1L cars ......performance!
Non-VW related chat - Moderated
Tahrey1043
Post by Tahrey1043 »
what does the clock read to?
Tigz
Post by Tigz »
Tahrey1043 wrote:what does the clock read to?
Heres mine.
Tahrey1043
dont want to be the doubting thomas but i think if a simple cam could take a 1-litre past 140mph we'd all be buying them....
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
and since parkers rate the 1.0 at 103mph top speed
:shock:
110mph is as far as i've had mine with the induction and exhaust and a downhill stretch of road with a strong north-westerly prevailing wind behind me! :P
-Ben-
Tigz
Post by Tigz »
No matter how much extra fuel you can get it.
The gearbox wouldnt be able to get past 120mph.
The wind stops me, about 1krpm before the limiter.
So lets say the extra power got you to the limitter.
the gearbox would stop you being about to rev any further.
Tahrey1043
maybe it was a different speedo clock?
all the same i doubt it could make 120 even if the gearbox allowed it (not accounting for massive speedometer variance!). You really do need either some serious horsepower or a very large hill to make it there - I don't even think a stock GT would manage it, so 80, maybe 90hp required if not a full 100+ ... which is like doubling the power, and i can't see camming it giving more than an extra 50% under any circumstances, unless it has a VERY mild one to start with.
Tigz
Post by Tigz »
Tahrey1043 wrote:maybe it was a different speedo clock?
Couldn't agree more :)
polo69
Post by polo69 »
its a 1L MK4 so the speedo will end at 120MPH.
His dad is a mechanic and fitted them, i was told they cost around 130/150?
and that its fast.
polopowah
Post by polopowah »
i'll have me some of that :D :D :D
any links? contact numbers?
-Ben-
polo69
Post by polo69 »
me too thank you. Ill ask a friend to contact him see what he says and report back.
Tahrey1043
i'll take one as well, because if that's true, i'll be able to make the old mk3 go faster than the 1.6 astra replacing it (assuming it ever fires again)
polo69
Post by polo69 »
So this is a rare thing then? all my friends talk about is bloody cams, like you can buy them at halfords!!
Tigz
Post by Tigz »
Do you know how a cam works?
Its a shaft that opens and closes the inlet, and exhaust valves.
All an upgraded cam does is, alters the time and and the lenth of time, the valves open.
Cams work along with:
induction (getting air in)
exhaust (getting air out)
if the cams are built for your car, they match your ehaust, and inlet.
So if the air can get in easier, and get out more freely, they can ajust the lenth of time the inlet valve can open.
then the mapped ECU can tell the spark plugs when to fire, and the injectors to fire.
There is no way, I would buy a set of cams from Halfords ;)
Cams in the head.
Valves.
I think all that is correct, but please correct anything Ive mixed up.
One of them nights :?
PoloCornwall
Post by PoloCornwall »
which in turn means, if you havent got the extra fuel, and increased manifold/exhaust system the cams wont really do much more than a standard cam,
Tigz
Post by Tigz »
Exactly :)
Thats why Im trying to explain to the girlfriend.
She can not understand, why I need and extra £800 for the custom cams I need to go with my trottle bodies :wink:
