Does anyone know if those mobile speed camera van things flash if you are speeding coming towards them? I was meant to be doing 40 im not sure if i was doin 40, as it was just after a stretch of national speed limit rd.
cheers
yes true, but theyre fairly easy to spot, usually on grass verge of the road and with the rear doors WIDE openTDi-polo wrote:as said above they dont flash when you are coming towards them, lasers are the ones you need to watch out for.....maybe its worth investing in a road angel or something along that line.
Dave.
Wrong, they only need to put a speed camera sign up if they visit the same place more than twice in one month.They must have a speed camera sign on the road within (I think it's) a 1000 yards of the van anyway although I cant see how you would prove they didn't if you did get caught. But generally if you see a speed camera sign just be a bit cautious, sounds obvious I know.
Yeh they are easy to spot once you are within 100m or there abouts, if its a long stretch of road they have a range of 5000ft. They will get you before you have chance to slow down.yes true, but theyre fairly easy to spot, usually on grass verge of the road and with the rear doors WIDE open , but these read far away?
I guess Im kinda screwed then really, Im hoping they gave a distance to allow drivers to slow down after the 40 sign otherwise unless Im very lucky Ive probably got 3 points. Time will tellYeh they are easy to spot once you are within 100m or there abouts, if its a long stretch of road they have a range of 5000ft. They will get you before you have chance to slow down.
