Page 7 of 16
Re: Amarok Oem Bixenon retrofit
Posted: Sat Feb 24, 2018 7:11 pm
by georgenis
There is no rush. Thank You for Your kindness!
I assembled all back. I can drive the car.
I checked the wiring diagrams also for 8ih and everything seems ok.
Posted: Sat Feb 24, 2018 7:21 pm
by ciclo
Based on the posted autoscan:
Try this new BCM coding, and tell me the results.
640000380C21000000280CC12C4B84D4B000654E60021040300000020000
It may be necessary to make more attempts.
Please, post the autoscan with the changes made, ...for example, if you have installed the SCLs, post the autoscan with the changes in BCM coding before I have to ask for it. Thanks
Posted: Sun Feb 25, 2018 7:25 am
by ciclo
What is the reference number of your light switch?
Posted: Sun Feb 25, 2018 8:36 am
by georgenis
6Q0941531N
I tried the coding and still not working. Here is my new coding with SLC.
640000380C21000000280CC17C4B84D42D80654E60861041300000020000
Posted: Sun Feb 25, 2018 9:12 am
by georgenis
Auto scan with Your new coding.
Sunday,25,February,2018,11:11:19:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WV1ZZZ2HZDA007105 License Plate: NEWCODING
Chassis Type: 2H (7E0)
Scan: 01 03 08 09 10 15 17 19 22 25 32 37 56 69
22-AWD -- Status: OK 0000
32-Differential Locks -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CNEA) Labels: 03L-906-022-CFC.clb
Part No SW: 03L 906 012 AD HW: 03L 907 309 AC
Component: R4 2,0L EDC H21 2710
Revision: 74H21--- Serial number: 00000000000000
Coding: 01594012232600080001
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_ECM20BTD01103L906012AD 001002
ROD: EV_ECM20BTD01103L906012AD.rod
VCID: 66C9AED899990C2E0EF-8033
2 Faults Found:
4481 - Cruise Control Switch (E45)
P0568 00 [036] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 57345 km
Date: 2062.14.27
Time: 19:59:18
4482 - Function Restriction due to Implausible Message(s)
U1112 00 [039] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 57345 km
Date: 2062.14.27
Time: 20:28:09
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 2H0-907-379.clb
Part No SW: 2H0 907 379 L HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0110
Revision: 00H44001
Coding: B07324B691940D9C24A389A36F5590
Shop #: WSC 07456 790 49164
VCID: 397335A4B0A753D693D-806C
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 2H0 907 047 E HW: 2H0 907 047 E
Component: Climatic-T5 H20 0505
Revision: 00001008
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 2A511AE84D01E84EEA7-807F
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 089 HW: 7E0 937 089
Component: BCM PQ25 MMI4 H80 0736
Revision: BB080001 Serial number: 0772 205170114
Coding: 640000380C21000000280CC12C4B84D4B000654E60021040300000020000
Shop #: WSC 18752 008 00032
VCID: F0E54880235D529EE43-80A5
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3321
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3321
Coding: 100000
Subsystem 3 - Part No SW: 2H0 959 442 HW: 2H0 959 442
Component: E221__MFL-DC1 H01 0103
Coding: A4FFFF
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231432400057
Coding: 110003
Shop #: WSC 12345 123 12345
ROD: EV_VW75XParkAssis8K.rod
VCID: 3B7F2FACB29B61C6811-806E
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00B H07 0013
Revision: -------- Serial number: 003HN0089MTP
Coding: 000000000000000000000000000000003042
Shop #: WSC 07446 790 50316
ROD: EV_AirbaVW10BPAVN750_VN35.rod
VCID: 336F078C9ACBA986591-8066
Crash sensor for side airbag; driver side:
Serial number: 3495RRB40691138A20JK
Crash sensor for side airbag; passenger side:
Serial number: 3505RRB405J134DQFHQ$
Crash sensor for front airbag; driver side:
Serial number: 3555YRB40084UHPKEHU1
Crash sensor for front airbag; passenger side:
Serial number: 3565YRB40064UHPKPPUJ
Part No SW: 2H0 920 861 C HW: 2H0 920 861 C
Component: KOMBI H05 0605
Coding: 170200
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 2757E3DC5E13D526F59-8072
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 089
Revision: BB080001
Coding: 002000
VCID: E8D520E01B8D9A5EBC3-80BD
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 C HW: 2H0 927 755 C
Component: SG offroad VTG 0155
Revision: 00H07000 Serial number: T1IYC136215TSM
Coding: 0000013
Shop #: WSC 131071 1023 2097151
VCID: 30650880A3DD929E243-8065
Component: IMMO H05 0605
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EAD15AE80D81A84EAA7-80BF
Address 32: Differential Locks (J647) Labels: 2H0-927-771.clb
Part No SW: 2H0 927 771 A HW: 2H0 927 771
Component: Quersperre H04 0017
Revision: 11001001 Serial number: 4DG 16.05.12 00
Coding: 000001
ASAM Dataset: EV_QuersUDSAAMVN817 A01606
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2C5D1CF047F5F67E18B-8079
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 N HW: 3C0 035 279 N
Component: RNS315-EU H52 0319
Serial number: VWZAZ2M5927569
Coding: 000002110200150000031001
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 2E5916F871E9846E36F-807B
Data medium:
Subsystem 1 - Part No: 3AA 919 866 A
Component: EUR_E_V8 0069
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030189325
Coding: 0100000100000000
VCID: 3065088063DD929E243-8065
End ---------------------------------------------------------------------
Posted: Sun Feb 25, 2018 12:41 pm
by ciclo
georgenis wrote: Sun Feb 25, 2018 8:36 am
6Q0941531N
It is likely that the problem with your DRLs is the light switch (I already know that you have 12v in pin3, but ...)
Now I cannt do the relevant verifications, tomorrow I'll tell you something about it.
SCLs coding it's right.
... hard obsession with activating Byte23 Bit0 ...
7E0 BCM don't need this coding with your electrical installation (without automatic lights).
What you do with this coding is to activate pin 1b for 58 signal and pin 1a to activate 56b signal automaticaly. (yes, 56b low beam, not 56a high beam)
You already have the 58 signal in pin 4b (and other pins), and since you don't have automatic lights the 56b signal management (low beam) is according to your wishes (manualy
) and the subsequent management by the BCM through the 2a and 2b pins.
Therefore, it is not necessary to activate Byte23 Bit0.
Without this coding (Byte23 Bit0 unmarked) 1a and 1b are used for high beam, but with a very different electrical installation. Like those of the VW T6, last Amarok model and other recent PQ25 models with a high level of equipment.
Posted: Sun Feb 25, 2018 12:56 pm
by ciclo
georgenis wrote: Sun Feb 25, 2018 9:12 am
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 57345 km
Date: 2062.14.27
Time: 19:59:18
U1112 00 [039] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 57345 km
Date: 2062.14.27
Time: 20:28:09
Revision: 00H44001
Revision: 00001008
Coding: 0000000002
Coding: 100000
Coding: A4FFFF
Coding: 110003
Coding: 170200
Revision: BB080001
Coding: 002000
Coding: 0000013
Serial number:
Coding: 000001
Data medium:
Perfect, we have already tested the two possible codings for Bixenon headlights in Amarok. (codings with 7H0 or with 7E0 BCMs).
Both have been accepted.
Increase the chances that the problem is the light switch.
Have you installed the CCS or are you testing?
Posted: Sun Feb 25, 2018 2:55 pm
by iichel
ciclo wrote: Sun Feb 25, 2018 12:41 pm
Well, my thinking was, parking lights work so clearly the PWM signal for T14/12 is working and power supply T14/10 is working too.
So somehow, I thought, DRL was not coded or incorrectly coded. Therefore my thoughts about byte 23 bit 0 and bits 3-4.
Thaks for clarifying!
Posted: Sun Feb 25, 2018 3:08 pm
by georgenis
The CCS is installed but it is not coded in that coding.
I don’t have the necessary voltage on headlight pin 10.
Posted: Sun Feb 25, 2018 4:54 pm
by georgenis
I think the problem is with the modified headight switch T17/16 wire versus the T10/10 wire.
Something with the terminal 58d.
Posted: Sun Feb 25, 2018 6:44 pm
by georgenis
I think T17/17 wire must be joined with ex. T17/16 wire (the one to bcm T73b/4 which is removed from my light switch).
Posted: Sun Feb 25, 2018 6:46 pm
by ciclo
georgenis wrote: Sun Feb 25, 2018 4:54 pm
As I told you, this is the only and correct way for the T17/16. This is indisputable.
viewtopic.php?f=56&t=70902&start=60#p530843
Your original installation is an
extremely economical way to connect all 58 signals (except taillights)... all joined via a single wire of the light switch, T17/16, and this is useless in case of: (any of these conditions)
1- Dimmer.
2- Bixenon led modules for parking/side lights and DRLs.
3- Led license plate lights.
4- Auto lights
etc...
Some can work with your original electrical installation "doing tricks in the coding", after all, the 12v power is there, but they aren't managed by the BCM, ...
but other necessarily need a BCM control and it is necessary to differentiate these signals individually...
Posted: Sun Feb 25, 2018 6:47 pm
by ciclo
georgenis wrote: Sun Feb 25, 2018 6:44 pm
T17/17 is already attached to T17/16.
its only function is to illuminate the light switch. (like other interior switches of your Amarok)
Posted: Sun Feb 25, 2018 6:54 pm
by ciclo
iichel wrote: Sun Feb 25, 2018 2:55 pm
- There is no T14 here.
- bits 3-4 not related to this problem.
Posted: Sun Feb 25, 2018 7:09 pm
by georgenis
Yes, I have checked my wiring and You are right.
