogen headlights and 'everything worked correctly', that is, without having touched the BCM coding. Thank you so much.
2- Have you correctly installed the new CAN lines (BCM-instrument cluster)? The old CAN lines that you remove from the instrument cluster connector 'Low and High' must be isolated 'separately' (they are still live lines for many other units).
3- Please read the ross-tech instructions for BCM replacement again, especially about transferring BCM coding, GW coding and GW installation list. Thanks a lot.
After this we start with the plan for debugging.
Note: Before doing any new Autoscan, you must 'Clear All DTCs' to avoid intermittent fault readings.
Note2: Please check the battery status, or use a power supply while using the diagnostic tool, or keep the engine running during the diagnostic process.
Posted: Sun Nov 19, 2023 1:31 pm
by Mick yeates1
🤣🤣 tell me about lol I haven’t done the instrument cluster cam lines. I’ve just been watching a video on YouTube in a polo. Will that be the same for the T5 .1.
Am not right good with technology sorry for being a pain 🤣🤣🤣
Posted: Sun Nov 19, 2023 1:49 pm
by ciclo
:arrow: viewtopic.php?p=528735#p528735, :arrow: https://drive.google.com/file/d/0B2nv91 ... 0ozRF3ht-w
Don't worry... we will solve everything step by step. :wink:
Posted: Sun Nov 19, 2023 5:08 pm
by Mick yeates1
Do I do all of that or just the instrument cluster bit thanks
Posted: Sun Nov 19, 2023 6:21 pm
by ciclo
I don't know what you've already done, do just what you need.
The new CAN lines are essential in this retrofitting.
Posted: Sun Nov 19, 2023 8:34 pm
by Mick yeates1
I have just done the instrument cluster canbus wires to night previously I have done the wires to keep the main beam on and fitted the the new bcm. On the link u sent it shows the wiring for the instrument cluster that I’ve just done 2 night and then there’s some more wiring that it’s on the light switch do I need to do that as well
Posted: Mon Nov 20, 2023 1:17 am
by ciclo
The following images are the same as the previous image, but with red coupling in case of installing the adapter wiring for AUTO light switch.
Posted: Mon Nov 20, 2023 1:36 am
by Mick yeates1
You’re an absolute star I’ll get this done over the next couple of days and get back to you. Thank you 👌🏻
Posted: Sat Nov 25, 2023 9:47 am
by Mick yeates1
morning sorry i haven't been back in touch i lost my head with theses lights wise i hadn't started them..
so just i recap on what i have done. i have put the t6 bcm i have coped the code from the old one using coding helper and pasted in to the new one and coded the keys i have done the wiring to keep the headlights on with the main beam done the can lines to the instrument cluster and the t17/t6 wiring to the bcm but still no luck
so the head light works as should / main beam works when pulled back but intermittently works when push forward. i'm assuming i need a t6 stalk to fix this. i still don't have side lights working and now the drl have stoped working when i did the the wiring to the t17 connector. and i have lost number plate lights to i did rear some wear on hear about the drl wires going 2 different pins i have got the in pin 5 and 6 on the white B plug as instructed off kuftec
any help would be grateful or if there is anyone out there that i can just pay and they can come and do it for me would be much appreciated hahahah
ill put the latest scan up to thanks
Posted: Sat Nov 25, 2023 9:57 am
by Mick yeates1
Saturday,25,November,2023,09:55:59:50810
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZFH036427 License Plate:
Scan: 01 03 04 08 09 10 15 17 19 25 56 69 77 0B
25-Immobilizer -- Status: Malfunction 0010
5 Faults Found:
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [00100000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 19 °C
Intake air temperature: 14 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.160 V
Unlearning counter according OBD: 39
Limitation: accelerator pedal: 92.4 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 200
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
4715 - No Communication with Instrument Cluster
U0155 00 [00100000] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Cruise Control System (CCS): status-Bits 0-7: 8
4717 - Body Control Module (Central Electric)
U0140 00 [00100000] - No Communications
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
4719 - No Communication with Diagnostic Gateway
U0146 00 [00100000] - -
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
5523 - Engine Start Blocked by Immobilizer
P1570 00 [00100000] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 934.50 /min
Intake air temperature: 15 °C
Voltage terminal 30: 11.680 V
Immobilizer snapshot A-Sia Error Snap A: 14 00 0A
Immobilizer snapshot B-Sia Error Snap B: 02 00 00
Readiness: 0 0 0 0 X
Revision: 00H43001
8 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:59
Count: 16384
Count: 1
Count: 8194
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:60
Count: 16384
Count: 257
Count: 8193
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Time Indication: 0
Date: 2018.03.29
Time: 12:05:30
Count: 16384
Count: 1
Count: 8214
Count: 764
Fault Priority: 1
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
Count: 16512
Count: 2305
Count: 128
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 16448
Count: 1
Count: 8207
Count: 764
01317 - Control Module in Instrument Cluster (J285)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Count: 16384
Count: 1
Count: 8242
Count: 764
03391 - Coding Not Possible
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Count: 16384
Count: 1
Count: 8254
Count: 764
00474 - Control Module for Immobilizer
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Count: 16384
Count: 1
Count: 8211
Count: 764
Coding: 01
4 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
332644 - Databus
Fault Priority: 6
Fault Frequency: 2
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 15: 10.80 V
Voltage terminal 30: 11.15 V
Entprellzeit: 5000 ms
332660 - Databus
Fault Priority: 6
Fault Frequency: 6
Reset counter: 60
117060 - Databus
Fault Priority: 6
Fault Frequency: 6
Reset counter: 60
Revision: 00001012
Coding: 0000000002
5 Faults Found:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
U1113 00 [00001000] - -
Fault Priority: 6
Fault Frequency: 16
Reset counter: 61
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 20
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:11:50
Coding: A0A4303A0A613431922848116C2B8C550080672F60850000320000010800
Coding: 1000B0
Coding: 0000A0
Coding: E20000
15 Faults Found:
Fault Priority: 2
Fault Frequency: 60
Reset counter: 21
Time Indication: 0
03432 - Activation of Right Parking Light
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:49
03435 - Terminal 30 for Interior Light and Parking Light
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:47
03303 - Response Closing Status of Rear Left Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 61
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.12
Time: 00:19:19
03396 - Supply voltage terminal 30 for central locking
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:47
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:48
Fault Priority: 3
Fault Frequency: 9
Reset counter: 21
Time Indication: 0
Fault Priority: 2
Fault Frequency: 11
Reset counter: 255
Time Indication: 0
03591 - Control Circuit for Horn
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:48
01516 - Terminal 30; Left
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:46
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 16
Reset counter: 61
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Time Indication: 0
Coding: 118001
5 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Date: 2023.11.05
Time: 18:39:26
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12670208 - Function Restricted due to Missing Message(s)
[Steuergerät für Schalttafeleinsatz-J285 - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 6
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
2 Faults Found:
12670208 - Databus
U1122 00 [00001000] - Implausible Message
[Kombi1-3 Time Out Error]
Fault Priority: 6
Fault Frequency: 2
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12674816 - Databus
[VIN Time Out Error]
Fault Priority: 6
Fault Frequency: 2
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 460A00
3 Faults Found:
12605440 - Databus
Fault Priority: 6
Fault Frequency: 3
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
Fault Priority: 6
Fault Frequency: 4
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Revision: B9082001
Coding: 042305
2 Faults Found:
000 - -
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.12
Time: 00:08:14
Fault Priority: 2
Fault Frequency: 5
Reset counter: 61
Mileage: 0 km
Time Indication: 0
Date: 2018.04.12
Time: 00:21:10
Serial number:
1 Fault Found:
13762816 - Databus
Fault Priority: 6
Fault Frequency: 3
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 3038E57F1A2F342A9F3-8064
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666502043 Dataset Number: 7P6035730M 0001
Coding: 0A01010000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3C20C14FC6E7C04A33B-8068
8 Faults Found:
9457427 - Left audio channel for speech/telephone
B104F 13 [00001001] - Short to GND
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 315425 km
Date: 2023.05.20
Time: 09:51:10
9457171 - Right audio channel for speech/telephone
B104E 13 [00001001] - Short to GND
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 315425 km
Date: 2023.05.20
Time: 09:51:10
12664832 - Body Control Module (Central Electric)
U0140 00 [00001000] - No Communications
Fault Priority: 6
Fault Frequency: 4
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
12670208 - No Communication with Instrument Cluster
U0155 00 [00001000] - -
[Kombiinstument: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 4
Reset counter: 30
12718592 - Steering Column Control Module
U0212 00 [00001000] - No Communications
Fault Priority: 6
Fault Frequency: 4
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
13633792 - No Communication with Diagnostic Gateway
U0146 00 [00001000] - -
[Gateway: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 31
Reset counter: 30
Mileage: 315689 km
Date: 2023.07.06
Time: 08:37:50
[Terminal 30: lower limit value not reached]
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Fault Priority: 6
Fault Frequency: 1
Reset counter: 30
End----------(Elapsed Time: 01:40, VBatt start/end: 14.0V/14.1V)-----------
