Posts: 8912 Joined: Sun Feb 24, 2013 10:20 am
Post
by ciclo » Tue Apr 14, 2015 5:03 am
It is a good idea, will be a good one mod I will do in the future (I'll copy from you ...
The only problem is to fit this LED bulbs with two functions in the socket.
Link to buy?
Mart!n-GTI-DK
Posts: 1401 Joined: Sun Apr 26, 2009 7:43 pm
Drives: '14 Polo BlueGT
Post
by Mart!n-GTI-DK » Tue Apr 14, 2015 7:01 pm
ciclo wrote: Thanks guys for the clarifications.
WRC team are very skilled, I guess they did similar to this but the other way around.
OMG
That is the worst taking apart your headlight DIY I have ever seen.
If the glass is still that hard to get off after you heated it... YOU HAVEN'T HEATED IT ENOUGH!!!
Andrea 6r
Posts: 96 Joined: Sat Jan 31, 2015 11:03 am
Drives: 6r
Post
by Andrea 6r » Tue Apr 14, 2015 10:13 pm
ciclo wrote:
Electrical diagrams:
[/b]
Passenger door: Two wires.
-T10v/4-------to------- T16l/15 (J387)
-T10v/2-------to------- T16l/14 (J387)
(J387) is window regulator motor.
T10v is a coupling.
Driver's door: Three wires.
-T10f/4-------to------- T16g/15 (J386)
-T10f/2-------to------- T16g/14 (J386)
-T10k/8-------to------- T16g/12 (J386)
(J386) is window regulator motor.
T10f is a coupling.
T10k is switch connector door mirrors.
Hi ciclo;
could you explain better connections? I do not understand what are the various codes example J387 indicates what?
Post
by ciclo » Wed Apr 15, 2015 7:10 pm
Mart!n-GTI-DK wrote: YOU HAVEN'T HEATED IT ENOUGH!!!
Totally agree ... but it seems that is the only way to take apart the glass.
Post
by ciclo » Wed Apr 15, 2015 7:18 pm
Andrea 6r wrote: ciclo wrote:
Hi ciclo;
It's an easy deduction if you look at the pictures.
J386, J387 are the motors of the windows (dark blue in the pictures above)
GUIDE Folding mirrors
Andrea 6r
Drives: 6r
Post
by Andrea 6r » Wed Apr 15, 2015 8:13 pm
Post
by ciclo » Thu Apr 16, 2015 6:34 am
you're welcome
Andrea 6r
Drives: 6r
Post
by Andrea 6r » Thu Apr 16, 2015 9:42 am
I have another question .. you know where to find the "window line"?
I only have this detail "t 28/20"
I bought a kit and they told me that I need to connect a wire them but I do not understand where he is
Post
by ciclo » Fri Apr 17, 2015 8:12 am
According to the manual:
T28a/20 driver's door
T28/20 passenger door
This is the electrical signal of Central locking, in both doors.
You can locate this wire into the connector (T28, numbered) next to hinges of the doors.
You have many images of these connectors here
click and scroll down
Andrea 6r
Drives: 6r
Post
by Andrea 6r » Fri Apr 17, 2015 10:33 am
I Have only wire on the left.I put in the pin 20?or in the 28?
Posts: 14874 Joined: Sat Nov 11, 2006 5:29 pm
Post
by alexperkins » Fri Apr 17, 2015 10:51 am
T28 is the connector in the passenger door
20 will be the pin number to use
Post
by ciclo » Fri Apr 17, 2015 10:56 am
20
I guess you'll have to hook the wire that says the seller to the wire located in slot 20.
What for is the kit?
Andrea 6r
Drives: 6r
Post
by Andrea 6r » Fri Apr 17, 2015 10:58 am
ok thanks
do you now where is the left-and right indicator in t28?
Post
by ciclo » Fri Apr 17, 2015 11:07 am
3
left T28a/3
right T28/3
