Hiya,
I've got the VW OEM Sat nav headunit in my 2001 Polo, and i'm wondering what adpater it is that I need in order for me to get PS2/DVD hooked up through it?
Has anybody done it? Can you point me in the right direction of what I need to get hold of?
Tom
What adapter do I need to get PS2/DVD through my MFD HU
Just be careful what you are buying! If you want to watch a dvd while driving you may be best buying an actual car dvd player and not a PS2. The PS2 will jump if you go over bumps on the road as its no designed for that sort of thing where as the car dvd players have anti shock type systems. Also if you want to connect the TV up then you are looking at another couple of hundred quid. You would need the VW Tuner and at that you still wont be able to watch it on the move unless you cut through the Gala wire which will then allow you to watch the TV/DVD on the move but will not give you Nav!
Good Luck with it anyway.
Depends on what system you have at the moment if you are running a gamma head unit or you have wiring for it then you need to buy a wiring kit/loom for only about £30 I think, This plugs into the gamma wiring and give you all the connectors needed to plug the MFD in. So yeah its basicly a plug and play job. Not too hard. For you to get the nav to work though you will need the airel. You can buy the VW one and change the whole thing on the roof or either just hide one in the dash somewhere should still do the trick. Thought you had bought one jazzy had seen you on the nav forum a few weeks back. If you'v got any probs am sure the guys over ther will help out. Just be careful what you are doing/cutting its an expensive bit of equipment!
