Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
I'm actually considering transplanting the entire center piece of a Golf 7 console. This way I have some space for cups, phone, etc. Storage space is a Polo 6R is seriously lacking.
New style R-Line logo
I want to big turbo swap another polo. Interested into doing it the way you did it- removing the plenum and dog bone mount.
What I'm wondering is how did you unbolt and bolt back the lower two nuts that hold the manifold ( Cylinder 1 and Cylinder 2)?
I saw you removed the oil feed and drain, so you could remove the EGR- to unbolt these two nuts. But when you went to Install the turbo, you already put feed and drain lines on it. How did you manage to bolt the manifold down (because you put egr first, then turbo) ? Is there enough room to slide in the long extension when the engine is tilted? ( room issues because dpf is in the way) ...
I think I was able to remove all the bolts without removing the EGR cooler unit including 1st and 2nd cylinder. Undo the DPF first before tilting the engine and remove the plenum so you have more space.
thank you, I will try it. :D
EPB bench testing with 3Q0 calipers and 5G0 handbrake switch.
RobertVW
Drives: T6
Post by RobertVW »
:D
311mm or 272mm discs?
I'll be using a setup with 310mmx22 rear discs from the VW Phaeton with porsche calipers. this is just for handbrake.
Is it overkill? Yep! Do I care? Nope!
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
I like your test bench :D
ag69 wrote: Fri Nov 18, 2022 9:43 am I like your test bench :D
It's very small and simple but it's been very useful
viewtopic.php?p=584758#p584758
434C kessy module (PQ35GP + VIP SG)
3AA062234 module
It should in theory support kick-to-open for the boot and 4-door kessy
https://www.drive2.ru/l/592913295619400916/
rear doors: connect the touch handle to T32/6 (left) and T32/7 (right)
easy entry: T32/1 LIN, T32/2 +30 to J938
Parts for "easy open" antenna + control module J938
extra module: 3AA962243D
antennas: 3AA962253
bracket: 3c8962283
connector: 4H0973704C
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 H    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1305
   Revision: 00093000    Serial number: 0410221359
   Coding: 132C0C
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 3A38FEBFBDF31292C7-806E
   Slave 1:
   Subsystem 1 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Component: GEB.F.Heckoef  H16 0811
   Serial number: 93845109
my setup:
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   Shop #: WSC 31889 047 31889
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 372BD69D7FCF6173169-8062
byte 0: 03 --> 13
byte 1: 0C --> 2C
byte 2: 0C == 0C
And coding for rear doors :?:
byte 0 bit 2 + 3?
byte 1 bit 2 + 3 off?
byte 2 bit 2 + 3 off?
byte 0: 03 --> 13 --> 0F?
byte 1: 0C --> 2C --> 20?
byte 2: 0C --> 00?
So 0F2000?
Replacing kessy module --> https://www.youtube.com/watch?v=KHdyu8KlHeQ
And the other winter project: 2Q0 SWA/BSD radars as upgrade from my 7E0 C radars. The alternative is 5Q0 BSD radars but it is said the 2Q0 is a bit more accurate.
7E0 radars --> viewtopic.php?p=540564#p540564
The goal is to add RTA for my PDC in the Discover Media PQ, otherwise the 7E0 radars work perfectly.
More images: https://imgur.com/a/Owc1paY
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
Cool ichel
I have bought the radars and tried to connect it, on my desk I succeeded to access them, but when changing to pq35 it tells me “out of range”
And when connecting to my car I couldn’t access it at all
Yep I had the same regarding pq35. On the T6 forum i read some positive outcomes for retrofits to pq platform.
