Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
What do we have here?
.... :twisted: ... :mrgreen:
So I went shopping:
And decapitated this lever and manual Polo 6R0 lever
Do some frankensteining....
:lol: :lol:
It's not perfect - yet.
The 5NB lever has the D/S on the same LED. The 6R0/6C0 lever works differently.
Pin layout 6R0, it has one common positive and switched negatives, it seems:
T10/
1 permanent GND
2 +-
3 P
4 R
5 N
6 D
7 S
8 Common + (+15 with DRL, 58d with sidelights and low beam)
9 vacant
10 vacant
wiring --> viewtopic.php?p=589334#p589334
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
very nice iichel.
With all these mods, I am short of superlatives to express you!!!
giannis20vt
Post by giannis20vt »
Wow, excellent job. I admire your will to create.
Great!👍
Thank you all. The show goes on 8)
6cgti_bcn
Drives: Polo 6C GTI
Post by 6cgti_bcn »
Great retrofit! You are doing a very good job!
I think I will miss my old Scirocco's gauges to check oil temp easier!
Normally, I always have the digital speedo in my cluster. The oil temperature is only 1 click down, if you need it.
Are you still running a dpf pressure sensor ?
Yes, I have an intact DPF on my car.
Yes, I saw the pictures you posted. You've relocated it. I think its a really nice upgrade.
amer6R wrote: Fri Jan 14, 2022 3:59 pm Yes, I saw the pictures you posted. You've relocated it. I think its a really nice upgrade.
You mean the DPF differential pressure sensor? It's still on the original location, a bracket on the fuel filter.
No, i meant on the sensor lines that go to the dpf. I presume you routed them on top side. Since its not visible on photo. That why i thought you maybe turned that feature off.
Ah yes, now I understand. The DPF is completely intact and working as intended. All sensors present.
How I got by the issue of the D/S indicator in the lever head not being illuminated.
to illuminate the D/S in S mode. the dsg selector mechanism has some kind of error detection on the LED.
if I connect both one or wires to the D/S LED (T10/6) it will go out after a few seconds. I don't think there is a DSG bit/byte to disable light diagnostics on the dsg lever 😂
patil
Post by patil »
iichel wrote: Fri Jan 14, 2022 5:39 pm
iichel, thanks a lot for sharing both the problem and solution associated with new led dsg lever on 6R. Even I have ordered same lever, yet to reach me (RUS--IND). I intend to install new lever with 6C base( more lights :mrgreen: ).
I see you are using a 12v 1ch relay with optocoupler isolated board that allows an electrical signal to be transmitted between two isolated circuits(for D&S) sharing single SMD, am I right? I am curious to know how it works.
Yes you are completely correct
