Cross Polo 6R Upgrading to BCM Max with Auto light switch
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Re: Cross Polo 6R Upgrading to BCM Max with Auto light switch
Post by MaDwArLoCk »
Hi guys! :)
First of all I can confirm that Battery Regul. was guilty in my problems with light :!: :!: :!:
Now I'm finished installation of the Bi-xenon headlights! :D
Everithing is working, only LED's looks like dimmed all the time. They are not changing brightness when i switch to parking lights or low beam...
I've used instructions for codding which was included to Xenon adapters:
My current coding: 24B02BBF48E3240093300FB07FEB1ED0FFC0670E60053041200000010000
Ciclo, could you please advice me something about coding :?:
Autoscan:
Monday,28,August,2017,16:03:03:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWZZZ6RZAU000000   License Plate:
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 44 56 77 0B
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 D    HW: 03F 906 070 D
   Component: SIMOS10.20H02 9851
   Revision: --------    Serial number:
   Coding: 001900D6202400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TFS01203F906070D 003015
   ROD: N/A
   VCID: 234234CE2A4EB859D4-8076
No ASAM data for: "EV_ECM12TFS01203F906070D" (VW25)
Readiness: 0010 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0005
   Revision: --------
   Coding: 210228E3227300BA842C14E844D600401300
   Shop #: WSC 31414 790 31414
   VCID: 020C514A99945151FF-8056
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3878F3A28BC8CB8111-806C
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 0571 017140713
   Coding: 24B02BBF48E3240093300FB07FEB1ED0FFC0670E60053041200000010000
   Shop #: WSC 02756 790 00000
   VCID: 2D56D2F6748A7E2972-8078
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 210310 05  54  0403
   Coding: 06302D
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU028.04.1013935
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU030.04.1010613
   Coding: 08BC30
   Subsystem 5 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
   Subsystem 7 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU026.04.1016866
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU020.04.1013618
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 A    HW: 7E0 919 475
   Component: PARKHILFE 4K  H10 0011
   Revision: --------    Serial number: 64531012301615
   Coding: 100003
   ASAM Dataset: EV_VW25P0arkiAssis2 S01008
   ROD: N/A
   VCID: 3C70EFB2B7F0E7A1F5-8068
No ASAM data for: "EV_VW25P0arkiAssis2" (VW25)
   Component: VW10Airbag00K H08 0020
   Revision: --------    Serial number: 003GX002F4VI
   Coding: 00304B
   ASAM Dataset: EV_AirbaWV10BPAVW250 A01001
   ROD: N/A
   VCID: 4A9CB96AED24491177-801E
   Subsystem 1 - Serial number: 3572SRB40000B53459C7
   Subsystem 2 - Serial number: 3582SRB40000B520C0C1
   Subsystem 3 - Serial number: 3515RRB405D6QGG0HO90
   Subsystem 4 - Serial number: 3525RRB405B6SD5OFPMN
No ASAM data for: "EV_AirbaWV10BPAVW250" (VW25)
   Part No SW: 6R0 920 860 D    HW: 6R0 920 860 D
   Component: KOMBI         H03 0207
   Coding: 140800
   ASAM Dataset: EV_Kombi_UDS_VD_DRM09 A04052
   ROD: N/A
   VCID: 3566FA9694DA36E90A-8060
No ASAM data for: "EV_Kombi_UDS_VD_DRM09" (VW36 *)
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 002240
   VCID: 70E80B82A33853C119-8024
   Component: IMMO          H03 0207
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
   VCID: 6ADC19EA8DE4A91157-803E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Component: RNS-MID       H21 6270
   Revision: AB001001    Serial number: VWZ6Z7N8319084
   Coding: 040104020100002C0001
   Shop #: WSC 01357 011 00200
   VCID: 3D76E2B6A4EAEEA9C2-8068
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V14  8477
Try this:
24B02BBF48E3240093300FB07EEB1ED0FFC0670E60053041200000010000
That coding is not correct...
Time: the indefinite continued progress of existence and events in the past, present, and future regarded as a whole. :wink: :lol:
Maybe tomorrow or another day I'll tell you what the correct coding is ... and if you're a good boy I'll tell you more hidden codings ... Image
MaDwArLoCk
iichel wrote: Mon Aug 28, 2017 4:20 pm Try this:
I will try this one for now :!: :)
ciclo wrote: Mon Aug 28, 2017 4:36 pm That coding is not correct...
Mmm, hidden codings - jummmy!!! :D :D :D
MaDwArLoCk wrote: Mon Aug 28, 2017 8:36 pm And what about something simlpe, how to increase brightness of the LPL leds?
Simple? Please, illustrate us.
Again I gave you some clues to achieve your goal, I'm sure you'll find a way to increase the brightness of Leds license plate lights. :)
MaDwArLoCk
This coding is OK - DRL dimming working!
I will try this one now:
ciclo wrote: Mon Aug 28, 2017 6:19 pm 24B02BBF48E3240093300F916CEB1ED05AC0672F60053041200000030000
But only like that:
24B02BBF48E3240093300F916CEB1ED05AC0672F60053041200000010000
Because of:
1 Fault Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 69
                    Mileage: 157248 km
                    Time Indication: 0
                    Date: 2012.01.20
                    Time: 15:49:60
ciclo wrote: Tue Aug 29, 2017 6:36 am
Looks like it's not so simple as i thought...
i hope i will find the way :D
MaDwArLoCk wrote: Tue Aug 29, 2017 3:50 pm
I insist, this coding is not correct for Bixenon headlights. :wink:
But only like that:
Because of:
1 Fault Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 69
                    Mileage: 157248 km
                    Time Indication: 0
                    Date: 2012.01.20
                    Time: 15:49:60
24B02BBF48E3240093300F916CEB1ED05AC0672F60053041200000010000 , this could be a perfect BCM coding for your 6R configuration.
I activated the Byte27 Bit2 (03Hex) to know its behavior once you installed the bixenon headlights and the BCM was coded for them.
It is the PWM for DSIP & SL (E20) as you can see in the vcds fault, in your configuration of BCM + wires installation has a strange behavior.
If your Dimmer works correctly, no problem ...
You can add more functions (e.g the previous links I post, etc...) but you can never enabled the Byte12 Bit0, in Europe it's illegal to drive with the side/parking lights only, except in the Scandinavian countries.
This would be possible if you have the light switch in the 0 position and the Byte12 Bit0 enabled, ...and if you are not aware of this circumstance (it is possible) you may cause an accident/incident due to poor lighting of your 6R (for all other drivers).
In any case, (tip) whenever the weather conditions allow, always keep the light switch in the AUTO position.
You can.
MaDwArLoCk
ciclo wrote: Tue Aug 29, 2017 6:38 pm
Thank you very much, Ciclo!
I will try this coding tomorrow :)
You can be sure ciclo knows this better than I do. His coding is probably the good one. I know a lot, but not the fine details such as PWM control of the lights. Trust him.
MaDwArLoCk
Ciclo and iitchel, i want to thank you :!:
You guys are "crazy modders"! :D and i am really glad that you are here and helping to people like me!
Last codind works perfectly! :)
Thanks to you. Enjoy it!
