squealing noise from rear?
madmansi
Post by madmansi »
Hello all
Any ideas on the following;?
After a while from cold i'm getting an intermittent squealing noise from the rear (i think) which seems to have got worse. I'm guessing wheel bearings but should they start to play up after 32K?, if it is, is the rear assembly similar to a mk2 golf gti? (haynes manual on order).
Any suggestions appreciated, only had it a week!
Si :?
dubpolo
Sponsor
Post by dubpolo »
my rear wheel bearing went after 10 000 miles! they are a sealed unit! dead easy to fit
madmansi
Post by madmansi »
Where did you get the bearings from and how much?
Ss
bstardchild
Moderator
Post by bstardchild »
madmansi wrote:Where did you get the bearings from and how much?
Ss
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=10280
Might help a bit - OK it's slightly different if you have discs on the back but same principle applies
madmansi
Post by madmansi »
It seems to be the rear pads making the noise. I stripped the assembly down taking the pads off and cleaned any flakey paint rust/dust off, applied lots of copper grease and its quieter but still making a bit of a squeal when warmed up.
Anyone else had this at all?
Si.
