POLO 6R. HEATED SEATS. OEM.
- habib_123
- Drives: Polo 6R 2012 1.2TDI RHD
Re: POLO 6R. HEATED SEATS. OEM.
Hey Ciclo,
That was my previous wiring. This is what I have done now and my new problem is the one in the video.
https://postimg.org/image/n7imp317z/
As soon as I plug the heated elements wiring into the kufatec grey connector and test it both pins light up as ground. When I take one pin out then test it, I get 12v and the other as ground. Very confusing....
Ok, the wiring issue is fixed.
Please make a new Autoscan (with bugs/faults if any).
- habib_123
Latest Auto-Scan:
Friday,12,May,2017,09:23:25:33719
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWZZZ6RZCU000000 License Plate:
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 37 44 56 77
VIN: WVWZZZ6RZCU015153 Mileage: 51530km-32019miles
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 A HW: 03P 907 425 A
Component: R3 1.2l TDI H06 9978
Revision: 11002001 Serial number:
Coding: 00114010002500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TDI03103P906021A 001023
ROD: EV_ECM12TDI03103P906021.rod
VCID: 26438C535964BA71B3-8072
1 Fault Found:
16973 - Exhaust Gas Temperature Sensor; B1 S3
P242A 00 [191] - Malfunction
MIL ON - Confirmed - Not Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:21
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 73 °C
Intake air temperature: 15 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 11.906 V
Unlearning counter according OBD: 0
Exhaust gas temperature sensor 1: 168 °C
Sensor for engine block temperature: raw value: 73 °C
Exhaust gas temperature sensor 3: 1000 °C
Exhaust gas temperature sensor 4: 104 °C
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 230224E3416E00B7C42624E782D400821300
Shop #: WSC 31414 790 31414
VCID: 071DE1D7B2AE8379A8-8052
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326B60036DACD6D12F-8066
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0251
Revision: BF046001 Serial number: 0434 204112918
Coding: 3CB82BBF08612E00923808006D6B0CD80088412F60860000200000000000
Shop #: WSC 12345 123 12345
VCID: 45812BDFCC2251699A-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU030061100013435
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU001071100014019
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0051077
Coding: 820000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU030061100017642
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU001071100012650
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H11 0012
Revision: -------- Serial number: 47301119601229
Coding: 308001
ROD: EV_VW250ParkiAssis2.rod
VCID: 3D71433FACF219A9C2-8068
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00RE3X0
Coding: 003237
VCID: 4A9B18E3ED3CBE1177-801E
Serial number: 3575HRB405H0N3MK9GQ5
Serial number: 3585HRB405H0IRE2D8P.
Serial number: 3515RRB405P0KOIAK09%
Serial number: 3525RRB40650KOIAFH4V
3 Faults Found:
9446656 - Redundant signal path for airbag shut-off; passenger side
B1025 00 [137] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:19
9445376 - Key switch for deactivation of passenger-side airbag
B1020 00 [137] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:19
10487296 - Control Module Does Not Match Vehicle
B2006 00 [137] - -
Fault Priority: 1
Fault Frequency: 1
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:19
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 970 HW: 6R0 920 970
Component: KOMBI H07 0304
Coding: 141A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 73E5A507DA369FD9E4-8026
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0251
Revision: BF046001
Coding: 003300
VCID: 70EFAA0BA320A4C119-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H07 0304
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADBB8638DFC5E1157-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660416968
Coding: 010000
VCID: 2959876F407A95099E-807C
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 S HW: 1T0 035 680 S
Component: RNS-MID H30 6276
Revision: AB001001 Serial number: VWZ6Z7S9225810
Coding: 00000440000000A10001
VCID: 3E734433A9F402B1DB-806A
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V13 8348
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F6D6977EA9EFB3940-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0982
Revision: -------- Serial number: 35502105200652
Coding: 020000000100000000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_002.rod
VCID: 2447965B2F584861AD-8070
2 Faults Found:
9458451 - Cellular Antenna
B1053 13 [009] - Open Circuit
Fault Priority: 4
Fault Frequency: 1
Reset counter: 13
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:17
9458193 - Control Module for Cellular Telephone
B1052 14 [009] - Open or Short to Ground
Fault Priority: 4
Fault Frequency: 1
Reset counter: 13
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:17
End-------------------------(Elapsed Time: 03:21)--------------------------
www.Ross-Tech.com
1 Fault Found:
Fault Priority: 2
Fault Frequency: 2
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:21
Revision: --------
Revision: 0002S 02
Coding: 18BC30
Coding: 08BC30
Coding: 820000
Coding: 08BC32
Coding: 08BC32
Coding: 308001
Coding: 003237
3 Faults Found:
B1025 00 [137] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:19
B1020 00 [137] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:19
B2006 00 [137] - -
Fault Priority: 1
Fault Frequency: 1
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:19
Coding: 141A00
Revision: BF046001
Coding: 003300
Serial number:
Coding: 010000
Coding: 11230
Shop #: WSC 31414
2 Faults Found:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 13
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:17
Fault Priority: 4
Fault Frequency: 1
Reset counter: 13
Mileage: 51536 km
Date: 2017.05.12
Time: 09:19:17
As far as the BCM goes, coding looks okay to me. I'm a bit worried about some errors in your airbag module though but maybe that's for later...
Do the following process:
Clear all DTCs and check if the Heated Seats work.
If they do not work, do the following:
https://drive.google.com/drive/folders/ ... sp=sharing
Upload the csv file to a server so that I can download it and make the appropriate checks.
You can also try a hard-reset , remove battery ground wire for a few minutes and reconnect it.
After that you may have to reset the comfort function of the windows once the battery is connected (user manual), and enter the radionavigation code.
- habib_123
Hey ciclo,
I cleared DTC's, and then checked but it still didn't work. I have attached the CSV log for you...
https://mega.nz/#!HY11DZpA!rdu_b59wNa06 ... zCgpqcyOsQ
I will now do hard reset...hopefully it will work.
- habib_123
I still need to change the airbag module from 4UE to 4UF. I have it however I will change it later. I was wondering since it can be ONLY coded ONCE, if I install it could it be removed and installed into another car later and re-install the old module back in my car. (Just in case I sell the car, I want to remove mods and install passenger airbag deactivation onto another polo later)iichel wrote:As far as the BCM goes, coding looks okay to me. I'm a bit worried about some errors in your airbag module though but maybe that's for later...
That's the only question in my head that is delaying the install...
- habib_123
Hard reset did not work.
While I check your BCM can you give us all the information possible from the Heated Seats unit that you bought? (new?, pics, etc...)
- habib_123
Heated Pads:
http://www.ebay.co.uk/itm/302226542529? ... EBIDX%3AIT = x2 (Brand New)
Heating Control Module:
http://www.ebay.co.uk/itm/132099241844? ... EBIDX%3AIT = x1 (Used)
Kufatec Heated Seats Wiring:
https://www.kufatec.de/shop/en/volkswag ... t-ibiza-6j = x1 (Brand New)
000 979 129 Wiring:
https://www.aliexpress.com/item/2Pcs-00 ... 0.0.U6gdRK
1J0 972 712 Connectors:
I got these brand new from iichel. (Thank You)
That's it.
000 979 129 Wiring:
That's it.
Have you checked that the T73a/36 terminal is correctly inserted in the BCM black connector?
Hmm... once inserted the contact terminal can not be extracted. 'Slightly' pull from the wire for testing.
The numbering for the terminal assignment is visible on the connector.
e.g.
- habib_123
I will. Also ciclo what is the purpose of this connector? (T73a/36)
it is to switch off the seat heating when the BCM needs to (ie too high power use, engine not running)
- habib_123
Maybe this is causing the problem?
Check your inbox.habib_123 wrote:Maybe this is causing the problem?
