I have done the installation today. Everything works fine except auto lights. Are there any coding changes to be done?
Polo 6R 1.2 GT Tsi RHD
sshakthi123
- Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Re: Polo 6R 1.2 GT Tsi RHD
I’m overwhelmed with the gifts
Thank you so much Ciclo!
The day is looking up by the minute, we just finished the electrical installation of my wiring looms for Auto lights - BCM Max successfully for another user and now we are going to do the same for you.
Yes, a new BCM coding is required, please send me a recent/fresh Autoscan to my email. Thanks!
sshakthi123
Here is the latest scan,
Sunday,08,December,2024,17:12:49:00006
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXL15600GT052162 License Plate: GT-AUTO-LIGHT
Mileage: 67830km-42147mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 5F 65
VIN: MEXL15600GT052162 Mileage: 67830km-42147miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6DD17FB6BC91F82CC3-8038
Readiness: 0110 0101
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6561
Revision: 00043014 Serial number: CU501505175568
Coding: 0000024
Shop #: WSC 30641 005 1048576
VCID: 3A7B84EA755F9F9416-806E
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0003
Serial number: --------------
Coding: 62DD2463422803C24615246F4253C0800909
VCID: 000F36029B03054418-8054
Serial number: 10051504650266
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF348FAE1F773B46A-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 4189F306D889CC4C57-8014
Part No SW: 7E0 937 089 D HW: 7E0 937 089 D
Component: BCM PQ25 MMI4 H84 0772
Revision: BB084001 Serial number: 2602 180190154
Coding: 3AB02BFF48A10000213806207CEB9E9090C0606F60CD19D0210400030020
Shop #: WSC 00046 123 12345
VCID: 3467AAD2973B69E4CC-8060
Component: RLHS 200618 0 50 0107
Coding: 0714DD
Subsystem 2 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU031031440906027
Coding: 1400B3
Subsystem 3 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU013011440132978
Coding: 0400B3
Subsystem 4 - Part No SW: 5TA 959 442 HW: 5TA 959 442
Serial number: 1131818514601282AJ1B
Coding: 250000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5550
Serial number: 13202580150909024344
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13102581150901174201
Coding: 020000
2 Faults Found:
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Time Indication: 0
Date: 2024.12.08
Time: 17:06:58
01499 - Bulb for High-Beams; Right (M32)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Time Indication: 0
Date: 2024.12.08
Time: 17:06:58
Address 10: Park/Steer Assist (J446) Labels:. 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39391606504499
Coding: 0001151011
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: N/A
VCID: 377D9DDE8E4D82FCE9-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0115JH8
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4999EB26E8B9040C8F-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140801
Shop #: WSC 00078 790 12345
VCID: 479DED1EFEADF27C99-8012
Part No SW: 7E0 909 901 HW: 7E0 937 089 D
Revision: BB084001
Coding: 002307
VCID: 68DF0EA29B73DD04B0-803C
Component: IMMO H05 0805
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74AA8D7FEF14A6-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 4189F306D089CC4C57-8014
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 D HW: 5K7 035 200 D
Component: MU-S--ER H20 0240
Serial number: VWZAZ2R8806143
Coding: 02630100BE0000001111000101182A001F0100D60020010003
Shop #: WSC 00066 790 00056
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 2541479624E1006C4B-8070
1 Fault Found:
U1101 00 [009] - Active
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Date: 2024.12.08
Time: 17:06:56
Voltage terminal 30: 13.1 V
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000256160
ROD: EV_RDKBERU30_005.rod
End-------------------------(Elapsed Time: 02:58)--------------------------
New BCM coding (provisional):
Waiting for the results.
I haven't touched on the diagnosis of the lamps and their activation via PWM because I assume you have installed LED headlights and coded them accordingly.
I even think you are already an expert in these matters.
As I have already mentioned, we will be waiting for the results to study them and correct whatever is necessary.
Please, don't be in a hurry, now I'm going out with friends to see how Piastri or Norris win in F1, although I would also like a good surprise.
I won't be back until late afternoon (my afternoon), or even later, my friends are tireless.
sshakthi123
Here is the latest,
results:;
1. high beam not working but pass light working
2. auto lights are not working
yes I have upgraded to led lights with the last codings by you.
results:;
Sunday,08,December,2024,18:02:10:00006
www.Ross-Tech.com
VIN: MEXL15600GT052162 License Plate: GT-AUTO-LIGHT-2
Coding: 0000024
Coding: 01
Revision: V0000000
Coding: 0714DD
Coding: 1400B3
Coding: 0400B3
Coding: 250000
Coding: 020000
Coding: 020000
4 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 15
Reset counter: 210
Mileage: 67831 km
Time Indication: 0
Date: 2024.12.08
Time: 17:58:57
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Fault Frequency: 14
Reset counter: 170
Mileage: 67831 km
Time Indication: 0
Date: 2024.12.08
Time: 17:58:39
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Time Indication: 0
Date: 2024.12.08
Time: 17:58:55
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Time Indication: 0
Date: 2024.12.08
Time: 17:58:55
Coding: 0001151011
ROD: N/A
1 Fault Found:
12718592 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Date: 2024.12.08
Time: 17:58:25
Coding: 003036
Coding: 140801
Revision: BB084001
Coding: 002307
Serial number:
1 Fault Found:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Date: 2024.12.08
Time: 17:58:25
Voltage terminal 30: 12.3 V
End-------------------------(Elapsed Time: 03:01)--------------------------
3AB02BFF48A10000213806207CEB9E9090C0606F60CD19D1210400030020
sshakthi123
new results;
1. high beam - works
2. auto lights - not working
www.Ross-Tech.com
Coding: 0000024
Coding: 01
Revision: V0000000
Coding: 3AB02BFF48A10000213806207CEB9E9090C0606F60CD19D1210400030020
Coding: 0714DD
Coding: 1400B3
Coding: 0400B3
Coding: 250000
Coding: 020000
Coding: 020000
2 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Time Indication: 0
Date: 2024.12.08
Time: 17:06:58
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Time Indication: 0
Date: 2024.12.08
Time: 17:06:58
Coding: 0001151011
ROD: N/A
Coding: 003036
Coding: 140801
Revision: BB084001
Coding: 002307
Serial number:
1 Fault Found:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Date: 2024.12.08
Time: 17:06:56
Sunday,08,December,2024,18:30:28:00006
www.Ross-Tech.com
Coding: 0000024
Coding: 01
Revision: V0000000
Coding: 0714DD
Coding: 1400B3
Coding: 0400B3
Coding: 250000
Coding: 020000
Coding: 020000
Coding: 0001151011
ROD: N/A
1 Fault Found:
- 00 [008]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Date: 2024.12.08
Time: 17:58:25
Coding: 003036
Coding: 140801
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 2
Reset counter: 210
Mileage: 67831 km
Date: 2024.12.08
Time: 18:05:08
Revision: BB084001
Coding: 002307
Serial number:
1 Fault Found:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 170
Mileage: 67831 km
Date: 2024.12.08
Time: 17:58:25
End-------------------------(Elapsed Time: 03:11)--------------------------
3AB02BFF48A10000213806207CEB9E9090C0606F60CD39D1210400030020
sshakthi123
At a glance auto lights worked. I couldn’t check all the functions as I were rushing to leave somewhere on my sedan.
So I had to park 15/20 days at least to check again.
Thanks for the very quick support.
Finally both my cars equipped almost equal
(I waited so long for BCM max). Now only BSD and helix sub woofer are pending in my GT
Sunday,08,December,2024,20:11:53:00006
www.Ross-Tech.com
VIN: MEXL15600GT052162 License Plate: GT-AUTO-HL
Mileage: 67850km-42160mi Repair Order:
VIN: MEXL15600GT052162 Mileage: 67850km-42160miles
Coding: 0000024
Coding: 01
Revision: V0000000
Coding: 3AB02BFF48A10000213806207CEB9E9090C0606F60CD39D1210400030020
Coding: 0714DD
Coding: 1400B3
Coding: 0400B3
Coding: 250000
Coding: 020000
Coding: 020000
Coding: 0001151011
ROD: N/A
1 Fault Found:
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 170
Mileage: 67854 km
Date: 2024.12.08
Time: 20:08:42
Coding: 003036
Coding: 140801
Revision: BB084001
Coding: 002307
Serial number:
1 Fault Found:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 170
Mileage: 67854 km
Date: 2024.12.08
Time: 20:08:42
Voltage terminal 30: 12.2 V
sshakthi123
Have funciclo wrote: Sun Dec 08, 2024 12:17 pm Please, don't be in a hurry, now I'm going out with friends to see how Piastri or Norris win in F1, although I would also like a good surprise.
I won't be back until late afternoon (my afternoon), or even later, my friends are tireless.![]()
Great! Thank you very much for the reports and for making my work easier!
Without a doubt you have done a great job with the installation of the wiring, and in addition to enjoying the results you can feel very proud of it.
If any type of incident arises at any time, due to new checks or with daily use, you already know that we will solve it through the forum or by email.
Highly recommended BSD
, and whatever else arises...
🏎 ... f1 forever ... 🏎
Exciting projects for next season.
A beautiful and emotional end to the season, even in the last race you can see the DNA of the champions regardless of the place they fight for.sshakthi123 wrote: Sun Dec 08, 2024 4:46 pmHave funciclo wrote: Sun Dec 08, 2024 12:17 pm Please, don't be in a hurry, now I'm going out with friends to see how Piastri or Norris win in F1, although I would also like a good surprise.
sshakthi123
Sure thing, it is a first time I prepared the BCM max adaption wiring myself and I really felt great about it.ciclo wrote: Sun Dec 08, 2024 7:01 pm Great! Thank you very much for the reports and for making my work easier!
And this complete wiring installation I had done myself.
But the thing is I had to pause sometime to enjoy the results
Awaiting for the right moment to dig through this but definitely in the way you had in your 6R. The BSD blinkers in the mirrors I really liked it and will wanted to update my Vento BSD lights as well. Please help sharing the required part numbers (links) where I can source them. Also wanted to wire for heated mirrors.
One more thing is about HBA. Can you point me the articles and the wirings. I will study them and come to an understanding.
Unfortunately we do not or have very limited options to see the races here. But I definitely give a try in future when my work and personal times allow it.ciclo wrote: Sun Dec 08, 2024 7:01 pm A beautiful and emotional end to the season, even in the last race you can see the DNA of the champions regardless of the place they fight for.
Thank you master!
The Ali store for BSD mirrors no longer has the item for sale.
... fortunately I bought enough BSD mirrors as spare parts for the supposedly long life of my 6R.
They are on sale again, this is Ali's shop.
https://www.aliexpress.com/store/588370 ... eP9DeP9Dky
HBA is explained in my 6R thread.
Danedmunds
- Drives: 2015
Can anyone help with long coding on abs???
WVWZZZ6RZFY275793 My chassis number
