ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Locked
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Golf7.5 Memory module that automatically deactivates the Start/Stop system by default.
To test, I tried to disable the Start-Stop system by coding with VCDS, but it doesn't work for my GW (AR version).
Related: viewtopic.php?p=603437#p603437
Following in the footsteps of my dear Doctor Patil :arrow: viewtopic.php?p=603430#p603430, I have purchased a wiring harness from Ali for Golf7.5 that integrates an electronic circuit/module that allows 'to the driver' to decide how the Start-Stop system works by default.
- Deactivates/shutdown the S/S system by default from the first ignition without having to press the S/S button.
- Or it keeps the S/S system working as it did from the factory.
- It remember the driver's last choice for the next ignition.
- There are no faults in the diagnosis.
Checking all wires in the Ali's wiring-harness, + some old info.
Video :arrow: :arrow: :arrow: https://www.youtube.com/embed/lNy6FtfH0 ... autoplay=1
1 to 1. Perfect! ✅✅✅
Installation and operation.
Same as this good YT video :arrow: https://www.youtube.com/watch?v=gydh1Aoi-xI 👍
More:
- G7.5 :arrow: https://www.youtube.com/watch?v=YCMpTXHpT3s 👍
- HumbleMechanic💎 :arrow: https://www.youtube.com/watch?v=ZcBfEQ8DaKg 👍
(Update, next post)
https://www.youtube.com/watch?v=-VHMoS903XI
Golf 7.5 Removing Ali's Start/Stop memory module.🤷‍♂️
At first everything seemed fine but after a few days of testing Ali's Start/Stop memory module and despite the my highly witty efforts 😅 to get 'this' Star/Stop memory module working on our Golf7.5 (with highly updated software), I have decided to remove this Start/Stop memory module because it randomly causes failures/malfunctions in the software of some control units.
They are loss of low priority messages, sometimes in some units and other times in other different units. For reference it is similar to what happens when changing the voltage value in the GW adaptation channel (Start_stop_voltage_limit, from 7.8v to 12v).
$10 = R.I.P. ... it was entertaining while it lasted. :lol:
Once the module has been removed and our Golf returned to an Original state, I take the car for a walk and then do a new Autoscan with the new VCDS Update.
Thursday,02,May,2024,19:52:31:32438
VCDS Version: 24.5.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: S-S MEM MODULE REMOVED.
Mileage: 54096km-33613mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 14 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 54096km-33613miles
14-Susp. Elect. -- Status: OK 0000
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000    CVN: 92B19492
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002.rod
   VCID: 290F00D8897EC92220D-807C
   VINID: 9E69EAAAA465A9B8000041051C011774D2
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA134202170477B060560CA2580562C84E26006A4733420F08A40AA430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DA7DF-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 AJ    HW: 5NA 907 044 AJ
   Component: AC Automat    H50 1301
   Revision: 20K03000    Serial number: 00000A00202735
   Coding: 000200032001100D1115004C0018542A
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 074B66607FAADF52169-8052
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H05 0010
   Serial number: AAE88B8400PAG0MUFU05
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 1513
   Serial number: 72007150025702 Dataset Number: V03935315NT 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 7DA704882D7685823C5-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043 0551
   Serial number:         180705074106
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SBY22M01D06H23M07S44
   Coding: 00A8DD
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY191251XZQ
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0313
   Serial number: 00002854456462182207
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000023032104400679
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0073
   Serial number: 000308417318277 Dataset Number: V03935313MC 0001
   Coding: 8271567841
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 58E9751CE29480AA4F3-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V310
   Coding: 2B0D67E35DFFC728979C81A4614006800000000000B9C00024
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 47CBA6603F2A1F52D69-8012
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 31051841350252 Dataset Number: V03935317XE 0001
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392FD09879DE79A250D-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ Dataset Number: V03935272MG 0001
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA92200D-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A532807E8C000801887A0F5401000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2B03FAD08382DB32D21-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5502
   Serial number: 09012020001767 Dataset Number: SET_FPA_MOD 0001
   Coding: 030900047F085700FB0002FE880F00010001070000000000000000000000
   GVL: 014E3C100000000040CC800000024C0000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFE80277A97922E9-802A
   Generator:
   Component: 5-01-14-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 E    HW: 1EA 959 442 E
   Component: MFL  H03 0219
   Serial number: 17036218123222100544
   Coding: AE2B00
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:| 2Qx-907-686-V2.clb
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000587514012
   Coding: 52A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000587481913
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000417322781  Dataset Number: V03935341UB 0001
   Coding: 00150220D000048000001000
   Shop #: WSC 00030 935 00052
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 52FD8734C468AAFAB17-8006
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935287HR 0001
   Coding: 931F0000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B121AC1E3CC4CA43B-8020
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0371
   Serial number: 01081930001280 Dataset Number: V03935292JZ 0001
   Coding: 00000005090016C206207F07620000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372BD6A04FCA6FD2A69-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000423015792  Dataset Number: V03935341UE 0001
   Coding: 00150220DE00048000001000
   Shop #: WSC 00030 935 00034
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 51FF8838C16ED1E288D-8004
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0879
   Serial number:                Dataset Number: 5G0CV1v____ 0001
   Coding: 02731001FF0000004111010140880A231F0507E401200400CF
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323DE7B4A4A88AFA917-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 ET    HW: -----------
   Component: ECE AS 24/25  --- 2210
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 30000000250801 Dataset Number: RDKS_TinyQ_ 1017
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3829D59C42D460AAAF3-806C
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: V03935246NT 0001
   Coding: 01040201C600201F000060
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320004213340 Dataset Number: V03935349WG 0001
   Coding: 0000018811EEC028889F2C801030004400438000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: 3537DCA855C69DC2B45-8060
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 Z001
   Serial number: 181027201414
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X_003_VW37.rod
   VCID: 6A8D3FD44CF8023AE97-803E
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:49, VBatt start/end: 13.3V/13.4V)-----------
Testing the height of 'my' DCC damping.
Test on a standard pedestrian sidewalk height.
I still have to do another 1000kms for the front shock absorbers/struts to lower a little more. (5 to 10mm)
It's just a test, I never invade pedestrian space. :lol:
https://www.youtube.com/watch?v=B8j4mn4eF-c&t=23s
Golf 7.5. Left rear level/height sensor/sender replacement (G76). 5Q0907503 (5Q0512521E).
5Q0907503 is the level sensor - used for the front or rear axles -.
5Q0512521E is the parts assembly for a rear torsion axle.
Since I had the happy idea 🤭 of cleaning the rear axle with high-pressure water jet - when I installed the new blue rear brake calipers - ...
... I have been randomly experiencing a malfunction of the left rear level sensor, mechanical failure according to diagnosis.
Tuesday,07,May,2024,08:50:58:32438
www.Ross-Tech.com
                Address 14: Susp. Elect.       Labels: 5Q0-907-376.clb
Control Module Part Number: 5Q0 907 376 C    HW: 5Q0 907 376 A
  Component and/or Version: DAEMPFUNGS-SG H17 0130
           Software Coding:
            Work Shop Code:
              ASAM Dataset: EV_DRCONTITEMIC 001019 (VW37)
1 Fault Found:
198147 - Rear Left Ride-Height Sensor
          C1036 07 [00001000] - Mechanical Failure
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 54139 km
                    Date: 2024.05.05
                    Time: 14:37:24
By doing a new ignition cycle, the fault disappears and everything works fine again for a while until the Light Assist and AFS system (cornering lights) malfunction warnings are displayed on the AID and info system again.
I have replaced the sensor for a new one and everything works correctly now, the fault has not reappeared.👌
Stainless steel bolts, same as those factory installed on the sensor.
I also installed new M5 stainless steel rivet nuts of better quality than the original ones.
A meaningless look at the other side...🤷‍♂️ everything seems fine after 1500Km on our magic carpet. :lol:
This is the rear level sensor that was causing the problem:
- Dirty.
- Clean (for inspection).
It's the one I installed when installing the 8IU Matrix LED headlights. viewtopic.php?p=578709#p578709, viewtopic.php?p=576562#p576562
Inspection:
The sensor shaft/rotor has no axial play, but it has a small/micrometric radial play/clearance, which seems to be enough for its malfunction.
ciclo 'the element' ... :lol:
I will never do a 'vehement' rear axle cleaning again.
https://www.youtube.com/watch?v=Xfc21g0Sf38&t=22s
Golf 7.5 (3Q0) New Start/Stop memory module.
Previously (1, image below): viewtopic.php?p=604231#p604231 , viewtopic.php?p=604266#p604266
I have purchased and installed a New Memory Module for the Start-Stop button (2, image above), which after a few days of testing everything seems to work as it should for our Golf7.5 (3Q0 GW, AR version). I still have it under long-term testing.
:arrow: https://www.aliexpress.us/item/32568044 ... 4itemAdapt
At the moment no fault has been reported in the diagnosis.
No more having to press the SS button.😊
💥NEW uncut video💥: :arrow: :arrow: :arrow: https://www.youtube.com/embed/c70VD_IJ2 ... autoplay=1
Wednesday,15,May,2024,13:15:00:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: NEW SS MEM MODULE.
Mileage: 54880km-34100mi   Repair Order:
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 54880km-34100miles
Readiness: 1110 0001
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Data carrier:
End----------(Elapsed Time: 01:48, VBatt start/end: 14.2V/14.2V)-----------
The first Start-Stop memory module I bought viewtopic.php?p=604231#p604231 was poorly wired, or rather it was horribly wired, because it had the rows of wires interchanged and in addition it used the positive signal +15 (T10/10) as a reference (instead of 58d). 🤦‍♂️
A real disaster that I had to correct to make it 'work'.
Golf 7.5. New Original 18" wheel. 5Q0601027BT 03C.
...for the spare wheel compartment.
Since I installed the 312mm front brakes I need a 16" or 'higher' spare wheel for the front axle wheels in case I have any issues/incident with the front wheels... or 'maintenance work'.
To avoid any type of dependency (towing, etc...) I have acquired a new original 18" space-saving emergency wheel to carry along with the Helix Sound System and the Tire Mobility System in the spare wheel compartment.
Original 'Linglong' tyre.
From Golf8.🤷‍♂️
19.5cm, 7.7in.
https://www.youtube.com/watch?v=MLsqTfX0OiE
Golf 7.5 Space-saving emergency-spare wheel + Helix Sound System.
Previous info :arrow: viewtopic.php?p=604474#p604474
How-to... Video :arrow: :arrow: :arrow: https://www.youtube.com/embed/r0ZSHdkuN ... autoplay=1 🎧 🔊 🤭
Edit...
🔥Bonus🔥
Notable improvement in overall sound quality.
I can only say that the Helix Subwoofer on top of this spare wheel is quite a bit better than without this spare wheel... now it's even nicer how well defined and crisp the bass feels.
BTW, I finally programmed my Helix SS to channel/program 97 (instead of 57), I love it. 💘
viewtopic.php?p=579694#p579694 , viewtopic.php?p=579929#p579929
https://www.youtube.com/watch?v=jFcLaZ95QcI
Golf 7.5 Geometry. Wheel alignment.
After completing 2000km -according to erWin- with the new DCC struts/shock absorbers viewtopic.php?p=603903#p603903, all the parameters/angles are within tolerances -in green- according to the wheel alignment platform/computer of my usual trusted wheel shop. Same parameters as in erWin.
I observe on the workshop computer that the parameters on the front axle -in green- tend to be slightly divergent/toe-out for the toe angle, but I prefer that the operator not make any type of adjustment in the steering rods because the car goes/running straight, there is no uneven wear on the tread of the wheels, braking at any speed is perfect/straight, and the steering wheel self-aligns in the right way after the turns and is centered/straight.
The angles can even vary/change slightly by simply tightening the steering rod nuts, in fact this is what usually happens.
If any adjustment is necessary in the wheel alignment angles, it is necessary to make/check the basic setting of the steering angle sensor G85 if the adjustment is on the front axle, and the basic setting of the ACC radar and the A5 camera if it's on the rear axle.
I recommend reading erWin to meet the prerequisites for checking geometry. :arrow: viewtopic.php?p=597574#p597574
VCDS Autoscan.
Sunday,26,May,2024,09:24:28:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: GEOMETRY. WHEEL ALIGNMENT. OK!
Mileage: 55007km-34179mi   Repair Order:
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 55007km-34179miles
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Data carrier:
End----------(Elapsed Time: 01:50, VBatt start/end: 14.4V/14.4V)-----------
Golf7.5. Climatronic. How to align the receptacle of a climatronic/aircon/heating flap control motor with the flap actuator arm.
When installing a flap control motor it is necessary to align the control motor receptacle (1) with the flap actuator arm (2), erWin indicates a procedure, which involves turning on the ignition, but this does not suit me...
With a 9 volt battery can be easily aligned the position of the receptacle.
Video :arrow: :arrow: :arrow: https://www.youtube.com/watch?v=AfK_LLEbXgg
One of the flap control motors in our Golf has started making a weird sound/noise, it can be heard in this video :arrow: from 0:50 to 0:53., it doesn't always happen, but it happens with high frequency.
I have been investigating with an endoscope and VCDS/VAS output tests, but the observations are inconclusive... or it is the defroster flap control motor V107 or the front air distribution flap control motor V426... It may also be the set of gears that are driven by the V426.🤷‍♂️
To try to find out and fix this weird sound/noise, I will start by first removing V107...
Golf 7.5 'Identification' of the heater/air conditioning unit.
Note: In the SelfStudyProgram 513 is wrong.🤷‍♂️
Unit in our Golf. Casual image of when I installed the matrix LED headlights.
Images of a removed Valeo unit.
Air distribution housing.
Doing more tests, I have continued to try to find out where the weird sound is coming from, and it seems to be coming from the 'light green rubber' on the defrost flap.
I will post the info once I edit the videos and images...
https://www.youtube.com/watch?v=pSE6hUrkVKE 😊
Golf 7.5 Climatronic. Defrost flap noise. Fresh air vs Hot air.
Tests / observations / investigations.
Endoscope.
Video of the front air distribution flap working, taken with the endoscope.
:arrow: :arrow: :arrow: https://www.youtube.com/embed/dDPZxhga- ... autoplay=1
The endoscope does not have a microphone and the images do not have good resolution because the endoscope only offers good resolution near the object to be inspected. However this video was very helpful because when the light green rubber surrounding the front air distribution flap sits in place, it makes exactly the same noise as the defrost air flap, although in this case it is only when the front air distribution flap sits, not all rotation.
I do not put the endoscope through the windshield defrosting holes, there is a high probability that it will get stuck due to the moderate rigidity of the camera wire... and that doesn't suit me. :lol:
Instead, I record the weird sound while I touch the defrost air flap buttons and other buttons in the following video.
:arrow: :arrow: :arrow: https://www.youtube.com/embed/S4hYeKMqw ... autoplay=1
The noise is not so loud in real life, the camera's microphone slightly amplifies this sound, and as seen in the video, with the hot air (HI) the noise is mitigated.
Due to these observations, I conclude that the noise comes from the light green rubber that surrounds the defrost air flap and which in turn is present in the axis of rotation of the flap. Red circles in the following image.
These are my first findings, but until the flap control motors V426 and V107 are removed I will not be able to say exactly the cause of the noise.
The idea to try to fix this noise will be to use pure Vaseline wherever it is possible to reach... (I will have to study the possible ointments).
I will report what is new as I remove parts, there are many, it will take me some time.
Edit..
- The air conditioning/climatronic system in our Golf has always worked correctly, there are no faults detected in the diagnosis (see last Autoscan posted on this page).
- I have always used the highest quality active carbon air filters with the high filtration capacity for the air conditioning systems of my cars, renewed at each Service/Inspection (earlier than recommended).
- Before starting removing parts, I am going to do a few sessions with the hot air (HI) selecting the position of the defrosting air flap to try to get the light green rubber on defrost flap to acquire another 'structure, texture, consistency', ...and see if this way miraculously it stops making the noise...😁
Golf 7.5. Climatronic. Defrost air flap noise solved* (95%).
Previously (the noise): :arrow: viewtopic.php?p=604572#p604572
During these last few days, I have been doing a couple of sessions with the Hot air every day, between 5 to 10 minutes...
Video :arrow: :arrow: :arrow: https://www.youtube.com/embed/u6yQNlWSW ... autoplay=1
Miraculously, the noise has almost completely disappeared, although it can still be heard when the rubber of defrost air flap sits... presumably a couple more sessions with the Hot air will be enough for the noise to disappear in its entirety. 🧙‍♂️
My final conclusion is that due to the environmental conditions of the last few weeks/months (spring/summer rains), and perhaps the conditions in which I retrofitted the DCC system... , some moisture condensed in the air distribution box.
Can it happen again? of course, but I will already know that the noise is irrelevant... you already know, we get older and we acquire 'experience'.🤷‍♂️
Edit... June 7, 2024.
After a couple of days and a new couple of sessions with hot air, the noise from the defrosting air flap has disappeared definitively, 100%.
Now it seems like we are driving a luxury car... EVERYTHING works like a charm without any type of noise even on bumpy/rough roads.
Many sacrifices to achieve it...😁
By the way, in case you are interested, I can now confirm that the 2nd Start/Stop memory module that I installed (info on this page) also works like a charm, no type of setback in operation or diagnosis. Works great even with FPA in ECO Mode, the comfort it provides is Great!🤸‍♂️
Although I have planned a new retrofit on our Golf, that I will report in the following posts once I have all the parts, now I will be more active in the thread of my 6R R-line to install the Lane Change (BSD). :arrow: viewtopic.php?p=604640#p604640
Mirror caps built for the Golf 7/7.5 with Passat B8 warning lights. 12v 0.7w.
Due to an interesting offer plus the summer 'promotion', I purchased these side assist warning lights.
They look great, they are almost perfect 😄, I hope to have time to install/connect them over the weekend.
Video with the current/original ones (2Q0 radars).
:arrow: :arrow: :arrow: https://www.youtube.com/embed/YDjWrqJ-_ ... autoplay=1
Golf 7.5. Passat B8 Side Assist warning lights on mirror covers/caps. Big improvement! Video.
Some preliminary information in the previous post (video, originals).
Some images of the installation process:
The wiring colors vary slightly if your Side Assist system is from the factory. You can consult diagrams in this thread (e.g. viewtopic.php?p=572297#p572297 , viewtopic.php?p=592068#p592068 ).
I recommend that under no circumstances cut, lose or throw away the original white mirror connector, it is a tiny diamond...💎
I recommend having both warning lights connected, the original (below) and the new one (above).😉
👌 Perfect? No, the following.😄
Video:
:arrow: :arrow: :arrow: https://www.youtube.com/embed/JDMYPqdOg ... autoplay=1
Note:
1- Are any diagnostic errors caused by having the four Side Assist warning lights connected? NO, the watts consumed do not affect its operation. All LEDs are 12 volts.
2- Our brain receives a lot of data while we drive, and knowing that other vehicles have the Side Assist system because the LED in their mirrors lights up is relevant information for other drivers. Personally, it helps me make better decisions in my driving style (it's one more piece of information, just that).
This is why I recommend leaving the mirror's original LEDs connected.
3- The Passat B8's warning lights in the mirror caps are clearly visible even if the sun shines directly on them, I think the system takes data from the light sensor (RLHS) because they are perfectly visible in any conditions.👌
Our Golf has 2Q0 radars installed and currently have these parameters loaded. Now our Side Assist 'Plus' is 'Double Plus' 😅, it works super wonderfully.
Autoscan.
Friday,21,June,2024,12:18:27:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: + PB8SAWL OK!
Mileage: 55341km-34387mi   Repair Order:
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 55341km-34387miles
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 090000
   Data carrier:
End----------(Elapsed Time: 01:47, VBatt start/end: 12.8V/12.8V)-----------
Golf7.5. Exterior door handles with light.
Getting ready to go back to school after summer break.😊
https://www.youtube.com/watch?v=FjmEwQ3v6O0&t=42s
Locked
