Thanks for that message. Also when I did finish I saved a full autoscan.. Will upload in 10-20 minutes. I'm using my phone.
Polo 6R ABS CODING
- habib_123
- Drives: Polo 6R 2012 1.2TDI RHD
Re: Polo 6R ABS CODING
Hi Ciclo.
- habib_123
Here is the full Auto-Scan:
I hope this entire thread helps someone else and thank you to everyone for helping!!!
Monday,23,May,2016,19:48:05:33719
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
http://www.Ross-Tech.com
VIN: WVWZZZ6RZCU015153 License Plate:
Gateway Installation List: 6N0 909 901
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Monday,23,May,2016,20:36:11:33719
VIN: WVWZZZ6RZCU015153 License Plate: PJ61KHG
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56 77
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 A HW: 03P 907 425 A
Component: R3 1.2 DCM3.7 H06 8411
Revision: 11002001 Serial number:
Coding: 00114010002500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TDI03103P906021A 001010
ROD: EV_ECM12TDI03103P906021.rod
VCID: 26438C535964BA0E24-8072
3 Faults Found:
14126 - Exhaust Gas Temperature Sensor; B1 S3
P242A 00 [040] - Malfunction
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 47
Mileage: 48990 km
Date: 2016.05.23
Time: 19:47:20
16973 - Exhaust Gas Temperature Sensor; B1 S3
P242A 00 [168] - Malfunction
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 2
Mileage: 48990 km
Date: 2016.05.23
Time: 19:47:25
15899 - Fuel Temp. Sensor A (G81)
P0182 00 [040] - Short to GND
Fault Priority: 2
Fault Frequency: 2
Mileage: 48990 km
Date: 2016.05.23
Time: 20:10:31
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230224E3416E00B7C42624E782D400921200
Shop #: WSC 31414 790 31414
VCID: 071DE1D7B2AE83063F-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326B60036DACD6AEB8-8066
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0251
Revision: BF046001 Serial number: 0434 204112918
Coding: 3DB02BBF0821200092380E006D6B0CD80080412F60860000200000000000
Shop #: WSC 12345 123 12345
VCID: 45812BDFCC2251160D-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 820000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H11 0012
Revision: -------- Serial number: 47301119601229
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3D71433FACF219D655-8068
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00RE3X0
Coding: 003237
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4A9B18E3ED3CBE6EE0-801E
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405H0N3MK9GQ5
Crash sensor for side airbag; front passenger side:
Serial number: 3585HRB405H0IRE2D8P.
Crash sensor for side airbag; rear; driver side:
Serial number: 3515RRB405P0KOIAK09%
Crash sensor for side airbag; rear; passenger side:
Serial number: 3525RRB40650KOIAFH4V
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 970 HW: 6R0 920 970
Component: KOMBI H07 0304
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 73E5A507DA369FA673-8026
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0251
Revision: BF046001
Coding: 002300
VCID: 70EFAA0BA320A4BE8E-8024
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 48990 km
Time Indication: 0
Date: 2016.05.23
Time: 19:51:24
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H07 0304
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADBB8638DFC5E6EC0-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660416968
Coding: 010000
VCID: 2959876F407A957609-807C
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H10 5274
Revision: AB001001 Serial number: VWZ6Z7N7256263
Coding: 00000440000000A10000
VCID: 3B754D27BAE617E66B-806E
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V12 8195
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F6D6977EA9EFB46D7-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0982
Revision: -------- Serial number: 35502105200652
Coding: 020000000100000000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_SE36.rod
VCID: 2447965B2F58481E3A-8070
2 Faults Found:
9458451 - Cellular Antenna
B1053 13 [009] - Open Circuit
Fault Priority: 4
Fault Frequency: 1
Reset counter: 62
Mileage: 48990 km
Date: 2016.05.23
Time: 19:47:20
9458193 - Control Module for Cellular Telephone
B1052 14 [009] - Open or Short to Ground
Fault Priority: 4
Fault Frequency: 1
Reset counter: 62
Mileage: 48990 km
Date: 2016.05.23
Time: 19:47:20
End-------------------------(Elapsed Time: 02:45)--------------------------
3 Faults Found:
Fault Priority: 2
Fault Frequency: 47
Mileage: 48990 km
Date: 2016.05.23
Time: 19:47:20
Fault Priority: 2
Fault Frequency: 2
Mileage: 48990 km
Date: 2016.05.23
Time: 19:47:25
Fault Priority: 2
Fault Frequency: 2
Mileage: 48990 km
Date: 2016.05.23
Time: 20:10:31
Revision: --------
Revision: 0002S 02
Coding: 18BC30
Coding: 08BC30
Coding: 820000
Coding: 08BC32
Coding: 08BC32
Coding: 308001
Coding: 003237
Coding: 140A00
Revision: BF046001
Coding: 002300
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 48990 km
Time Indication: 0
Date: 2016.05.23
Time: 19:51:24
Serial number:
Coding: 010000
Coding: 11230
Shop #: WSC 31414
2 Faults Found:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 62
Mileage: 48990 km
Date: 2016.05.23
Time: 19:47:20
Fault Priority: 4
Fault Frequency: 1
Reset counter: 62
Mileage: 48990 km
Date: 2016.05.23
Time: 19:47:20
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Re: R: RE: Re: Polo 6R ABS CODING
Thank you for you explanation, ciclo!ciclo wrote:There seems to be a calculator (I no have), the calculations I did for the coding to ABS unit (6R) from habib_123 are based on data collection from other Polo 6R, and they have no scientific basis [img]http://czestochowaforum.pl/images/smiles/caveman.gif[/img] (as has been seen in this thread).
I can only calculate Bytes that they matching with the VIN. I would like to say how this part is done, but this is not convenient for security reasons and data protection (thinking on respect for others who do not want to publish the VIN). Otherwise, I already would have said.![]()
...therefore Lady luck favored to habib_123.[img]http://www.cool-smileys.com/images/47.gif[/img] (if possible for you, a full autoscan would be perfect to finish)
I think that this thread/topic has been very interesting.
I would like to find the long-coding for my 288mm front brakes.
Can I ask here in this topic? Or do I have to open a new one?
Inviato dal mio LG-D802
- habib_123
Its fine. You might as well as carry on with the thread as it's already about ABS coding.
As ciclo said:Jay-Jay wrote:Thank you for you explanation, ciclo!ciclo wrote:There seems to be a calculator (I no have), the calculations I did for the coding to ABS unit (6R) from habib_123 are based on data collection from other Polo 6R, and they have no scientific basis [img]http://czestochowaforum.pl/images/smiles/caveman.gif[/img] (as has been seen in this thread).
With 288mm on the front, 232mm on the rear, coding should be:
210248E3217200BA842912E984D800401700
- Jay-Jay
Re: R: Polo 6R ABS CODING
I've already tried that long-coding, but it's rejected.
If you need it, I can post a complete autoscan of my car.
Basically you need to change byte 2 to '48' and byte 10 to '12'
- Jay-Jay
I tried also to modify only those bytes, with the same result: coding rejected.
I tried also to modify only byte 2 to "48": no success.
The same if I try to modify only the byte 10 to "12".
It seems like my ABS unit doesn't accept any modification or this specific modification for these two bytes.
What else could I try?
Thanks for the autoscan.habib_123 wrote:Hi Ciclo.
But, I don't understand, you used this coding: viewtopic.php?f=56&t=68290&start=60#p510381
230224E3416E00B7C42624E782D400821300
and the ABS unit accepts this coding: viewtopic.php?f=56&t=68290&start=75#p510394
230224E3416E00B7C42624E782D400921200 without hill-hold control.
82/92
http://forums.ross-tech.com/showthread. ... #post11646Jay-Jay wrote:I tried also to modify only those bytes, with the same result: coding rejected.
Address 01: Engine (J623-CBZB)
just like my R-line ... I remember that some time ago also tried to modify some of those bytes without success.
Your coding (NEtech) is correct (VIN, etc), but others Polo 6R with those front discs (288mm) have the coding 48/12 from factory.
It is difficult to recommend something else with the info available.
- Jay-Jay
I would like to understand what effects has a coding specific for 288mm front brakes.
Will brakes be stronger? Will the brake power be redistributed better between fron and rear calipers?
Will the ABS kick in earlier or later?
- Jay-Jay
Hi everybody,
is there someone on here who is able to calculate the right coding for ABS/ESP Bosch 8.2i depending on the brake size?
When I press hard the brake pedal, the ABS kicks -in too early in my opinion.
I believe it has to do with redistribution of brake pressure between front and rear calipers.
I have this problem since I upgraded the front brakes from ATE FS-III 256mm to Lucas 288mm and the problem remained even now that I installed the ATE FN3 288mm front calipers.
Yes, post the old coding please
- Jay-Jay
This is the coding I have now:
this coding is already for 288mm front / 232 rear discs
