For little lesser price I can buy brand new "Salvador" alloy wheels for my 6R
iichels VW Passat 2.0 TSI DSG 4-Motion 2017
patil
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Yep, it's crazy.... https://www.kwik-fit.nl/autobanden/mich ... 0y19ps4sxl
I'm selling (at least trying to) my old Hankook tires (8mm tread) for about 400 euros and somebody is acting like the offer includes the Estoril rims as well
So I did some experiments with the facelift engine cover and... it fits!
After:
Before:
I took the cover from Seat 06k103925BM and removed the Seat logo, painted the TSI in red and ordered 2x WHT0007324
Fits like a charm.
https://imgur.com/a/9De9h8n
After:
Before:
Fits like a charm.
giannis20vt
Much better the new one. I love it.
Upgraded the diverter valve with the GFB DV+ T9359
Mostly in preparation of the GTX3071R turbocharger coming.
https://imgur.com/a/X6ZPWxv
Inspired by many others, I decided to make some aerodynamic improvements to the bottom of the car.
I already had the Alltrack kevlar skid plate: viewtopic.php?p=598271#p598271
Many of these parts will fit other cars on the MQB platform, be sure to check out the links below.
I had to cut some parts to make them fit, like the subframe cover and the rear/center panels near the fuel tank.
The result is pretty good, given that the factory panels are pretty poor; only the half sized splash shield up front.
The rear is a bit hopeless, it has the rear subframe wit the haldex and quite a lot of exhaust, so not much room to fit any panels.
I did my best for the rest of the car, the result is pretty good.
Front wishbone
3Q0407117B
3Q0407118B
2x N0385494 / 8E0825267
Rear wishbone
5Q0501733
5Q0501734
4x N0385494 / 8E0825267
Front trans tunnel
5Q0825230H (= with heatshield)
4x 8E0825267
5Q0804421B bracket for AWD
Center strip RL
3Q0825206B
4x N90974701
1x WHT003491
Center strip RR
1x 3Q0825102A
4x N90974701
1x WHT003491
Tiguan subframe cover
1x 3Q0199110B
2x WHT000729A
Tiewraps
Sources:
https://www.golfmk7.com/forums/index.ph ... 16.370077/
https://www.golfmk7.com/forums/index.ph ... lf.320687/
https://www.golfmk7.com/forums/index.ph ... lf.375175/
More pics: https://imgur.com/a/M2jP8hp
Front wishbone
3Q0407117B
3Q0407118B
Rear wishbone
5Q0501733
5Q0501734
Front trans tunnel
4x 8E0825267
Center strip RL
3Q0825206B
4x N90974701
1x WHT003491
Center strip RR
1x 3Q0825102A
4x N90974701
1x WHT003491
1x 3Q0199110B
2x WHT000729A
Tiewraps
Sources:
patil
Did I say you were good?.. you're a Rembrandt!iichel wrote: Mon Sep 25, 2023 8:38 pm So I did some experiments with the facelift engine cover and... it fits!
After:
Fits like a charm.
Thanks guys, I didn't get that reference, as a movie enthusiast I'm a bit embarrassed now!
I did some more retrofitting and I'll update this thread as well
Front Audi A3 8V jacking points: 8V0802845 (left) 8V0802846 (right) and 8V0804631 (both sides)
Rear jacking points 8V0802847 will fit the Mk7 golf, but not the Passat.
The front jacking points do need a different piece of underbody trim
So I had to get creative and then the trusty Polo is always a good fallback, they have the 8N TT pads all around.
So I got a set of 8N0804583 + 8N0803855 that do fit in, but need me to modify my freshly installed lower bodywork. 63mm hole
Credits to the source: https://www.golfmk7.com/forums/index.ph ... 13.339117/
More images: https://imgur.com/a/tnRLlk1
Since I got fed up with cleaning my rims every week, and I'm very keen on my T-Roc R wheels, I decided to change the OEM organic pads to EBC Redstuff.
This is a non-race ceramic-like pad that is said to produce less dust. On my Polo I really liked my ATE ceramic pads, so something similar was bought for the Passat
https://imgur.com/a/r2n1Kf5
patil
I thought no one noticed or understood
patil
What are you upto? As if 450hp is not enough
Accidentally built a race car
It's always addictive to have more power, no? 415 horsepower at the wheels is already really nice and will give some great acceleration and speed
But it's an IS38 and these are known for unreliability. So I had the opportunity to get a good deal on a hybrid IS38 (which this in essence is).
IS38:
This is what my seller got on his golf 7R:
This is what I have now:
I don't think I'll push it all the way to 550+, that would be too much stress for both the engine itself and the gearbox.
I'll probably stay in the low 500's with a very nice torque curve, but I'll wait for what the tuner has to say. Pushing 570 hp and 670nm is probably not reliable on this engine.
It will need upgrades in fuelling as well like HPFP (LPFP is already done) which I think is putting too much stress on the drivetrain.
IS38:
Did some software updates...
From...
to
two errors are a bit of a bugger!
to
needs dataset only
to
no dataset needed, no need to re-learn keys!
and
to
no dataset needed
to
needed dataset + to code again + do basic settings
to
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 B
SW 320/325/330
Was fail
(same for 52, BB and BC)
to
needs parameters for pressure, I used tinyQ editor
Still thinking about doing 44 to M and 03 to BN.
I'll do 05 kessy to N but I heard that needs re-learning of the keys via online ODIS. I'll do that at the same time as a BCM upgrade to 084EC
6D will be updated to SW T as soon as I can find myself some parameters for that
3C/CF will be updated to 2Q0 with SW B
There are no updates AFAIK for 2B, 15, 47, 69, CA, D6 and D7 at all.
01, 02, 08, 13, 16, 17, 19, 5F, A5 and 6C have already been updated or replaced with the highest versions
To get rid of the errors in 0x10, I'll probably need to update the door control modules to HW F or something similar and retrofit 75 telematics.
From...
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417617172 Dataset Number: V03935256HH 0001
Coding: 0A71267951
Shop #: WSC 30389 123 56831
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 50F98D01FA61D64ADFB-8005
No fault code found.Code: Select all
Part No SW: 5QA 919 298 L HW: 5QA 919 298 A
Component: PLA 3.0 12K H07 0074
Serial number: 000308417617172 Dataset Number: V03935315EN 0001
Coding: 0A71267951
ASAM Dataset: EV_EPHVA2CAU3700000 009055
VCID: 59EF7025A99B9702285-800C
2 Faults Found:
12716048 - Databus
U1121 00 [009] - Missing Message
[T¸rsteuerger‰t - Spiegel_01 - fehlende Botschaft]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 16
Mileage: 165214 km
Date: 2023.11.07
Time: 16:02:53
12650512 - Databus
[Steuerger‰t f¸r eCall - TM_01 - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 16
Mileage: 165214 km
Date: 2023.11.07
Time: 16:02:53Code: Select all
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0121
Serial number: 25061741350001
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3829D5A172D16E0B132-806D
Part No SW: 5Q0 907 376 C HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0130
Serial number: 25061741350001 Dataset Number: V03935290WM 0001
VCID: 392FD0A549DB7702085-806C
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 H HW: 5Q0 963 272 H
Component: STH-MQB 008 0075
Coding: 9309
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS.rod
VCID: 3B23CAAD43E745121A9-806F
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000276932
Part No SW: 5Q0 963 272 K HW: 5Q0 963 272 H
Component: STH-MQB 008 0080
Coding: 9309
VCID: 3E25C3B950F5503A3D7-806A
No fault code found.and
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Component: Haldex4Motion H52 7083
Serial number: HA1-00017.05.17 Dataset Number: v1260x015G0 0000
Coding: 0601
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4ACD9F691C3DEC9A91F-801F
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Coding: 0601
Shop #: WSC 00046 000 00000
VCID: 4CC199711649F2AAA33-8018
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H05 0022
Serial number: Y0006QFD15173
Coding: 001000020000050081C280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
ROD: EV_SeatMemorDriveSide.rod
VCID: 3A2DCFA94CDD7C1A01F-806F
Part No SW: 3Q0 959 760 D HW: 3Q0 959 760 B
Component: Sitzmemory H05 0024
Serial number: Y0006QFD15173 Dataset Number: V03935285VX 0001
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3C21C9B146E9422A133-8068
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 190417EDJ1110A Dataset Number: V03935256EF 0001
Coding: 00351A20D200028000111000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43D3B24D3B173DD2529-8017
No fault code found.Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 B
SW 320/325/330
Was fail
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000081630
ASAM Dataset: EV_RDKBERU30 006001
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3431E1916EB98A6B3FA-8061
Part No SW: 5Q0 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000081630 Dataset Number: RDKS_TinyQ_ 1017
VCID: 3829D5A172D16E0AF7B-806C
No fault code found.Still thinking about doing 44 to M and 03 to BN.
patil
0-100 in less than 5 sec is crazy! reminds me of song baby calm down ha ha ha
Those errors in address 10, could be due to uploading K dataset in L firmware?
Module 75( telematics ) is one cunning module to say the least. It wants to be informed of almost everything we change/ retrofit.
I thought I was smart, tried to split GPS signal meant for 75 module from roof antenna for newly installed Discover media, but telematics module wasn't happy to share signal and threw GPS signal open circuit error and cluster error everytime I started car damn. I hate this module
