Help- anyone with a very low Polo!!!
Non-VW related chat - Moderated
italvisions
Post by italvisions »
Righty, had my coilies fitted today along with my turbos, but I have a problem. If i brake whilst turning on uneven ground, a knocking noise comes from the front of the car. I think it may be the driveshafts, but I'm hoping someone else who has an equally low car would be able to help me out! What's the problem and how do i fix it?!
{PS, hope you like the car! :wink:
Josh_PoloGTi
Drives: BMW E85 Z4 3.0i
Post by Josh_PoloGTi »
Looks great mate!
You want to talk to Speedlaw, he runs a 6n with RT's and Coilovers (LOW!).
8)
workinprogress
Post by workinprogress »
if there fk's then its probably the double springs moving on each other makes a bongy sort of sound
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
im liking your polo mate 8)
i can't say i suffer with this knocking noise, though i do get a strange sound if i turn the steering wheel too far, which is probably just rubbing.
-Ben-
jezmk4
Post by jezmk4 »
could be tyres on arch liners
might be driveshafts
oxogenic
Post by oxogenic »
right i have this problem too and i have ronals aswell
its the right hand drive shaft rubbing on something i think if u have a 16v or a 1.6 8v its the drive shaft on the chassic leg i was told but i have checked the shaft and it just makes it alittle shinny but nothing im not worried about just make sure u check your wheels and have had the
italvisions
Mines' a 1.4 8v, but is suppose it could still be that! The coilovers are fk highsports, and they're wound down fully to 85mm at the front, so could it be that they're hitting the bumpstops?
polo2k
Post by polo2k »
get the drivers side rear wishbone rubber checked. if its gone soft then post up in the vag forum and we can get you one
