Locked
Gannu wrote:Ciclo, need some help. What is the easiest way for routing a thin wire through the firewall/bulkhead? I saw the rubber grommet for the hood release cable but it is located a bit inside and may have to remove the wipers and the plastic trim to gain access. Is there another point?
Thanks in advance!
On the opposite side.
You can see pictures in this guide: https://drive.google.com/file/d/0B2nv91 ... ZrU0k/view
Remember that my R-line is LHD.
In any case, to remove the wipers and the trim is not difficult.
(In the links on the left of this website you have the process)
http://workshop-manuals.com/volkswagen/ ... iper_arms/
http://workshop-manuals.com/volkswagen/ ... /removing/
Similar process (in Spanish :D ) :
This is right place (a bit more difficult):
Thank you ciclo for this effort. I will try it and report back
Gannu
Drives: 6R 1.6 TDI 105 PS
Post by Gannu »
Thank you ciclo. I think there might be a dummy hole with a grommet on the co-driver side as well. Let me check.
Or will use a pointed object like a needle and insert the cable through the hood release grommet from the inside to the engine bay side. Will keep you posted. Thank you once again!
I am planning to retrofit the windshield wiper fluid low-level sensor on the plastic tank.
Ok, thanks to you for your excellents DIY in your forum (team-bhp). :wink:
sambir
Drives: Polo 6R GTD (140HP 300NM)
Post by sambir »
@ciclo
Hi im active in the dutch Mypolo community.
I was wondering if you could help me out with my retrofit OEM xenon headlights.
I opened a topic about the led's in my headlights. I was looking for a solution to brighten the led DRL like original when the lightswitch is at 0 and dim when at 1 or 2.
I have the bcm which ends with 87b (polo is from 2009).
Everything works, leds, high and low beam but the led light do not dim or brighten like original. Is this due to the BCM or can it be fixed with propper coding?
This is my topic and my comment with the headlights at 0, 1 and 2.
http://www.mypolo.nl/xenforo/index.php? ... ost-138262
By the way this is my longcode at the moment:
3CB02BBF48F32400933800003C2B1FD8D08067FF608400002000
Any help is appreciated :)
Hi sambir
Your BCM can not control DRL because it has no pins needed for this. With BCM encodings you can not do anything about it.
The encodings are very different depending on the equipment from factory (drl, fog lights, static cornering light, etc...), so it makes no sense to compare one BCM over others. The electrical installation of Polo6R with BCM 087 is different from those Polo Bluemotion with BCM 088 or others 089x, 090x.
All you can do is modify the electrical installation depending on the equipment you have in your Polo. You need ElsaWin (diagrams) to configure your electrical installation as needed.
It is possible to run everything as factory, but it is too long to explain and I do not have time for this. I'm sorry sincerely.
Right now I'm very busy. Image I hope you understand me. :wink:
iichel wrote:Thank you ciclo for this effort. I will try it and report back
OKay :wink:
sambir
Post by sambir »
Ciclo. Thanks for your reply. I guess i need to accept how it works for now.
Next step is to find a professional which can do the wiring to let the DRL work as it should and also do the wiring for the cornering lights, so they work within the headlights instead of the bumper.
I thought maybe it is just a coding thing :P
As promised:
Gannu
Post by Gannu »
ciclo wrote:Ok, thanks to you for your excellents DIY in your forum (team-bhp). :wink:
Thanks a lot to you too for this informative thread ciclo! The glovebox light mod was inspired by the one you did. :)
Unfortunately for us, we do not have many competent garages here so the only way out is to refer to the VW workshop manuals and DIYs posted by others and get it done with the help of a friend.
I have a doubt regarding the 32 pin connector that goes to the instrument cluster. I believe the windshield wiper fluid tank low-level sensor's cable goes into pin #17 but I can't find a pinout or wiring diagram for this. Checked many websites including ELSAWIN but couldn't find one. Can you please help me out with this?
T32/17
You're right Gannu.
As you can see sensors share a common earth. T32/20
Gannu
Post by Gannu »
ciclo wrote:T32/17
You're right Gannu.
Thanks a bunch brother! Much appreciated! :mrgreen:
iichel wrote:As promised:
Excellent! 8)
You have done many good mods on your Polo. Authentic R-line (only lack a few details).
Still have to install the light sensor and then contact me, I have a surprise for you. Remember it.
Thanks for sharing the pic. Image
sambir wrote:Ciclo. Thanks for your reply. I guess i need to accept how it works for now.
Try this installation:
For your DRL with harnes 10 to 14 pins (BCM 087)
Remove the pin 10 of connectors T14. Isolate.
Remove the pin 3 of connector T17 light switch. Isolate.
Wire from slot 3 switch light connector----> fuse (5amp * ) ----> two wires directly to T14 (connectors) slots 10 , for both of xenon headlights.
T17/3-----FUSE-----T14a/10 and T14b/10
This way your DRL will work in the "0" position light switch.
* I do not know which is the power consumption of LEDs for DRL, but I think that is enough with 5amp fuse.
If you know the real consumption of LEDs for DRL, multiply it by three and that's the fuse value. (multimeter)
sambir
Post by sambir »
Thanks for your reply mate :) The DRL already works in all cases. I only want it to work in FULL power mode when the switch is at "0".
Currenlty the DRL's work at dim modus in all cases, 0, 1 and 2.
Locked
