May I ask... How do you realize which address changes what??????MaDwArLoCk wrote: ↑Tue Apr 03, 2018 5:38 pm My IC was updated!
And Direct TPMS now working!
But after update I got “backlight bug”
Backlight starts flashing... (probably because of light sensor)
To fix this bug it’s necessary simply deactivate NeedleSweep
However for me this is temporary solution, because I like NeedleSweep I am trying to find the problem in the eeprom.
I made eeprom dump before and right after updating.
So now I am busy with comparing... without success for now
Also I have noticed that after updating in the adaptation channels, Cruise control display become “Not available”.
And I have found Byte that activates this channel!
Adress 0x02D9 we need to change 01 to 81
Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
- Drives: other
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
- Drives: Cross Polo 2010 TSI
It's not able to read my Delphi 1.2 TDI ecu but it should be fine for the Siemens 1.2 TSI
It’s Simple when you know what are you looking for!EdgardoRodriguez wrote: ↑Thu Apr 05, 2018 3:16 pm
Before software updating CC Display was available, after become NOT availiable.
So I start comparing EEPROM’s before and after update.
There was about 400 Bytes difference!
I have divided these Bytes for blocks and start to upload these blocks one by one, checking CC Display after every upload.
When I found correct data block I start checking each Byte from it, same way.
That’s how I found correct address!
It takes some time, but it’s working mothode
With these Siemens 1.2 ECU’s also not that simple!
There are many kinds of ECU’s: Simos 10.10, Simos 10.20, Simos 10.22 and so on..
For example Kess V2 refuse to read mine Simos 10.20 but easily takes Simos 10.22
I didn't try with the Galletto since I received the RED Kess V2 first, that works perfectly with my ECU.
Backlight bug is solved!
02F9 — xxxxxXxx it’s necessary to switch bit 2 to 0
This bit is switching off dials backlight during NeedleSweep.
My value was 7Е, changed to 7А
Now NeedleSweep is ON and backlight not blinking any more!
Solution found by aadriver
- Drives: other
Nice!!!!MaDwArLoCk wrote:Backlight bug is solved!
Enviado desde mi iPhone utilizando Tapatalk
- Drives: other
Does anybody knows why , at least my ic, has dual color leds for backlight?? They are all exactly the same, look.
- Drives: Polo 6R
For dials backlight during needle sweep same is applicable for stock SW of seat ?MaDwArLoCk wrote:Backlight bug is solved!
Sent from my Pixel 2 using Tapatalk
With some LEDs it happens when you connect wrong polarity ( +/- )EdgardoRodriguez wrote: ↑Tue May 01, 2018 12:29 am Does anybody knows why , at least my ic, has dual color leds for backlight?? They are all exactly the same, look.
What do you mean by “stock”?smg_shardul wrote: ↑Tue May 01, 2018 3:33 amFor dials backlight during needle sweep same is applicable for stock SW of seat ?MaDwArLoCk wrote:Backlight bug is solved!
Stock formware 0607?
I haven’t tried it on 607 FW.
You can try and report us results!
- Drives: Polo 6R
What do you mean by “stock”?MaDwArLoCk wrote:EdgardoRodriguez wrote: ↑Tue May 01, 2018 12:29 am Does anybody knows why , at least my ic, has dual color leds for backlight?? They are all exactly the same, look.
Enviado desde mi iPhone utilizando TapatalkFor dials backlight during needle sweep same is applicable for stock SW of seat ?MaDwArLoCk wrote:Backlight bug is solved!
You can try and report us results! [emoji6][/quote]I tried it's not working...
ok.
Now we know that this is feature of 7xx firmware!
