iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Re: iichels VW Passat 2.0 TSI DSG 4-Motion 2017
K dataset with K firmware unfortunately does the same :mrgreen:
I'm looking forward to the telematics retrofit, it's a nice thing to have, adds a lot of safety, at least for my feeling. I hope it works!
Short term plans are to install the Mk8 EA888 gen4 PCV --> https://www.golfmk7.com/forums/index.ph ... mo.429130/
Swap coolant from G13 Evo to G12 --> viewtopic.php?p=586061#p586061 + viewtopic.php?p=598477#p598477
Mk8 PCV done (06Q103495B + 06K103210D). I made my own boost tap with a simple hose barb and 10mm fuel line. Works perfectly.
Could also work on a 6C GTI and related cars. AW GTI probably already has a similar system.
Lots of info on the subject
https://www.datadrivenmqb.com/drivetrain (really recommended)
Upgraded the G13 coolant "Mit Silikat" (factory fill, maintenance free) for G12 Evo. G12 Evo is the successor for G13, even though the name suggests differently.
G13 had the nasty habit of clogging heater matrix cores over time, mostly on TDI engines. I also got rod of the old expansion tank as it had the Silicate teabag, that is known to rupture in some cases. Clogging up the coolant system as well. New bottle: 5Q0121407AA
It's an easy job, but hopefully with great pleasure.
Interesting reads:
TSB 2025303
https://www.audirs3.de/threads/g12evo-k ... ost-341094
https://imgur.com/a/szkFD4W
A pleasant surprise to see the GW update easily from AA to AG to AR (could have done AR in one go but i had AG dataset, in case I messed up)
No dataset needed, all codings, adaptations and history maintained.
Remember, original FW 5xxx = continental, FW 4xxx is Lear. Lear will to to AG.
DCC slider is still present, no need to re-set battery etc.
Interesting. It appears that the 'DCC slider' (functions) is an additional data set within the GW data set.
I have the impression that since I updated the GW to AR on our Golf7.5 MQB everything 'flows' better, even when new updates are made to other units and all these modification processes with diagnostic tools. I don't know how to explain it clearly, but although with SWs prior to AR everything worked well, on some occasions some intermittent fault would appear that made no sense 🤷‍♂️, which would disappear later with a new ignition cycle or by erasing it with the diagnostic tool.
There are new updates for the GW (Passat, Arteon, ...) but for now I'm sticking with the GW AR and BCM EC combination, I really like how everything 'flows' (no sporadic or intermittent faults/dtcs without sense).
some more SW updates:
from
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------    Dataset Number: V03935248QY 0001
   Coding: 14C002
   Shop #: WSC 05311 115 00065
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
   ROD: EV_RearRadarS1BoschVW48X_VW37.rod
   VCID: 3A2DCFA94CDD7C1A01F-806F
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
   ROD: EV_RearRadarS2BoschVW48X_VW37.rod
   VCID: 372BD69D7FCF6172FE1-8063
to
   Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0610
   Coding: 14C002
   VCID: 3B23CAAD43E745121A9-806E
   Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   VCID: 3829D5A172D16E0AF7B-806C
a bit pointless, but now we know it works without dataset. F is the latest flash container I could find.
H is also found on i.e. 2019 passat (SW 0539 :!: mine is 0610) --> https://forums.ross-tech.com/index.php?threads/33796/
FW K L M is Audi only
I'll be installing 2Q0 lane assist soon so I won't enjoy the F firmware that much anyway :mrgreen:
and from
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 K    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5072
   Dataset Number: V03935256EB 0001
   Coding: 9307
   Shop #: WSC 00015 115 00319
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
to
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5082
   Coding: 93070000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C21C9B146E9422A133-8068
does need dataset + G85 initialization
see more here: viewtopic.php?p=597542#p597542
but I got some more zero's for coding :mrgreen: . Dataset number didn't change, funny.
and from
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31344982200000 Dataset Number: V03935327XF 0001
   Coding: 02A8
   Shop #: WSC 30389 123 56831
   ASAM Dataset: EV_DeckLidCONTIAU736 001014
   ROD: EV_DeckLidCONTIAU736_VW37.rod
   VCID: 42DDB749240D34DA59F-8017
to
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0265
   Coding: 02A8
no dataset needed, still chasing easy close with mirror fold and kick to close
and last but not least...
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1302
   Serial number: E80320003220200 Dataset Number: V03935368RP 0001
   Coding: 0004019821FEC024889F14001020004000438000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: 3537DC9565C39362ECD-8060
to
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1421
needs a dataset but SWAP + calibration are maintained
upcoming mods:
- 42, 52, BB and BC modules upgrade from 5Q0 HW: E + SW: E to 5Q0 HW: F and SW: K/L
- BCM 084EC
- 2Q0 side assist
- Kessy module to N/Q SW
- I'm unsure if the 084E BCM will work with the 5Q0 slip ring, so Patil inspired me about 5Q1 slip rings. I'll give that a try too.
impulse purchase :oops:
https://imgur.com/a/3ocY33i
patil
Post by patil »
Intersting 5Q1 BCM, HW44/SW 512 I don't expect lot of changes from 5Q0 937084EC ( HW44/ SW 511), but good to have latest one. There is already SW update for 084EC BCM ( 511 :arrow: 1513)
I hope the new BCM might fix your side mirrors not folding with easy close, though primarily I believe your kessy module needs update to fix the issue. May be your stock kessy module SW is not configured from factory to fold mirrors with easy close, the communication protocol between 6D unit and BCM vary with different HW/SW versions of Kessy unit.
I've already started drafting my electric tailgate retrofit details. Hopefully I will post soon.☺️
patil
Post by patil »
iichel wrote: Thu Nov 16, 2023 2:29 pm
iichel, you will need
1. BCM HW 038 or higher
2. Kessy module SW " N" or higher
3. 6D module with SW "Q/T" with correctly modified dataset
4. Kick sensor control module " C " or higher
With above criteria fulfilled, everything should work perfectly. 👍
patil wrote: Sun Nov 19, 2023 1:48 pm Intersting 5Q1 BCM, HW44/SW 512 I don't expect lot of changes from 5Q0 937084EC ( HW44/ SW 511), but good to have latest one.
Sometimes there are disconcerting things in the ETKA, the BCM 5Q0 EC (SW 511) supposedly replaces all those mentioned on the right of the dialogue, including the 5Q1 B (SW 512). It is advisable to be cautious with experiments, that is, do a deep investigation comparing both SWs.🤷‍♂️
Ali: (price comparison)
- 5Q1937084B
https://es.aliexpress.com/i/1005005407109468.html
- 5Q0937084EC
https://es.aliexpress.com/item/4001034124074.html
iichel wrote: Thu Nov 16, 2023 2:29 pm some more SW updates:
from
   Coding: 14C002
   Revision: --------
   Coding: 14C002
to
   Coding: 14C002
   Revision: --------
   Coding: 14C002
I reverted back to E, since I had errors about both L +R LED indicators in the mirrors and lane assist stopped working completely.
Seems like F is Audi only: https://vag-flashinfo.de/site/index?partno=3Q0907590 / https://vag-flashinfo.de/site/index?partno=3Q0907566
G is latest 3Q0 SW, after that it was all 2Q0 radar
2019 3Q0 G: https://forums.ross-tech.com/index.php?threads/31538/
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 61907000000236
   Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
   VCID: 79AF10A5095BB702485-802C
to FM 0755
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 5Q0 614 517 FM    HW: 5Q0 614 517 AH
   Component: ESC           H62 0755
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 015F7845618BEFC2005-8054
After flashing it was necessary to restore coding. Basic settings not needed.
Compatibility chart by Medusa852: https://docs.google.com/spreadsheets/d/ ... edit#gid=0
It looks like my passat is in the 07xx FW series, so 0755 is currently highest. DB 08xx seems to be for GTE, but I'm not 100% sure.
raduss
Drives: Passat b8
Post by raduss »
Hey, do you want to run kick to close?
yes!
raduss
Drives: Passat b8
Post by raduss »
I did at my place, send me a scan of the ODIS car to my email and I will help you.
https://photos.app.goo.gl/e1hivJ343WvQnMu89
