Polo 6R 2016 Mod.
BlueEyesGT
Drives: Polo 1.2 TSi
Re: Polo 6R 2016 Mod.
Post by BlueEyesGT »
rdasadia wrote: Mon Aug 28, 2017 8:46 pm
2) for the headlight washer retrofit from the past posts got the below parta details which needs to be procured.
- 6R0 955 978 nozzles. ( Can someone advise where they can be procured from)
- wire harness (https://www.kufatec.de/shop/en/Volkswag ... VW-Polo-6R)
However could not gather from where to find the pumps(does it use the same pump that of windshield washer), and the hoses and connection diagram.
Here is the 6C headlight washer retrofit in progress,this might help.
viewtopic.php?t=70119
rdasadia
Drives: Polo GT 1.2TSI DSG 6R 2016
Post by rdasadia »
iichel wrote: Mon Aug 28, 2017 9:14 pm There is a thread for headlight washer retrofit somewhere (or maybe 6R bi xenon retrofit). There is a list of parts, including the washer system.
I'm not aware of any retrofit kit or topic but it shouldn't be too difficult to make a wiring set for the new roof lining.
Thanks iichel. The kit I have got has only the visors which can support vanity light. It does not have the lights or the wiring details. I need to still procure the lights for which I dont have the part no. Also I can make the wiring if only I knew the connections. I mean I am sure the vanity lights wont work via BCM. But which fuse, etc
rdasadia wrote: Mon Aug 28, 2017 8:46 pm So most recently got complete GTI body kit upgrade including bumpers (front & back), side skirts, interior "black" panels, etc
However require help for below two retrofits.
1) Sun visors with vanity light
2) front bumpers are with headlight washer space.
1) For sun visors tried to search for retrofit details but couldn't find any. Would like to know part no. of the light which is fixed on the roof and wiring details of this light and connector coming out of the visors.
1)
2)
https://www.google.es/search?q=6R0+955+ ... 17&bih=708
Dealer?
Ask to firegrafik, CNK...
The relay adapter shown on the wiring picture (kufatec) does not fit into your Polo 6R 2016 relays holder. Ask before you buy.
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
Maybe it will be helpful mine reports of retrofit used 6C bumper with PDC, headlights washers.
1)Partlists
https://www.drive2.ru/l/7796984/
2)Bumper repainting and installation
https://www.drive2.ru/l/10003797/
3) Headlights washers activation
https://www.drive2.ru/l/10250966/
4) Full 8k Park distance control
https://www.drive2.ru/l/452708245769815793/
in addition to firegrafik's excellent post, this is what i was referring to: viewtopic.php?t=64417&start=30
iichel wrote: Tue Aug 29, 2017 8:03 am ... firegrafik's excellent post...
+1
rdasadia
Post by rdasadia »
Getting ready to install AFS. Have already ordered all other parts. Just for the AFS module one of the IIchel's post shows the part no. as 6R0 907 357. However there are many firmware versions avaliable as below.
https://i.imgur.com/rsEAqc1.jpg
Any specific which I need to buy.
The AFS module you should buy depends on the rear leveling sensor and the bixenon headlights you have purchased. Also of other factors like the brakes system installed (ABS, ESP).
The AFS module works in conjunction with the rear leveling sensor and the headlight range control motor that is inside the bixenon headlights.
Please tell me the bixenon headlights references (including date of manufacture), also the rear leveling sensor reference (including date of manufacture).
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
ciclo wrote:The AFS module you should buy depends on the rear leveling sensor and the bixenon headlights you have purchased. Also of other factors like the brakes system installed (ABS, ESP).
oh wow. i didnt know that. so is there any issue if i buy the complete set from kufatec and buy bixenon somewhere else?
The usual thing is that the parts are compatible ... but it always must be checked in the ETKA. Problems arise when people buy cheap, repaired or second-hand parts, something very common.
rdasadia
Post by rdasadia »
@ciclo
I have just installed the MIB Discover Media Headunit in my Polo along with a 8K OPS which has the moving lines interface.
But the ops is not working.
The most important issue is that I cannot get maps working on the unit. Can you help how to put india map on the unit.
I tried with Discover Care Software but no luck here.
Even Android auto won't work on the unit.
Sunday,01,July,2018,16:27:02:58997
VCDS Version: 18.5.2.0 (x64)  HEX-NET CB: 0.4427.4
Data version: 20180518 DS291.0
www.Ross-Tech.com
VIN: MEXA16604GT072590   License Plate: ROHAN
Mileage: 18620km-11569mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 56 5F 65 77
VIN: MEXA16604GT072590   Mileage: 18620km-11569miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number: 00000000000000
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6D9229D8BC778B2380-8038
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6561
   Revision: 00043014    Serial number: CU501511017434
   Coding: 0000020
   Shop #: WSC 57779 002 1048576
   VCID: 3A38D28475B9EC9B55-806E
   Part No SW: 6R0 907 379 BH    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2463422A03C2461924724251C0800908
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0542717884C7536368-8050
   Serial number: 05061504651234
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB01E94E11100BB29-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41CAA568D86FBF4314-8014
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 352161294
   Coding: 3AB02BB848B30000013806917CEB9E90BAC067FF600D30C1200000030000
   Shop #: WSC 51200 002 104857
   VCID: 2A18E2C445195C1B25-807E
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 271115 03  37  0059
   Coding: 0730DD
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  020 2551
   Serial number: 13102848151112221545
   Coding: 050008
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  020 2551
   Serial number: 13202849151112235703
   Coding: 050008
   Subsystem 4 - Part No SW: 13 202 849 15    HW: 132 028 491 51
   Component: RLS 271115 03  37  1122
   Serial number: ˇ132028491511122357
   Coding: 353730
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  019 1552
   Serial number: 13202728151109234823
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  019 1552
   Serial number: 13202729151110091329
   Coding: 020000
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Time Indication: 0
                    Date: 2018.07.01
                    Time: 16:23:46
02746 - Bulb for Daytime Running Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Time Indication: 0
                    Date: 2018.07.01
                    Time: 16:23:46
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 64931721802185
   Coding: 0000000000
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 373ECBB08EABF1F3AA-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
2 Faults Found:
13636352 - ROD - Unknown Error Code
          - 00 [009]
          [Steuerger‰t f¸r Reifendruck¸berwachung: keine Kommunikation]
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:48
12718592 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:48
   Revision: --------    Serial number: 003GW012EG31
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 49DABD48E85F7703CC-801C
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 141E01
   Shop #: WSC 12345 123 12345
   VCID: 47DEBB70FE4B8173DA-8012
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002300
   VCID: 689C58CC9B95AE0BF3-803C
   Component: IMMO          H05 0805
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9822C48D999C1BE5-803E
Address 37: Navigation
Cannot be reached
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 41CAA568D06FBF4314-8014
Address 56: Radio
Cannot be reached
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5C0 035 682 E    HW: 5C0 035 682 E
   Component: MU-S-N-CN     H31 0359
   Serial number: VWZAZ2S5285330
   Coding: 02140105FF00000011150001001028001F0100D400200100C6
   Shop #: WSC 19460 666 12345
   ROD: N/A
   VCID: 250211F82407736308-8070
No ASAM data for: "EV_MUStd4CTSAT" (VW25)
9 Faults Found:
1555 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:47
15360256 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:48
2565 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:48
1564 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:47
7178 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:50
7194 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:50
0001 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:48
0003 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:48
1637 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 228
                    Mileage: 18629 km
                    Date: 2018.07.01
                    Time: 16:23:48
   Serial number: 30000000054715
   ROD: EV_RDKBERU30_005.rod
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:20, VBatt start/end: 13.5V/13.5V)-----------
Wrong PDC ECU... you need 7E0 919 475 L (for example)
I think you should also deselect 37 and 56 and 77 from the gateway, to replace them with 5F (already selected).
rdasadia
Post by rdasadia »
Thank you @iichel
But the Chinese seller said it will work perfectly with 6R polo and said they have tested it in china.
Paid a lot for this module and the headunit.
Please help make them work.
I'm afraid it isn't possible. You'll need a different PDC module.
rdasadia
Post by rdasadia »
What about the Headunit,
Android Auto and CarPlay is not working.
Also how do I make navigation work on it.
The unit came with china maps and that worked perfectly but when I tried to load india maps its not reading them.
Also the unit has a cracked firmware to bypass the component protection.
