RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
How to wire the POLO 6R fuse box
https://drive.google.com/drive/folders/ ... sp=sharing
The pink locking mechanism is only for small slots/fuses. In the 6R fuse box the large fuses do not have this locking mechanism
To remove the terminals from the fuse box you have to use the terminal removal tool. Exactly the same as for the rest of volkswagen connectors.
As for the electrical supply signals: (brief explanation)
+30 = Before ignition. Electric power 'permanent'. Direct from battery.
+15 = After ignition. When you turn the ignition switch.
For example:
The light sensor needs +30 because it is required for CH/LH functions. Before you open the car doors, before ignition.
The Dimming mirror needs +15 because the dimming rear view mirror function is used when driving, after ignition.
The following codings should only be entered once you have installed the wiring and new 7E0 BCM (not before).
BCM, read here for Replacement and Adaptation.
The new BCM coding it's based on your previous BCM coding, which is a disaster (already corrected in this new BCM coding).
Halogen headlights, automatic lights.
New BCM coding
3A904BBF48E10200013807B06CCB96905F88616F608C2041200000030000
RLS coding
0628DD
Bixenon headlights, automatic lights.
New BCM coding
3A904BBF48E10200013807916CCB96905A88676F600D3041200000030000
RLS coding
0728DD
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
Got the bixenon today have one question regarding it
White shaft is of motor which levels up down it is out of the slot can anyone tell me how to put it back in the slot ?
smg_shardul
Drives: Polo 6R
Thanks a lot ciclo it got repaired I was worried about it and I thought I need to open the lens to repair it...[emoji4]
Thanks a lot again...
:wink:
Remember (once again :lol:) , Installation guide (MK5 POLO 6R link)
... and you will avoid having excessive worries. Image
Yesterday I received this VCDS autoscan by email from the smg_shardul's Vento, he asking me what the problem is.
Wednesday,11,October,2017,01:22:15:39744
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: MEXA16608GT067313   License Plate:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56 0B
02-Auto Trans -- Status: Not registered 0011
03-ABS Brakes -- Status: Not registered 0011
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0011
10-Park/Steer Assist -- Status: Not registered 0011
15-Airbags -- Status: Not registered 0011
25-Immobilizer -- Status: Malfunction 0010
44-Steering Assist -- Status: Not registered 0011
56-Radio -- Status: Not registered 0011
Address 01: Engine (J623-CWXB)       Labels: None
   Part No SW: 03L 906 023 SN    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00250116032500080000
   Shop #: WSC 00000 000 08192
   ASAM Dataset: EV_EC1M5TDI02103L906023SN 001001
   ROD: N/A
   VCID: 040057528F805F66AE-8050
No ASAM data for: "EV_EC1M5TDI02103L906023SN" (VW25)
6 Faults Found
6260 - ROD - Unknown Error Code
          - 00 [036]
          Intermittent - Not Confirmed - Tested Since Memory Clear
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 4
                    Mileage: 63548 km
                    Date: 2000.00.00
                    Time: 00:00:00
6068 - ROD - Unknown Error Code
          - 00 [036]
                    Fault Priority: 2
                    Fault Frequency: 8
                    Mileage: 63548 km
                    Date: 2000.00.00
                    Time: 00:00:00
7278 - ROD - Unknown Error Code
          - 00 [036]
                    Fault Priority: 6
                    Fault Frequency: 4
                    Mileage: 63548 km
                    Date: 2000.00.00
                    Time: 00:00:00
7279 - ROD - Unknown Error Code
          - 00 [036]
                    Fault Priority: 6
                    Fault Frequency: 4
                    Mileage: 63548 km
                    Date: 2000.00.00
                    Time: 00:00:00
11844 - ROD - Unknown Error Code
          - 00 [165]
          MIL ON - Not Confirmed - Tested Since Memory Clear
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 31511 km
                    Date: 2018.14.31
                    Time: 00:32:31
6117 - ROD - Unknown Error Code
          - 00 [037]
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 63548 km
                    Date: 2018.14.31
                    Time: 00:32:29
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: Redir Fail!
   Part No SW: 0AM 300 065 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6501
   Revision: 00043014    Serial number: CU501510066015
   Coding: 0000020
   Shop #: WSC 01324 785 00200
   VCID: 3878F3A24BC8CB8672-806C
1 Fault Found
006242 - Powertrain Data Bus
               P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 10
                    Mileage: 0 km
                    Time Indication: 0
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 BN    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2C63422907C74617346A4254E0820908
   Shop #: WSC 28939 002 1048576
   ASAM Dataset: EV_Brkae1ESP90iBOSCH 003031
   ROD: N/A
   VCID: 0B127C6EA2DE101EEF-805E
No ASAM data for: "EV_Brkae1ESP90iBOSCH" (VW25)
5 Faults Found
0983 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 186
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
0931 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 31511 km
                    Date: 2018.14.31
                    Time: 00:17:43
0945 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
0891 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 0
                    Mileage: 31511 km
                    Date: 2018.14.31
                    Time: 00:04:01
0885 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 186
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 04: Steering Angle (G085)       Labels: None
   Serial number: 26071513471359
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW52X 005001
   ROD: N/A
   VCID: 7EF425BAE16C35B6F8-802A
No ASAM data for: "EV_LWSKLOVW52X" (VW25)
1 Fault Found
332644 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 186
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 08: Auto HVAC (J255)       Labels: None
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 418E9E46D8128A4EC5-8014
2 Faults Found
01317 - Control Module in Instrument Cluster (J285)
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
            013 - Check DTC Memory - Intermittent
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 173171271
   Coding: 24982BBB0C610000000000302E4B0C800F00400F60040850200000000000
   VCID: 2B52DCEE4A9E701E0F-807E
   Subsystem 1 - Part No SW: 6R0 959 802 CC    HW: 6R0 959 802 CC
   Component: -------------  007 5521
   Serial number: 13102670151005153008
   Coding: 050000
   Subsystem 2 - Part No SW: 6R0 959 801 BT    HW: 6R0 959 801 BT
   Serial number: 13202671151005132525
   Coding: 050000
   Subsystem 3 - Part No SW: 5TA 959 442     HW: 5TA 959 442
   Serial number: 2991519341401746AJ2B
   Coding: 250000
   Subsystem 4 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: -------------  006 5520
   Serial number: 13202580151005230949
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581150929004312
   Coding: 020000
6 Faults Found
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 31511 km
                    Time Indication: 0
                    Date: 2018.14.31
                    Time: 00:17:39
03432 - Activation of Right Parking Light
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 31511 km
                    Time Indication: 0
                    Date: 2018.14.31
                    Time: 00:17:39
00532 - Supply Voltage B+
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 31511 km
                    Time Indication: 0
                    Date: 2018.14.31
                    Time: 00:32:02
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 31511 km
                    Time Indication: 0
                    Date: 2018.14.31
                    Time: 00:17:39
01516 - Terminal 30; Left
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 31511 km
                    Time Indication: 0
                    Date: 2018.14.31
                    Time: 00:17:39
00927 - Terminal 30 (Right)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 0
                    Mileage: 31511 km
                    Time Indication: 0
                    Date: 2018.14.31
                    Time: 00:17:39
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261224902578
   Coding: 300104
   Shop #: WSC 02756 790 50316
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 397EF6A6B8C2D28E8D-806C
1 Fault Found
12670208 - Databus
          U1121 00 [008] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 15: Airbags (J234)       Labels: Redir Fail!
   Revision: --------    Serial number: 003GW0121NNF
   Coding: 003036
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_AirbaVW1B0PAVW250 A01001
   ROD: N/A
   VCID: 499E8666E822420E1D-801C
No ASAM data for: "EV_AirbaVW1B0PAVW250" (VW25)
2 Faults Found
12670208 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
12674816 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
   Part No SW: 2H0 920 871 B    HW: 2H0 920 871 B
   Component: KOMBI         H04 1009
   Coding: 140A000000
   Shop #: WSC 13202 938 12345
   ASAM Dataset: EV_Kombi_UD_SVDD_RM09 A05730
   ROD: N/A
   VCID: 275A20DE5E76547EEB-8072
No ASAM data for: "EV_Kombi_UD_SVDD_RM09" (VW36 *)
1 Fault Found
12605440 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002000
   VCID: 68D863E29BE89B0622-803C
1 Fault Found
            000 -  -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 31511 km
                    Time Indication: 0
                    Date: 2018.14.31
                    Time: 00:17:39
Address 25: Immobilizer (J334)       Labels: Redir Fail!
   Component: IMMO          H04 1009
   ASAM Dataset: EV_Immo_UD_SVDD_RM09 A03710
   ROD: N/A
   VCID: 6ADC19EA8DE4A91634-803E
No ASAM data for: "EV_Immo_UD_SVDD_RM09" (VW25)
1 Fault Found
13762816 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
Address 44: Steering Assist (J500)       Labels: Redir Fail!
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ASAM Dataset: EV_StereAssisNSK 014008
   ROD: N/A
   VCID: 418E9E46D0128A4EC5-8014
No ASAM data for: "EV_StereAssisNSK" (VW25)
1 Fault Found
0101 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Component: MIB2-S-R-CN   025 0210
   Revision: -----001    Serial number: 02425GD0000489
   Coding: 0000044004000A
   Shop #: WSC 00081 790 00133
   VCID: 45868A56CC3AA66EF9-8010
5 Faults Found
00625 - Vehicle Speed Signal
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Time Indication: 0
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Time Indication: 0
00876 - Treble Speaker Rear Left (R14)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 29000 km
                    Time Indication: 0
                    Date: 2018.14.09
                    Time: 19:46:27
00875 - Treble Speaker Front Right (R22)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 29000 km
                    Time Indication: 0
                    Date: 2018.14.09
                    Time: 19:46:27
00874 - Treble Speaker Front Left (R20)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 67
                    Mileage: 29000 km
                    Time Indication: 0
                    Date: 2018.14.09
                    Time: 19:46:27
End-------------------------(Elapsed Time: 02:53)--------------------------
:lol: :lol: :lol:
1 Congratulations
Congratulations, you are the number 1 in terms of having faults in all units.
2 Despair
I do not know what to do to tell you to pay attention to what you are doing, it's extremely annoying that I give you the best information so that you do good work and you ignore it. I repeat again that reading is free.
In two previous posts I provide you the link so that you follow in detail the replacement and adaptation of your new BCM.
viewtopic.php?f=56&t=70289&start=75#p525420
3 My help
If you read in the link to ross-tech...
Code the 19-CAN Gateway module with the Long Coding from the original module found in the Auto-Scan.
Configure the 19-CAN Gateway module using the [Installation List] function in VCDS per the original Auto-Scan.
so...
- enter your Old Gateway coding :arrow: 002300
- go to Installation list in Gateway and enable the units of your VW Vento, which are: 01 02 03 08 09 10 15 17 19 25 44 56
- follow the instructions for entering BCM coding, etc...
4 Really serious comment
I hope you are not installing the BCM Max without having installed the wiring for the BCM Max adaptation.
I can also see in your Autoscan that you have not yet installed the RLS wiring.
5 ...what is the problem?
Maybe the question is, what is your problem?
Turn up the volume, some say the human is able to increase their IQ after listening music.
6 Hope
I hope this harangue is useful to solve the future problems that will surely arise in this installation that you are going to do.
My main concern is you and your security, everything else is just words ...
smg_shardul
Drives: Polo 6R
Thank you for the help ciclo...
smg_shardul
Drives: Polo 6R
Following 3 errors are not going and even drl and cornering lamps are not working
Logically ...
There is no power in T73a/63 and T73b/68 pins... maybe it's because you have not installed the wiring for BCM adaptation.
I'm going to use your tactic of provide as little information as possible. :lol:
One question, do you understand what I am writing here?, maybe my English is not understandable enough for you. :?:
smg_shardul
Drives: Polo 6R
ciclo wrote:Logically ...
I have installed wiring for bcm adaption
Rest all is working only drl / cornering lamps and reverse camera not working ...
When I connect old bcm cornering lamps are working .
So, post a recent VCDS autoscan here to find out what's going on.
I apologize you to not be smarter... I must have even a few more experiences like this to get a degree as a fortune teller or magician. :mrgreen:
smg_shardul
Drives: Polo 6R
ciclo wrote:So, post a recent VCDS autoscan here to find out what's going on.
ASAM Dataset: EV_ECM15TDI02103L906023SN 001001
ROD: EV_ECM15TDI02103L906023RS.rod
VCID: 0407DFF88F707E66AE-8050
Coding: 0000020
VCID: 387F7B084B38EA8672-806C
VCID: 0B15F4C4A22E311EEF-805E
2 Faults Found:
0931 - Tire Diameter Implausible
C10A8 00 [009] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 31526 km
Date: 2017.10.11
Time: 16:32:09
0944 - Databus
U1122 00 [008] - Implausible Message
Fault Priority: 2
Fault Frequency: 4
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 01
ROD: EV_LWSKLOVW25X_VW25.rod
VCID: 7EF3AD10E19C14B6F8-802A
Revision: V0000000
VCID: 418916ECD8E2AB4EC5-8014
Coding: 3A904BB848E10200013807917FCB96905A88676F608D3041200000030000
VCID: 2B5554444A6E511E0F-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 080617 04 42 0106
Coding: 008F77
Subsystem 2 - Part No SW: 6R0 959 802 CC HW: 6R0 959 802 CC Labels: 6R0-959-802.CLB
Coding: 050000
Subsystem 3 - Part No SW: 6R0 959 801 BT HW: 6R0 959 801 BT Labels: 6R0-959-801.CLB
Coding: 050000
Subsystem 4 - Part No SW: 5TA 959 442 HW: 5TA 959 442
Coding: 250000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
4 Faults Found:
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 31531 km
Time Indication: 0
Date: 2017.10.11
Time: 17:40:54
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 31531 km
Time Indication: 0
Date: 2017.10.11
Time: 17:40:54
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 3
Reset counter: 1
Mileage: 31531 km
Time Indication: 0
Date: 2017.10.11
Time: 17:40:16
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 3
Reset counter: 1
Mileage: 31531 km
Time Indication: 0
Date: 2017.10.11
Time: 17:40:16
smg_shardul
Drives: Polo 6R
Are you getting full report ?
Yes, you will have to explain to me why you have modified the BCM coding that I told you previously. :evil:
viewtopic.php?f=56&t=70289&p=525618#p525420
In any case, the BCM adaptation wiring is not installed correctly.
BCM
4 Faults Found:
00927 - Terminal 30; Right
wait....
Also:
Coding: 008F77
