Page 7 of 20
RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Posted: Wed Oct 11, 2017 6:08 pm
by smg_shardul
ciclo wrote:Yes, you will have to explain to me why you have modified the BCM coding that I told you previously. [emoji49]
viewtopic.php?f=56&t=70289&p=525618#p525420
In any case, the BCM adaptation wiring is not installed correctly.
wait please...
I have just installed BCM Max , bixenon headlamps, Auto dimming mirror & RLS
Rest all is pending and will complete it in Diwali holidays
Coded as per your instructions
Bixenon headlights, automatic lights.
New BCM coding
3A904BBF48E10200013807916CCB96905A88676F600D3041200000030000
RLS coding
0728DD
Re: RLS ,CH/LH , Auto lights , Rain sensing wiper & Auto dimming Rear view mirror on Vento
Posted: Wed Oct 11, 2017 6:20 pm
by ciclo
You lie, and you make me work unnecessarily. Thank you.
Posted: Wed Oct 11, 2017 6:31 pm
by smg_shardul
ciclo wrote:You lie, and you make me work unnecessarily. Thank you.
What did I lie ?
Posted: Wed Oct 11, 2017 7:06 pm
by firegrafik
ciclo wrote: Wed Oct 11, 2017 6:05 pm
Also:
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 080617 04 42 0106
Coding:
008F77
To everyone.
Yesterday I have faced on drive2 with issue. One guy tried to code this new type sensor 5K7 955 559 C. Found out interesting thing.
Please look at the photo
So I was very surprised the coding length of this sensor. So now I am urgently seeking of the autoscan the Polo sedan 2017 with this sensor from the factory. To have the base coding. I'll keep you informed
Posted: Wed Oct 11, 2017 7:07 pm
by ciclo
smg_shardul wrote: Wed Oct 11, 2017 6:31 pm
What did I lie ?
3A904B
B848E1020001380791
7FCB96905A88676F60
8D3041200000030000
008F77
smg_shardul wrote: Wed Oct 11, 2017 1:39 pm
I have installed wiring for bcm adaption
Rest all is working only drl / cornering lamps and reverse camera not working ...
When I connect old bcm cornering lamps are working .
Impossible with
03432 - Activation of Right Parking Light
01516 - Terminal 30; Left
00927 - Terminal 30; Right
smg_shardul wrote: Wed Oct 11, 2017 6:08 pm
Coded as per your instructions see above your BCM coding... and RLS coding
New BCM coding
RLS coding
0728DD
What is the rest?
You lie.
I will wait until Diwali holidays to finish with this installation, no problem.
Thursday, October 19, 2017
Posted: Thu Oct 12, 2017 3:20 am
by smg_shardul
ciclo wrote:smg_shardul wrote: Wed Oct 11, 2017 6:31 pm
What did I lie ?
3A904B
B848E1020001380791
7FCB96905A88676F60
8D3041200000030000
008F77
Impossible with
Wires for Bcm adaption are that yellow and black wire right ?
If I won’t put that wire cluster don’t get any canbus signal from new Bcm
What is impossible?
New BCM coding
RLS coding
0728DD
What is the rest?
Auto lights wiring is left for installation
You lie.
Posted: Thu Oct 12, 2017 3:40 am
by ciclo
smg_shardul wrote: Thu Oct 12, 2017 3:20 am
What did I lie ?
3A904B
B848E1020001380791
7FCB96905A88676F60
8D3041200000030000
008F77
Impossible with
What is impossible?
New BCM coding
RLS coding
0728DD
What is the rest?
You lie.
Please, can you tell me what is the rest? Thanks
Posted: Thu Oct 12, 2017 3:47 am
by ciclo
firegrafik wrote: Wed Oct 11, 2017 7:06 pm
Also:
Coding:
008F77
To everyone.
http://forums.ross-tech.com/showthread. ... Lock/page5
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW:
7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 343160625
Coding: A0FC793A0A61341193284F606CEB8FF4C084738960CD796032 04003F0860
Shop #: WSC 02737 534 1731640
VCID: 2A5CBFE34554CD119D-807E
5K7 955 559 C
Component: RLS 291116 04 42 0106
Coding:
0228EE
It could be a 'bug' on the labels of VCDS version being used.
Do you remember?
Posted: Thu Oct 12, 2017 4:03 am
by smg_shardul
ciclo wrote:smg_shardul wrote: Thu Oct 12, 2017 3:20 am
ciclo wrote:
3A904B
B848E1020001380791
7FCB96905A88676F60
8D3041200000030000
008F77
Impossible with
What is impossible?
What is the rest?
You lie.
Wiring for auto lights
Posted: Thu Oct 12, 2017 4:09 am
by ciclo
Really?...
In short, what we have already mentioned above.
I do not want to imagine the type of installation you have done.
When everything is installed post a new autoscan, to be able to correct any errors and provide you more links with information to activate more functions if it is your desire.
I look forward to the day of this Autoscan.
Posted: Thu Oct 12, 2017 4:18 am
by smg_shardul
Really?...
Got to know now you was asking me wire adaption for bcm which I thought that are only 2 wires
Got to know factory bcm and bcm max have different internal logics so until I install below wiring it won’t work..
Posted: Thu Oct 12, 2017 4:32 am
by firegrafik
ciclo wrote: Thu Oct 12, 2017 3:47 am
Do you remember?
Oh, you're right. I forgot it could be possible. I hadn't took into account, that guy uses the the old 12.12 VCDS.
Posted: Thu Oct 12, 2017 4:34 am
by benzinkopf
I think its not much of the bcm internal logics. The wiring is made by ciclo as a complete package. You will never get it right making the installation one by one and then want to power it up one by one. Its not how it works.
Posted: Thu Oct 12, 2017 5:17 am
by ciclo
It is a combination of wires and coding (logically).
Posted: Thu Oct 12, 2017 3:10 pm
by smg_shardul
For Fog light connection can I use old wires which are out of Bcm?
Two wires T73B/9, T73B/10 (earlier used as cornering lamps in fog lights) which are isolated after wiring of bixenon can I power them directly from 15amp fuse from fuse box ?
Or those wires are not capable to run it for long time ?
