Any input is much appreciated.
Cheers Robz
Torguey engine??? So does that hole 1 bhp make a difference? The SDI isnt the slowest polo across the range it is actually the 1.2 robzfollowd by a 1.2 12v engine giving 65bhp. torquey engine
Torquey i mean compared to the other petrols, the 1.2 12v 65bhp model has better acceleration than the 1.4 16v 75bhp, which has been said to be "lacking torque" because it peaks higher up the rev range, therefore making the 1.2 12v 65bhp model quicker off the mark to around 35mph.Polo-03 wrote:Aaron just to correct you the Polo SDI is acually 64 bhp that means it is ONE bhp slower than the 1.2 12v at 65bhp.
Just to qouteTorguey engine??? So does that hole 1 bhp make a difference? The SDI isnt the slowest polo across the range it is actually the 1.2 robzfollowd by a 1.2 12v engine giving 65bhp. torquey engine
yip, fully agree with Toxxin here, the two surprises in the engine range, havent driven the 1.4 TDI but according to logistix on this forum, with careful chip, induction and performance exhaust, it is possible to get it to GT level, 130bhp from a 3 cyl!!!toXXin wrote:IMHO, there are 2 surprising engines in the range.
1) 1.2 12v. You'd think a 1.2 is going to be slower than a snail. Try one, you'll be very surprised at how torquey it actually is. Oh and it sounds like a Porsche
2) 1.4 TDI. Yes it's a diesel, but it's a cracking engine. Again, you'll be very surprised by this engine, and they chip/map up to 100bhp
if you don't like either, try the higher powered engines and see how you get on with them.
Oh and I hate to throw a spanner in the works, but what about the Ibiza? 02 plate 1.2 12vs can be picked up for £3500 now!!!
yea, i would like to see the torque curve tooAndrew B wrote:I have the 1.2 12v and wasn't expecting anything from it, thought it would pull like a go-kart, 1st test drive, and I was very pleasantly surprised, haven't seen a graph of engine curve, but there's a nice peak at 3,000. It does sound great once you get it above that, real throaty rasp, gear box is a bit noisy IMHO, going to add a BMC filter soon, (as soon as I can work out how to get at the bloody airbox) so hopefully slight increase in power and more noise.
