Hi i have recently been having some head unit problems. I just blew a fuse so changed that and everything was working fine for a few hours then when i was driving my head unit turned off. The head unit turns on when the ignition is turned the first notch but the head unit turns off when the engine is turned on. I have pushed all the wires in further to check that its not a loose wire and nothing seems to change. I have also checked the fuses but all are fine. The head unit turns on sometimes when i am driving but sometimes turns off again and do not know what is wrong? any help would be good.
thanks
Head Unit Problems
I had the same problem, i think its the ignition chamber.
After you turn your car on try rocking your key and see if that turns your stereo on.(I found by rocking the key even a small amout the head unit would come on)
If that works chances are its the ignition. Just rewire your head unit to be on all the time that is what i did jobs a good un. Dont forget to take your head unit out though or you will drain the battery
