Although according to my personal preferences I would introduce the following BCM coding so that the CH & LH functions were carried out through the main headlights instead of the fog lights, and so that the fog lights were turned on when reversing (especially for a T5. 1 Highline Executive) which is very convenient in tight parking lots.
B8F2793A0A61241393208F706EEB9ED40780602F7E8C6841320003020000
Enjoy the wonderful feature of AUTOmatic lights!
Note:
Remember that the CH function is semi-automatic (pull stalk HB once + open the door). LH is automatic (remote control).
kylelnsn
Drives: T5.1
Post by kylelnsn »
Thank you both!!!
I can confirm we have automatic headlights! :D :shock: :D
Can I ask, as I would like to learn/understand what have we changed or activated? What is different now?
Thank you again. Next on the list... MFSW...
We changed a few bytes for asistent driving lights, coming home, leaving home and the version of coming home.
enkor
Drives: VW T5
Post by enkor »
ciclo wrote: Sat Feb 03, 2024 12:04 pm Lamp diagnosis works for all types of light bulbs. It depends on the coding and the dataset (parametry) established at the factory for the lighting configuration of the vehicle where the BCM is going to be installed. The parameters of the BCM PQ25 can be modified with VCP.
You can check the operation of the diagnosis by removing the bulbs, taking into account that the coding must be appropriate.
There was confusion in the definition of the Bit for lamp diagnosis on the VCDS labels for BCM PQ25, try the opposite in case of doubt.
At first the multifunction steering wheel buttons were connected to +30 but later to +15.
It is not compatible to have MFSW + Stalk for the trip computer at the same time.
Regarding the radio, I don't know what's happening to you, once unchecked from the GW installation list it should no longer appear.
Maybe it's related to Address 10 ...
... or other control unit.🤷‍♂️
I checked coding of every unit and I didn't find anything suspicious. It's a shame that the unit doesn't write what is the reason for that error. But I don't care as long as everything works :). Maybe it is related to bcm decoder of newly installed radio instead of original one so the unit thinks that radio is still installed.I will just leave it as it is.
Thank you one more to all of you guys.
Pit
Drives: T5.1
Post by Pit »
Evning, guys!! Is this post still alive for new project or is it for information only.....
I have finally started parts collection, and now trying to educate myself how to do so.
(Bixenon headlights and BCM 7H0937090B to replace 7H0937087B, are present.)
I have purchased : https://vag-instal.com/pl/products/adap ... 4-864.html
to have self levelling too - need support if 6R0907357B I can use this module from passat cc with my lights ( do I need 2 of??).. further to buy leveling sensors front and rear and washers....
not sure if I want to go with automatic mode but definitely not now.
As far I can see post is good knowledge center although very complicated to navigate.
Wish me luck!!
BTW. has any one ever changed colour of those drl lights to yellow??
Maybe some day I will be lucky and this will be answered... anyway:
as a blog will try to update what has been done.:
Currently test one - no DRL lights an any T17 switch position. Harnes I have bought from VAG-Instal has T14 conector location 12 connected with T10/4; but T14/10 has 0.5mm cable fitted wich should be fitted to BCM plug. This is the harnes with self leveling wich I wan to install too.( I am assuming that T14/12 has to be isolated and replaced with T14/10....)
Kameleon1978
Drives: VW gp t5.1 caravelle
Post by Kameleon1978 »
Hello,
I’m reviving this topic.
I’ve searched the whole thread but haven’t found an answer.
It’s a great thread – lots of things have been explained – a brilliant source of knowledge.
I have a 2011 T5 Caravelle Trendline 2.0 CAAC with H4 bulbs, and I’m keeping them for now.
I’ve replaced the BCM from 7H0937087H to 7H0937090D.
I’ve fitted an automatic headlight switch and RLS.
I followed the instructions for everything, but I’m still left with two problems I can’t seem to sort out.
I also had a problem with the high beams, but I sorted that out my own way using a relay.
Unfortunately, I got a bit lost at one point and I’m not entirely sure whether this thread is referring to 7H0937090D or 7E0
Problem 1 – The clock dimming function does not work in AUTO mode. When it is dark, the clocks are dark, only the hands are lit.
Problem 2 is rather unconventional.
I have an Android-based radio with a rear-view camera connected – not the factory-fitted one.
The camera is powered by the reversing light.
When the engine is off, the camera works. A few seconds after starting the engine, it shows ‘no signal’.
Generally, the radio is connected to the CAN bus and indicates that the car is in reverse gear.
As for the high beams, I had problems with the high beams not receiving power when set to the steady position. They worked in the flashing mode.
After connecting the relay as shown in the diagram, the full-beam headlights only worked in flashing mode and a ‘bulb burnt out’ error message appeared.
This suggests that the BCM supplies power to the ‘high beams’ pin 1.
I apologise for any linguistic errors, but I’m using a translator :)
Hi.
A brief summary:
-Before fixing the issues on your own, it would have been better to post an autoscan to try and resolve them via BCM coding after you had modified the wiring...
The BCM controls how your H4 headlights and the dimmer operate.
-There are two types of electrical setups for automatic headlights that can be retrofitted in PQ25* (pre-2015 and 2015 onwards), depending on the Max BCM type —7H0 or 7E0— one or both configurations might apply.
-In the PQ25 diagnosis it is absolutely essential to have details (with images if possible) of the before and after modifications.
-Non-OEM electrical installations (eg. RVC) can cause malfunctions... you should contact the device manufacturer or remove the unit if it is malfunctioning or was installed incorrectly. "Powering" the RVC from the reverse "signal" is a terrible idea.
Please post an autoscan or the BCM coding, perhaps we can see what is going on.
Kameleon1978
Thank you for replying to my post.
BCM coding
E8 A0 39 BA 2E 31 20 12 01 28 0E 50 7C AB 9E D4 14 90 41 0F 60 8D 20 D0 30 00 00 00 00 00
I’ve also got a scan, but as I mentioned, I’ll try to post it in subsequent posts. The anti-spam filter is flagging that I’m sharing contact details
As for the rear-view camera, when the reversing lights were powered directly from the sensor rather than from the BCM, everything worked. However, I couldn’t leave it like that because it was reporting a lighting fault. So, a cable from the BCM has been routed under the seat, just as described. T73b/12 to T10o/3.
The question is whether there’s a way to configure the system so that the BCM doesn’t control the reversing lights – or, more precisely, so that it doesn’t check whether the bulb is working properly. If so, I’ll revert to the previous power supply and the problem will be fixed.
The BCM is also connected via CAN to the instrument cluster, as described.
other connections:
low-beam headlights SB5a to T73a/2 SB27a to T73b/2
DRL – SC12a to T73b/3 SC14a to T73a/5
flash – SB28a to T73a/62
Question about the HB lights: can this module control them directly from the BCM, without relays, as everything seems to suggest it can?
And I have a question: what is the best place to connect the RLS power supply, as I’ve currently connected it to plus15?
Here is your current BCM coding without spaces between the hexadecimal-bytes, which is useful for verification using the appropriate software.
E8A039BA2E31201201280E507CAB9ED41490410F608D20D0300000000000
There are errors in the coding for the high beams and the dimmer.
If you followed the instructions below exactly for the H4 wiring installation:
- :arrow: viewtopic.php?p=528663#p528663
- :arrow: viewtopic.php?p=528735#p528735
This is the new BCM coding you should use:
E8A039BA2E31201201280E507CEB9ED41490610F608D24D1300000020000
and everything should work correctly,
Note: Before entering (copy-paste) this new BCM coding, undo any "custom" modifications or workarounds to avoid issues.
The electrical setup must be identical to the one described in the posts on page 4.
You can source the +30 power supply for the RLS from any fused +30 line. The RLS sensor has very low power consumption.
According to erWin, for the T5, it should come from the SC21 fuse.
Regarding the aftermarket RVC—and since we do not have the manufacturer's electrical installation instructions— you can experiment with the two bits shown in the image below to hopefully find the correct combination for your setup.🤷‍♂️
I wish you luck with this.
A standard, "normal" RVC needs one wire to connect to the reverse signal and another to power the camera unit itself... in addition to the video and ground connections. Any RVC that doesn't have this setup isn't a "normal" one. 😁
Kameleon1978
Ciclo, thank you, you’re the best. :D
The code you provided fixed the problems with backlighting and the high beams.
In byte 11, I unchecked bits 4 and 6, which fixed the problem with the reversing camera.
Unfortunately, my VCDS doesn’t have descriptions for all the bits – for example, bit 4 of byte 11 – and from byte 22 onwards, I’ve practically no bit descriptions at all… hence the problems with correct coding. :cry:
There’s also a minor detail which isn’t particularly significant, but it intrigues me. ‘Coming Home’ works correctly, i.e. semi-automatically. However, ‘Leaving Home’ didn’t work and still doesn’t.
I didn’t mention this earlier.
As suggested, I’ll connect the RLS according to the diagram provided, which will allow the windows to close automatically when it rains :)
Gracias, Amigo :)
The "Leaving Home" function will work once you have the RLS correctly connected.
The "Coming Home" function depends on your choice (via stalk), but the "Leaving Home" function depends on the RLS (via remote).
Dzięki wielkie, przyjacielu!
Cieszę się, że mogłem pomóc i że wszystko działa idealnie. Pozdrawiam! 🤗
Kameleon1978
Thanks,
Connecting the RLS to +30 will probably fix the problem.
Because at +15, the RLS doesn’t have a continuous power supply.
Gracias :)
Exactly. 👍
