Exactly...
Bizmo
- Drives: Transporter T5GP
Ciclo, don’t know if you can assist? I am looking to upgrade the BCM on a T5.1 2013
I currently have
And I have been given
I eventually want to install auto lights and maybe HBA but that’s a bit down the line at the moment
It’s a 2014 model year ‘E’
I currently have
Please, Bizmo, read this topic in its entirety.
It is easier than it seems, you must logically forget the part of the bixenon headlights (if you don't want to install them at this time).
Focus your attention on BCM Max adaptation (7E0937090) and on the installation/diagrams of the wiring for automatic lights.
The processes are identical.
We need a autoscan from your T5GP as recently as possible and pics from your T-17 light switch connector and fusebox.
we'll continue...
we'll continue...
Bizmo
Thanks, my VCDS cable is only micro can so ordering a new one which supports the t5, once that has come will send you a scan.
In the meantime I’ll order some cable and terminals
Oh and the fuse / relay holders.
Anything else?
Also if I just plug my new bcm in now and copy the coding over will it function without re-wiring? Promised my old one to someone!
Anything else?
Light switch with Auto function and Relay.
hmm... fabric/cloth tape, plastic clamp ties...
You can do it..., but you must bear in mind that it's a temporary measure. (during wiring installation)Bizmo wrote: Tue Mar 20, 2018 10:25 pm Also if I just plug my new bcm in now and copy the coding over will it function without re-wiring? Promised my old one to someone!
Better the less time you spend in these conditions --- new 7E0 BCM and no re-wiring ---
Do not forget to make an Autoscan before removing the old BCM.
Do you know where the new BCM comes from (donor car)?
Bizmo
Thanks, will do.
Got it from my local VW who said it was new and ordered for a T6 but not used. Not sure if it will have any coding for the T6 already in it.
If it's new, it will have a basic/generic coding.
- You have to do everything indicated
here, it's easy.
Bizmo
Starting to put together a shopping list.
So far 1 have
2.5mm cable yellow 5m x2 - power supply to BCU
1.5mm cable black 2m - SB27 to BCU
0.5mm cable black 1m - CAN lines twisted
Then from there we have the light switch cabling which is
0.5mm cable 6 colours
Then wiring for automatic lights
Not got anywhere on this one other than 6Q0937617B fuse holder with 646 Fuse
Could you also let me know why there is such a difference in this topic and the wiring PDF for Adam87? Adams seems to have a lot more cables.
Could you also let me know a good source of terminals? I’m struggling to source them in quantities of less than 500!
So far 1 have
- 4x SPT Terminals
2x MCP 5.8 Terminals
Fuse holder 6Q0 937 617 B
2x 30A Fuses
- 2x SPT Terminals
2x MCP 2.8 Terminals
- SB28a to BCU 2m - 1x MQS Terminal
SC12a to BCU 2m - SPT one end and MCP 1.5 other
SC14a to BCU 2m - SPT one end and MCP 1.5 other
- Not sure which terminals
- Red audio connector
Bizmo wrote: Thu Mar 22, 2018 10:01 pm Starting to put together a shopping list.
So far 1 have
2.5mm cable yellow 5m x2 - power supply to BCU1.5mm cable yellow 2m - SB5 to BCU
- 4x SPT Terminals
2x 30A Fuses
1.5mm cable black 2m - SB27 to BCU0.5mm cable 3x colours
- 2x SPT Terminals
2x MCP 2.8 Terminals0.5mm cable yellow 1m
0.5mm cable black 1m - CAN lines twistedMQS both ends.
1mm cable green 2m - reverse lightMCP 2.8 bcm end and MCP 1.5 (male) other
0.5mm (1.0mm too) cable 6 coloursJPT
Please read this topic again, but this time pay attention to the images, diagrams. Ref numbers, etc...
Yes, the project for Adam87 was the first we did for the T5, ,,,and in addition to the automatic lights it also included the High Beam Assist.
1- BCM adaptation + automatic lights, etc ... this topic. (Elsawin T5)
2- BCM adaptation + automatic lights + High Beam Assist, etc ... We would have to open a new topic and elaborate the information according to the new diagrams posted here. (Elsawin T6) ...but I'm not willing to do it for obvious reasons.
The electrrical installation for Adam87 will be unique (I mean the wiring configuration).
viewtopic.php?f=10&t=42713#p466570
Bizmo
Sorry it has taken me so long to get back to you, full scan is bellow
I messaged the person about the terminals but haven’t got any reply from them? Do you have another source?
Sunday,22,April,2018,20:42:19:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(Parallels)
VCDS Version 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: License Plate:
Mileage: 127480km-79212mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 77 0B
VIN: Mileage: 127480km-79212miles
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 GN HW: 03L 907 309 L
Component: R4 2,0L EDC H38 5606
Revision: 22H38--- Serial number: 00000000000000
Coding: 01194012232400080000
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_ECM20BTD01103L906019GN 003004
ROD: EV_ECM20BTD01103L906019GK_003.rod
VCID: 7DF0C168ECF16FAEE1-8029
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels:. 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 508724AD89A50A9824AA9177A96210
Shop #: WSC 02736 790 49152
VCID: 3A7A0A74B55F989684-806F
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 7CF6CC6CF7EB66A6D6-8029
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 M HW: 7H0 937 087
Component: BCM T5GP H+4 H34 0411
Revision: BO034001 Serial number: 0573 163131098
Coding: B8A0303A0A732431922848107C2B9C540080432F60844000320000000000
Shop #: WSC 02736 790 12345
VCID: 3E720664A977B4B6B8-806B
Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Coding: 010000
Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
Subsystem 3 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 7E1 951 172
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32931312600211
Coding: 108001
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A7A0A74BD5F989684-806F
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00J7H86
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 35601948944177EE69-8061
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 7E0 920 970 J HW: 7E0 920 970 J
Component: KOMBI H04 0710
Coding: 160801
ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
VCID: 31682D5860295BCE35-8065
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BO034001
Coding: 042300
VCID: 70EEE85CA3A312C67A-8025
Component: IMMO H04 0710
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADAFA348D7FE81634-803F
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: VWZ1Z2N1589686
Coding: 05000200020014
Shop #: WSC 02734 790 00000
VCID: 33642750923569DE47-8067
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664918056
Coding: 0A01010000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 39781578B859938E8D-806D
1 Fault Found:
9458195 - Control Module for Cellular Telephone
B1052 13 [008] - Open Circuit
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 83
Reset counter: 243
Mileage: 126922 km
Date: 2018.02.28
Time: 19:21:30
End-------------------------(Elapsed Time: 03:45)--------------------------
I don't have another source for these specific contact-terminals, but there are a huge amount of websites that sell them.
(google search by ref. number? https://www.a4-freunde.com/showwiki.php ... uebersicht)
I must be a lucky one, dachsmax@web.de - Mr. Heiko - always answers me.
Autoscan.. OK
Pics?.. viewtopic.php?f=56&t=70736&p=533249#p531689
Autoscan.. OK
Bizmo
Apologies,
Attached
- I’ve emailed your contact again so will wait a contact from them
Attached
Thanks, everything written in this topic can be applied to adapt your new 7E0 BCM Max to your Transporter with H4 headlights from factory.
You have to install the RLS so that the automatic lights work.
Do you intend to install the RLS? (in order to provide you the right codings)
Post a new autoscan with the new 7E0 BCM installed/present once you have done the electrical installation, I'll provide you the new codings in order to correct the possible faults.
(remember to tell me what new parts you have installed whenever you post a new autoscan)
Hmm, maybe graylscott can help you to locate everything you need to do this installation.
Bizmo
Yes going to install the RLS, just need to source a new windscreen then should be good to go - is there any benefit to the round rls from the T6 over the squarer one from the T5? Do they fit in the same windscreen mounting?
Will sit down this evening and make a shopping list and buy the rest of the bits that I need.
Thanks for all your help
T5 RLS vs T6 RLS
Don't fit in the same retaining plates. Logically.
e.g. viewtopic.php?f=56&t=70442&start=45#p531196
Square T5 RLS perfectly fulfills its main missions.
Round T6 RLS some benefit should have with respect to the square T5 RLS.
