Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Slavik kindly updated by BCM software to 090E and updated the CCE software so I can use the R button on my Golf 8 MFSW
   Part No SW: 7E0 937 090 E    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0772
   Revision: B9082001    Serial number: 4000 173171327
   Coding: 3EB82BBFA8EB3400B33807E0FFCB9FF0E68067EFE08D78D031E400030800
   Shop #: WSC 30389 123 56831
   VCID: 2D07F4F58D13DBA37C5-8078
   Component: RLHS 220816 0  42  0106
   Coding: 0214DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027011200011418
   Coding: 58BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
--- DCC wiring continued.
--> front half of the car/sensors viewtopic.php?p=593608#p593608
This is the orientation of G343, horizontal, upside down, plug facing forward, near the rear left wheel.
The Polo 6R does not have a suitable place for mounting it. So I made it myself..
With sensor installed:
I made the largest hugest wiring loom ever I think.
The door sill is completely filled with wire. Retrofits will from now on have all their wires routed on the passenger side :mrgreen:
Tomorrow I'll connect the wires to the DCC ECU in the boot
Wire							T47/
Left front shock absorber T2/1 red			39
Left front shock absorber T2/2 black			40
Left front Accelerometer T3/1 red/blue			22
Left front Accelerometer T3/2 green/blue		7
Left front Accelerometer T3/3 white/blue		6
Left front Ride height sensor T4/1 red			27
Left front Ride height sensor T4/2 green		26
Left front Ride height sensor T4/3 white		11
Right front shock absorber T2/1 black/grey		41
Right front shock absorber T2/2 black			42
Right front Accelerometer T3/1 black			25
Right front Accelerometer T3/2 yellow			10
Right front Accelerometer T3/3 green			9
Right front Ride height sensor T4/1 red			30
Right front Ride height sensor T4/2 white		29
Right front Ride height sensor T4/3 blue		14
Button
Signal (T6/5) black					5
Comfort LED white/grey					36
Sport LED (T6/2)	 white				38
Module GND (T6/1, T6/4) black/grey			21
ACC sensor left rear
1 	red black (marker)				19
2 	white black (marker)				4
3 	blue black (marker)				20
Ride height sensor left rear
1	green black (marker)				24
2	yellow black (marker)				23
3	black black (marker)				8
patil
Post by patil »
iichel wrote: Sat Oct 08, 2022 7:52 pm
Kindly correct my spatial disorientation.. where is this space.. left side boot arch?
I would like to name your DCC retrofit as.. Dutch Car Conundrum.😂
By the way, with your help.. I successfully accomplished my last retrofit on my little 6R.. thank you so much🙏 details coming soon in my thread.
Yes you are looking at the left rear seat belt tensioner on the far right.
--> parts for DCC --> viewtopic.php?p=589020#p589020
--> installing front sensors --> viewtopic.php?p=593064#p593064
--> wiring of the front ride height sensors and brake warning contacts --> viewtopic.php?p=593594#p593594
--> rear acceleration sensor viewtopic.php?p=593634#p593634
The rear ride height sensor for Polo 6R is installed on the left rear on the OEM bracket:
--> viewtopic.php?p=509258#p509258
The PQ35 3C0 sensor is oriented differently and it has the 'arm' on the other side, thus the rotation of direction is inverted.
The Polo 6R has the 1T0 sensor arm pointing towards the center of the car while the 3C0 sensor arm must be mounted facing the wheel.
So this means that I have to get creative...
Mounting the 3C0 sensor on the bracket intended for the 1T0 sensor ends up like this:
That ain't good... Extending the arm will lead to a high amount of torque and deflection due to play and elasticity of the materials and bearings.
So I mounted the sensor on the 'outside' of the arm and extended the head a bit:
All in place:
Completed the wiring as well to the module:
Basic settings must be performed with the feet up in the air:
All done for now. Battery is charging.
Full image gallery: https://imgur.com/a/B50eNJk
jp-125
Drives: Polo 6R 1.4
Post by jp-125 »
Hi, how do you get 6 favorites on Phone menu in your Discover Media?
jp-125 wrote: Mon Oct 10, 2022 1:44 pm Hi, how do you get 6 favorites on Phone menu in your Discover Media?
I honestly don't know, it was already there by default. I'm running an MQB skin for my DM, perhaps it comes from there?
til3tsio
Drives: Seat Toledo KG
Post by til3tsio »
Well done , your work is always inspiring and well documented !
*I noticed that your bcm is flashed with 772 firmware, is this file available or you got it that way ?
I went to slavik / MaDwArLoCk. He did the flashing for me
6R0071360 - Chrome list for rear lid. In blue for our special friend CNK.
Fire extinguisher + holder --> 000016997 + 000016995
Band aid kit + strap --> 5K0860282 + 6R6860265
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
cool.
your manual seats had storage drawers?
Yes indeed they did, it's an option for the 6R seats (18-22), i.e. for the left front seat:
DONE AND DUSTED! The PQ35 DCC has been installed and wit works flawlessly.
It can be activated by OEM button or via the CCE by mr Slavik.
The key was to code byte 2 bit 3 in the CAN gateway to enable "Charisma" function.
Monday,31,October,2022,12:51:27:11868
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN:   License Plate:
  Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 05 08 09 10 14 15 17 19 20 25 2B 36 37 3C 44 47
          55 5F 61 65 69 77 B9
VIN:   Mileage:-
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
47-Sound System -- Status: OK 0000
69-Trailer -- Status: OK 0000
B9-Aux. Display -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels: None
   Part No SW: 03L 906 023 KE    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9978
   Revision: --H43---    Serial number: 00000000000000 CVN: 3BB1FB41
   Coding: 00254036032401080000
   Shop #: WSC 00066 000 00237
   ASAM Dataset: EV_ECM16TDI02103L906023KE 003009
   ROD: GV_ECM16TDI021VW32X.rod
   VCID: 73B3228D2B37CD53EA1-8026
   VINID: 9E69EAAAA1A2A92A42085185103550A70A
Readiness: 0 0 0 0 0
Address 02: Auto Trans
Cannot be reached
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Coding: 21DD2885412500C5841A146E825500521504
   Shop #: WSC 31889 047 31889
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F7B4E7D27DF89B36E9-805A
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 372BD69D7FCF6173169-8062
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E0B1F3-806C
   Coding: 3EB82BBFA8EB3400B33807E0FFCB9FF0AF8066EFE08D78D031E400030820
   Coding: 0214DD
   Coding: 0200A3
   Coding: 1000AB
   Coding: 58BC32
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391528804191
   Coding: 0011195151
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          [Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 179
                    Date: 2022.10.31
                    Time: 12:44:07
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 31080904160002
   Coding: 000180
   VCID: 270B06DDAFEFF1F3869-8072
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4ACD9F691C3DEC9B797-801E
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140F01
   VCID: 3333E28D6BB78D532A1-8066
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0772
   Revision: B9082001
   Coding: 00220F
   VCID: 688945E162713E8B4F3-803C
   Revision: AA001001
   Coding: 0404000000000000010000
   Shop #: WSC 12345 123 12345
   VCID: 2E05F3F98095A0BB45F-807A
   Component: IMMO          H04 0709
   Coding: 000007
   VCID: 6A8D3FE97CFD0C9B597-803E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4900000000000000
   Shop #: WSC 31889 470 31889
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F3BEEFD879FA9B34E9-807A
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 B    HW: 3C8 959 760 B
   Component: Sitzmemory    H02 1001
   Revision: 00H02000
   Coding: 000039
   Shop #: WSC 40022 666 40022
   VCID: 3431E1916E398A6B33B-8060
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02756 790 00000
   VCID: 2F3BEEFD8B1FA9B34E9-807A
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
   Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AD    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3124
   Serial number: CF3F0205
   Coding: 001F00
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_014.rod
   VCID: 79AF10A5095BB703A0D-802C
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 280905E1A271FE8B8F3-807C
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D42000001000000
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2DCFA94CDD7C1BE97-806E
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2W1425226
   Coding: 02620001AA00000011111103C00D0A201F0100D401200100CE
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 25170CD5D563E3E3B45-8070
   Data carrier:
   Subsystem 1 - Part No SW: V03 825 254 AD    HW: -----------
   Component: ECE DL2 22/23  --- 1810
2 Faults Found:
15360256 - Component Protection
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6100)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 179
                    Date: 2022.10.31
                    Time: 12:44:07
                    Voltage terminal 30: 10.9 V
0003 - Antenna 2 for radio
          B111A 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 179
                    Date: 2022.10.31
                    Time: 12:44:08
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0772
   Coding: 03037A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
   Serial number: 40000000058319
   ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revision: 3A001001    Serial number: 00008200133984
   Coding: 4100000101000000
   VCID: 3039ED819A21B64B573-8064
Address 77: Telephone
Cannot be reached
Address B9: Aux. Display (J285)       Labels:* 5C5-919-527.clb
   Part No SW: 1K8 919 527     HW: 1K8 919 527
   Component: ZUSATZANZEIGE H08 0003
   Coding: 05
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
   ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
   VCID: 75B71C952543D363C45-8020
End----(Elapsed Time: 02:27, VBatt start/end: 11.6V/11.5V. VIgn 11.3V)-----
With OEM 6C DCC GTI springs:
Project overview:
1. I got an idea... viewtopic.php?p=589020#p589020
2. Location of the module: viewtopic.php?p=589367#p589367
3. Holes in front wishbones: viewtopic.php?p=593064#p593064
4. Installation of front ride height sensors: viewtopic.php?p=593594#p593594
5. Front damper and acc. meter wiring: viewtopic.php?p=593608#p593608
6. Rear acceleration sensor installation: viewtopic.php?p=593632#p593632
7. Rear ride height sensor installation: viewtopic.php?p=593647#p593647
Summary on the Ross Tech forum: https://forums.ross-tech.com/index.php? ... ost-291462
Inspired by, and explained in detail: https://www.t6forum.com/threads/epb-ret ... -go.23626/
ag69
Post by ag69 »
iichel, you have space for roughly 5+ switches available (once you get rid of hand brake lever)
so we are going to get some more and awesome mods. I cant even guess what they could be. Some XXX or James Bond stuff ;)
I think I have to start thinking of superlatives (in advance)
