Scotty_boy vw
Today I added the new Style front & rear Badges to my polo.
Scott
Scott
- 0A574EA6-FA9F-4A26-BDE5-D074242A284A.jpeg (2.8 MiB) Viewed 46530 times
- FCCA7D10-77FA-4B39-9BEF-D4BD94084FFE.jpeg (217.53 KiB) Viewed 46530 times
- 7C5BD7BA-FA22-41D7-BB64-54B8A35E8AB1.png (4.46 MiB) Viewed 46530 times
- A0165544-8D93-4F4F-9F54-B67CCF5FEC0B.jpeg (203.14 KiB) Viewed 46530 times
Scott, Will you be changing the centre caps on your alloys and the emblem on the steering wheel centre boss to the new style too?Scotty_boy vw wrote: Fri Feb 05, 2021 10:48 pm Today I added the new Style front & rear Badges to my polo.
Scott
Scotty_boy vw
Yes i will be if they are available to buy but the airbag would be a lot to buy just to replace the emblem so not too sure about that!!!SRGTD wrote: Sat Feb 06, 2021 8:07 amScott, Will you be changing the centre caps on your alloys and the emblem on the steering wheel centre boss to the new style too?Scotty_boy vw wrote: Fri Feb 05, 2021 10:48 pm Today I added the new Style front & rear Badges to my polo.
Scott
scott
Dark_cze
- Drives: AW GTI with MT
I'm not 100% sure but plastic cover around airbag could be separate partScotty_boy vw wrote: Sat Feb 06, 2021 10:39 amYes i will be if they are available to buy but the airbag would be a lot to buy just to replace the emblem so not too sure about that!!!SRGTD wrote: Sat Feb 06, 2021 8:07 amScott, Will you be changing the centre caps on your alloys and the emblem on the steering wheel centre boss to the new style too?Scotty_boy vw wrote: Fri Feb 05, 2021 10:48 pm Today I added the new Style front & rear Badges to my polo.
Scott
scott
There are some of the new style centre caps for sale on various websites - part number 5H0601171FOD; inner diameter 55mm, outer diameter 65mm. Couldn’t see any on UK based seller’s websites, and buying them from an EU seller if they ship to the UK would probably make them expensive after post-Brexit import duty / import taxes have been applied.Scotty_boy vw wrote: Sat Feb 06, 2021 10:39 amYes i will be if they are available to buy but the airbag would be a lot to buy just to replace the emblem so not too sure about that!!!SRGTD wrote: Sat Feb 06, 2021 8:07 amScott, Will you be changing the centre caps on your alloys and the emblem on the steering wheel centre boss to the new style too?Scotty_boy vw wrote: Fri Feb 05, 2021 10:48 pm Today I added the new Style front & rear Badges to my polo.
Scott
scott
I installed a plug and play android/ CarPlay Ai box today. If your not familiar with this type of device here’s a link to a review by MR-fix on YouTube to give you a better understanding of what I’m talking about.
https://youtu.be/XzcF6wKH-wM
Overall I’m happy with the box, it’s definitely exceeded my expectations regarding responsiveness, sound and picture quality are relatively good for a basic car screen to.
Also it’s not a good idea to watch boxsets/ videos or movies while driving before anyone mentions it, You could get points and a fine if you’re caught doing so or even worse kill someone while being distracted and be sent to prison.
Today I installed a under seat storage box it’s originally from a Audi a1 or seat Arona & possibly other cars. after a bit of digging around I came to realise the metal structures/skeleton under the seats on these cars are the same but the foam cushions are different. The box is Probably not as big as I’d like but it’s better then nothing. Overall I’m happy to have extra storage to keep things out of site.
Images below are from car wows review of the seat arona.
Part numbers:
Storage box : 81A8826024PK
Speed nut : N90088003 (x2 pcs)
Oval Hexagon Socket Head Bolt : N90737101 (x2 pcs)
I have spare nuts(8) and bolts(8) as it worked out cheaper to buy as a pack of 10 so if anyone is interested in doing this retrofit pm me I’ll send them out for free as I have no use for them. (Uk only)
Part numbers:
Andy Beats
Mine has been sitting in the drive for days now.
I've got all-seasons fitted, but it was still difficult to get going up the road the last time I tried (better than it would have been on summers though, obviously).
Then the sheer depth of snow made it impossible for me to use anything other than the wife's Evoque.
Which I have to say that considering it's just the 2x4 model, is astonishing in snow.
MichaelWood
Picked her up today after a make over,went for something different..
- IMG_20210212_173101_354.jpg (131.68 KiB) Viewed 46223 times
MichaelWood wrote: Fri Feb 12, 2021 5:35 pm Picked her up today after a make over,went for something different..![]()
I like it, It looks like a street version of the r5 gti polo now, full rally spec
- B9A89BAE-56E6-4B05-A419-A27B537025B5.png (6.14 MiB) Viewed 46164 times
Hey Scotty.. Could you share the link to buy these new badges..? I would like to do the same on my poloScotty_boy vw wrote: Fri Feb 05, 2021 10:48 pm Today I added the new Style front & rear Badges to my polo.
Scott
Iamnotbarry
- Drives: GTi+ (aw)
Fitted a racingline turbo inlet hose today, also tried fitting a racingline turbo muffler delete but couldn't get it to fit correctly. For some reason the 3 holes wouldn't line up correctly!
Tried rotating the turbo muffler around to try different positions but none would work. I can get 2 screws on and the last one doesn't line up, it's roughly 2mm off.
Has anyone fitted a racingline turbo muffler delete before?
I'd like to change my rear diffuser to the R-Line style like this as I currently just have the standard one that comes with the match spec. Where would I be able to buy one?
Scotty_boy vw wrote: Thu Dec 20, 2018 10:44 pm Today I changed my rear diffuser to this one.
Also added Heated Windscreen Washer Jets.5AA1FE47-2020-4310-8B94-E9F31EA3E112.jpeg
And also added Rear LED Footwell Lights.
Scott
RichTea
- Drives: Polo blue GT - 170BHP - 320nm
Mine went in straight away but some people have had problems as well. Its an easy fix, just drill the holes out an extra 2mm so you have more playIamnotbarry wrote: Wed Feb 17, 2021 4:49 pm Fitted a racingline turbo inlet hose today, also tried fitting a racingline turbo muffler delete but couldn't get it to fit correctly. For some reason the 3 holes wouldn't line up correctly!
Iamnotbarry
- Drives: GTi+ (aw)
Aye mate, that's what I'm going to do over the weekend. CheersRichTea wrote: Thu Feb 18, 2021 10:29 amMine went in straight away but some people have had problems as well. Its an easy fix, just drill the holes out an extra 2mm so you have more playIamnotbarry wrote: Wed Feb 17, 2021 4:49 pm Fitted a racingline turbo inlet hose today, also tried fitting a racingline turbo muffler delete but couldn't get it to fit correctly. For some reason the 3 holes wouldn't line up correctly!
