Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Don't worry, please proceed hijacking, it's for good use.
mortys
Drives: 2013 Polo GT
Post by mortys »
First post on this forum, so bare with me..
We just purchased a 2013 Polo GT and I really miss the auto setting on light switch. Stopped by a junk yard today an got a light switch from a 6C, but notice the symbols does not line up correctly....not compatible with my OCD at all :lol:
How did you sort that in you Polo?
My OCD was satisfied by swapping the entire dashboard.
But I'll spare you the disappointment you'll have, the 6C light switch is not electrically compatible with the 6R. So better get the Golf Mk6 light switch 3C0/3C8...
I made a hybrid with the 6C housing and the 3C internals.
gourtz
Drives: Polo 6c 1.4tdi dsg
Post by gourtz »
hello. do you have better photos from the footrest? and from the gear knob?
No not right now. The footrest is very well described in the ciclo topic. Did you look there?
gourtz
Post by gourtz »
i will check. thank you
gourtz
Post by gourtz »
benmet
Drives: Polo 6R 105PS TDI
Post by benmet »
Hi til3tsio,
Thank you for your effort, everything went well. The speedometer works perfectly and I no longer have an error message. Thank you iichels for your help and that we could use your blog. :D
til3tsio wrote: Mon Jan 23, 2023 11:19 am Ok , no problem !
It's a pleasure to help others.
I reuploaded the file with a small fix to your fuel curves and fuel warning indicator so make sure to download it again.
Also you have to transfer your adaptation map from the old one so the service intervals and other settings are true on the new one .
* Sorry iichel, we highjacked your thread :D
Well done guys. Well done!
Shane_in_oz
Drives: 2016 Scirocco R - 2015 Polo GTi
Post by Shane_in_oz »
Hi
wow all the mods you have done are amazing...I was curious to know can a digital dash cluster be fitted to a 6C GTI? I have seen them on aliexpress for MK6 MK7 CC but not a Polo
cheers
Shane
I doubt it... but ask yourself... should you fit an aliexpress cluster to an otherwise nice car?
MIH11MI6
Drives: 6J FR 2.0TFSI CDLJ AWD
Post by MIH11MI6 »
iichel wrote: Mon Oct 31, 2022 12:04 pm DONE AND DUSTED! The PQ35 DCC has been installed and wit works flawlessly.
It can be activated by OEM button or via the CCE by mr Slavik.
The key was to code byte 2 bit 3 in the CAN gateway to enable "Charisma" function.
Hi iichel,
On the sport suspension button, does it also stiffen up the steering?
I'm now retrofitting the electric power steering (same as yours) into my 6J ibiza and would love to have the adjustable steering stiffness.
Is the sport suspension button the way to go? and if so do you have any rough ideas as to whats needed for just the steering as I don't need the DCC
Thanks!
Yes, the steering feedback is also changed. You can't have the DCC module without the dampers, the system won't work.
MIH11MI6
Post by MIH11MI6 »
iichel wrote: Mon May 15, 2023 2:41 pm Yes, the steering feedback is also changed. You can't have the DCC module without the dampers, the system won't work.
Thanks iichel,
I thought as much, sounding as though there isn't a way to stiffen the steering feedback without the DCC module then?
You can set the steering feedback 'programme' via VCDS. On the fly adjustment is not as easy.
