Bixenon headlights with AFS For polo gt Tsi 2015
hmthakur
Drives: Polo gt tsi 1.2 dsg
Re: Bixenon headlights with AFS For polo gt Tsi 2015
Post by hmthakur »
Which slot in fuse box should i use for tpms??
+30 signal
Maybe SB5 or SB6. It depends on the installation you did with my wiring.
Please show me a current picture of your fuse box, thank you.
hmthakur
Post by hmthakur »
Pin 40 & 41 should be size no 2 ??
Not fitting in bcm connector
hmthakur
Post by hmthakur »
hmthakur
Post by hmthakur »
hmthakur wrote: Fri Aug 17, 2018 8:45 am Image
It is perfect as it is.
Maybe you are making a mistake.
In this image you can check the dimensions of the terminals.
hmthakur wrote: Fri Aug 17, 2018 8:49 am Image
You have labeled the cables incorrectly. :cry:
-1st, why have you labeled the cables?
-2nd, the cables corresponding to 40a and 41a go inside the BCM-Fusebox harness, not individually.
OMG!
This is a real image of your wiring.
:arrow: https://uk-polos.net/viewtopic.php?f=56 ... 75#p540211
The type of terminals you show are MQS.
:cry:
I have doubts, maybe I was the one who made the mistake.
I don't know the reasons why those MQS terminals are crimped in those cables.
Please verify again the wires 40a and 41a with incorrect terminals.
No problem for me to send you asap a new BCM-fusebox wiring. (free, of course)
hmthakur
Post by hmthakur »
Can you tell me what that terminals called??
hmthakur
Post by hmthakur »
If i keep the slot 40 & 41 what will be the problem??
hmthakur
Post by hmthakur »
ciclo wrote:I have doubts, maybe I was the one who made the mistake.
hmthakur
Post by hmthakur »
Whats the part no. Of MCP 1.5 ??
Can i get them at vw showroom??
hmthakur wrote: Fri Aug 17, 2018 9:58 am Can you tell me what that terminals called??
MCP 1.5
https://www.a4-freunde.com/showwiki.php ... uebersicht
https://www.a4-freunde.com/attachment.p ... 1415951045
hmthakur wrote: Fri Aug 17, 2018 9:59 am If i keep the slot 40 & 41 what will be the problem??
https://uk-polos.net/viewtopic.php?f=62 ... 57#p540248
