some errors after upgrading 1S0937087D bcm to 1S0937090F
Re: some errors after upgrading 1S0937087D bcm to 1S0937090F
Okay, I'm going to do your new BCM coding, hopefully no errors come up due to the license plate lights.
Please wait a while. Thank you.
H2Deetoo
Drives: VW UP/Passat B6
Post by H2Deetoo »
Fresh auto scan:
Friday,20,November,2020,16:00:17:00008
VCDS Version: 18.9.1.0
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WVWZZZAAZED094213   License Plate:
Mileage: 111560km-69320mi   Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 02 03 09 10 15 17 19 25 44 56 AD
VIN: WVWZZZAAZED094213   Mileage: 111560km-69320miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 AN    HW: 04C 907 309 N
   Component: R3 1.0l MPI   H23 9104
   Revision: UOH23---
   Coding: 00140012022400000000
   Shop #: WSC 00900 211 00000
   ASAM Dataset: EV_ECM10MPI01104C906020AN 001008
   ROD: EV_ECM10MPI01104C906020AM.rod
   VCID: 67DD0D9C9E6DDC727C-8032
Readiness: 1110 0001
Address 02: Auto Trans (J514)       Labels:| User\0C8-927-750.clb
   Part No SW: 0CT 927 750 A    HW: 0CT 927 750 A
   Component: SQ100         H10 0013
   Coding: 010120
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMSQ101011 004010
   ROD: EV_TCMSQ101011_004.rod
   VCID: 4683E018F9A7E57AA7-8012
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 E    HW: 1S0 614 517 E
   Component: EBC 460 ESP   H08 0012
   Serial number: A00IP1V
   Coding: 12BF24718BB602F548FC24F6D1AC404059B200
   ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
   ROD: EV_Brake1ESPMP1TRWVW120.rod
   VCID: 3169A3C4602952C262-8064
Address 09: Cent. Elect. (J519)       Labels:. User\1S0-937-090-F.lbl
   Part No SW: 1S0 937 090 F    HW: 1S0 937 090
   Component: BCM PQ25 1MX4 H81 0744
   Revision: BW081001    Serial number: 0978 215160666
   Coding: 7AB82B0000010000090806446DEBBCC870C040F0608A2440200000400100
   VCID: 366390D8814775FA37-8062
   Subsystem 1 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS 090608 04  46  0204
   Coding: 033025
   Subsystem 2 - Part No SW: 6R0 959 591 B    HW: 6R0 959 591 B
   Component: J245 PS72.023  H02 0007
   Serial number:     WOO26347321
   Coding: 181100
   Subsystem 3 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29170001883980077353
   Coding: A4FFFF
Address 10: Park/Steer Assist (J446)       Labels:| User\1Sx-919-475.lbl
   Part No SW: 1S0 919 475 B    HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0013
   Revision: --------    Serial number: 32931725102029
   Coding: 100101
   ASAM Dataset: EV_EPHVA14VW1200000 001009
   ROD: EV_EPHVA14VW1200000.rod
   VCID: 39799BE4B8599A82DA-806C
   Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
   Component: VW10Airbag00N H03 0006
   Revision: --------    Serial number: 003MY006R7KX
   Coding: 00000000000000000000000000000000304E
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750_VW12.rod
   VCID: 3D718FF4AC71A6A2F6-8068
   Serial number: 3495RRB400M50S02MPQ5
   Serial number: 3505RRB400850SKCG8FM
   Serial number: 3555NRB401A50RN8EQ2R
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 870     HW: 1S0 920 870
   Component: KOMBI         H05 0010
   Revision: X0005001    Serial number: 00000000000000
   Coding: 1148010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05808
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 6ED378B8B1970D3A3F-803A
Address 19: CAN Gateway (J533)       Labels:. User\6N0-909-901-6R.clb
   Part No SW: 1S0 909 901     HW: 1S0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: BW081001
   Coding: 001200
   VCID: 70EF66C0A3A31BCA2D-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 870
   Component: IMMO          H05 0010
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6ADB74A88D7FE11A63-803E
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 R    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  311 3111
   Serial number: CE240147
   Coding: 0007
   Shop #: WSC 31104 001 1048576
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   Part No SW: 1S0 035 156 A    HW: 1S0 035 156 A
   Component: Radio         567 5543
   Revision: AA001001    Serial number: VWZ8Z1P0142252
   Coding: 0000040802
   VCID: 29594BA440F92A02AA-807C
1 Fault Found:
00871 - Bass Speaker Front Right (R23)
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
   Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
   Component: CV-SENSOR     H06 0460
   ASAM Dataset: EV_CVSen 001001
   ROD: EV_CVSen.rod
   VCID: 285F4EA053F3130AB5-807C
End-------------------------(Elapsed Time: 02:39)--------------------------
Best regards,
H2Deetoo
Thanks, I'll build on it for the new BCM coding.
H2Deetoo
Post by H2Deetoo »
If the current license plate installation will result in some error I will put a new wire directly to T73b/7 to sort it :)
OK.
Test this new BCM coding:
7AB82B0000010000090806D46CEBBEC870C060F0608E2441200000420100
Please report the result, don't forget to also check the reverse gear.
If there are faults in the scan for any of the lights, please tell me the type of bulb installed for that light. Thanks.
H2Deetoo
Post by H2Deetoo »
I tried the new coding and the situation remains the same: No interior lights, no permanent high beam (stalk forward).
Also no faults (even after driving for a minute):
                Address 09: Cent. Elect.       Labels: User\1S0-937-090-F.lbl
Control Module Part Number: 1S0 937 090 F    HW: 1S0 937 090
  Component and/or Version: BCM PQ25 1MX4 H81 0744
           Software Coding: 7AB82B0000010000090806D46CEBBEC870C040F0608E2441200000400100
            Work Shop Code: WSC 31414 790 00001
Reverse gear is (and was) OK.
Some small additional notes about your coding:
- I have an automatic gear
- I don't want to use rain sensor at this time
Rgs H2Deetoo
Ok, thanks for the clarifications, you can later select what best suits your needs or taste.
Well, some part of the wiring is not properly installed, we will have to investigate the causes.
I have to check the diagrams for your UP, I haven't seen these diagrams in a long time, it will take me some time to ask you some questions about the electrical installation you have done.
Note: In the previous autoscan that you posted you had the diagnostics of some lights disabled, I don't know the reasons or if it was that way from the factory. I never enable the lamp diagnostics that are previously disabled.
Wait a minute,
.... double check that you copied and pasted the new BCM coding correctly.
Because the one you show here is not correct. :arrow: viewtopic.php?p=577622#p577622
I hope you are not getting help from someone else and you are not following my guidelines.
You have to do exactly what I tell you, otherwise my help has ended right now.
H2Deetoo
Post by H2Deetoo »
I am sorry I made a mistake in copying, my apologies.
But I need to change 1 bit because I have an automatic gear and not a manual gear, so byte 27 needs to be 40h and not 42h.
After writing the correct coding you specified (byte 18 to 60h instead of 40h which I forgot) the main beam *is* working! Great :)
And still no errors in bcm:
Friday,20,November,2020,18:15:36:00008
VCDS Version: Release 18.9.1 Running on Windows 7 x86
www.Ross-Tech.com
           Software Coding: 7AB82B0000010000090806D46CEBBEC870C060F0608E2441200000400100
                      VCID: 366390D8914775FA37-8062
Only the interior lights are not working yet.
Regards,
H2Deetoo
H2Deetoo wrote: Fri Nov 20, 2020 5:16 pm
But I need to change 1 bit because I have an automatic gear and not a manual gear, so byte 27h needs to be 40h and not 42h.
Regards,
H2Deetoo
Enable Bit1 of Byte 27 and check your interior lights.
Please understand that there are many people waiting for my help. Thank you.
H2Deetoo
Post by H2Deetoo »
Ciclo, your help is greatly appreciated, ever since the beginning of this project!
I did set bit 1 of byte 27 now and interiour lights *are* working now !
And no fault codes in bcm:
Friday,20,November,2020,18:48:54:00008
www.Ross-Tech.com
           Software Coding: 7AB82B0000010000090806D46CEBBEC870C060F0608E2441200000420100
So the description for this bit is defined wrong in the VCDS label file it seems :-/
Or you have some other explanation?
Muchas gracias!
H2Deetoo
Post by H2Deetoo »
Thanks for the links. I will review them and update my label file if apropriate.
Thanks again for your time and effort!
H2Deetoo
Perhaps slightly offtopic, but massive respect for this work on your VW Up!.
I did a cruise control retrofit on one today and I'm always yelling and cursing at the BCM connectors. Especially the bastard white one since it's always in places my fingers cannot reach.
It's hard to imagine removing terminals and doing a BCM max retrofit.
Share your secret, pretty please :mrgreen:
