LED headlamp retrofit
Scotty_boy vw
Re: LED headlamp retrofit
Post by Scotty_boy vw »
Flashredpolo wrote: Wed Mar 02, 2022 12:07 am Hi, any more news on this?
I'm interested in a set of these aliexpress lights on my UK spec car
Can anyone link me to a set they bought?
Also what was required to install
Hey Flash why dont you go the correct original way?
I have a friend who stays in great yarmouth who can make you all the looms and fit everything as well as flash the modules to get this all working,you would need to buy the headlights which you can from ebay then take them to him to have everything done...
His name is Eddie 07982622729 either give him a call or whatsApp him :D
kreesenm
Drives: Aw gti 2019
Post by kreesenm »
Andy i have both headlights with ballasts and headlight control module and level sensor & my mate Ed is making up the wiring looms for me so once lockdown is sorted then its game on!!!
Also i will be fitting the Wireless charger too
Hi Scott,
i need your assistance i'm in the process of installing OEM led headlights onto my 2019 polo GTI that was spec'd with halogen lights, i need to know the headlight control module and level sensor model numbers if possible.
also did you have to replace the BCM on your car, i've read on a few forums that the BCM will need to be replaced?
Kreesen
fouad12
Drives: AW
Post by fouad12 »
Hello,
I have the polo aw 2019 with halogen headlights but i want to install the OEM led headlights.
Where can i buy the cable adapter to connect the led's?
Thankss
tompolo2024
Drives: Mk6 (AW)
Post by tompolo2024 »
Does anyone know of any places I could take my car to have OEM led lights retrofit, I would really like LED headlights, but certainly do not have the knowledge to fit them myself. Thanks in advance. :D
Dimitrisk14
Drives: Polo aw1 2019
Post by Dimitrisk14 »
Hey Scotty i have seen you retrofitted genuine headlights, I have done the same to mine and now its coding time, can you please share the adaptation maps from your bcm, gateway, and 5f unit; in a csv file from vcds;
Hazeman
Drives: VW Polo VI AW
Post by Hazeman »
Dimitrisk14 wrote: Wed Oct 15, 2025 10:23 pm Hey Scotty i have seen you retrofitted genuine headlights, I have done the same to mine and now its coding time, can you please share the adaptation maps from your bcm, gateway, and 5f unit; in a csv file from vcds;
Hi guys, I want to retrofit the original LED headlights on my Polo. I have all the necessary parts (I hope the right ones) except the wiring. Please, does anyone have the part number for the wiring? And please, would anyone be willing to help me with the conversion/give me advice? I would be happy to reward you somehow if you could help me with the conversion.
Thanks for the answer and have a nice day.
That18Se
Drives: MY18 Se since new
Post by That18Se »
Hi mate I really wanna do this To my MY18 Se how long has it took you
