I'll ban you for 100 years for basing your help on personal tastes.
Polo 6R 1600 TDI Team
Re: Polo 6R 1600 TDI Team
I'll admit guilt if you reduce the sentence to 50 years
The condemnatory sentence is to listen to one hour of Monkeys Spinning Monkeys.
Play
It could have been 10 hours ...
Play
Phew, close call... lucky me
- Turbodruk
- Drives: Polo 6R 1600 TDI Team
Some good and bad news.
Drl left is working...
When the right headlight is connected.
So I switched the modules and but no luck.
Took a look at the pins on the back of the unit, nothing to see here.
Seems the LED drl on the left side is broken.
Which means my connect skills and iichels cable make skills are fine.
iichel suggested fiddling with a multimeter and looking for the cause of the problem.
If that doesn’t work I’ll probably am going to buy a spare left headlight.
- Turbodruk
https://youtu.be/QjOM4cou9hE
Video says enough. Unfortunately the left side DRL was FUBAR. Had to buy a new unit, not too expensive luckily. I want to thank ciclo for the coding and the help and iichel for the live assistence and help.
Next up is the fitment of the sensor on the rear axle and the connecing of all the cables in the AFS module. All the cables are already in the car, so this shouldn’t take so long.
Thanks!
Thanks!
good job Wilmer! hope Mr TUV will be nice to you. And don't forget to place 6q0 941 334 dimmer without headlight range regulator.
... for the coding only?Turbodruk wrote: Mon Jan 15, 2018 7:15 pm https://youtu.be/QjOM4cou9hE
Thanks!
Maybe you should review this topic again ...
- Turbodruk
Hey Ciclo, if you read carefully, I wrote for the coding and the help. There was no intention to anger you, I’m truly sorry!
Wilmer
Wilmer
...and the help to solve iichel mistakes already set from the other forum, you mean that help? It is not necessary that you answer.
It only bothers me to have to solve tech problems from others that provide an inefficient technical support when they sell products.
Everything you have done is only possible thanks to the knowledge provides by uk-polos.net (whithout ads
Thank you for clarifying your intentions, I will take it into account if you need my help on another occasion.
- Turbodruk
I am forever greatfull for all the things you have written, and all the spare time you put in just to help others with their (technical) problems. Without you, there would be just another stock 6R on the road.
Cheers!
Cheers!
