Got a result from the Autopia people!!!!
If we can get 10 people in the GB, then we can get a 20% discount on the item, which in this case is the Sonus DAS.
When we have 10 people, we can apply a promotional discount code when you make your individual purchase though a web link. The discount is applied to the goods before the carriage is added on.
Roughly this works out as follows:
- DAS kit = £120 delivered
- DAS kit + 1 spare Green + 1 spare Blue pad = £131 delivered
- DAS kit + 2 spare Green + 2 spare Blue pad = £142 delivered
- Remember the exchange rate is about $1.90:£1 at the moment, so make use of it!
- It might be a good idea to get another green and blue foam pad, as these are the two that you will use most often
- Remember that this is a 110v system, so you WILL need a 110v transformer and an extension cable from Screwfix or a local electrical wholesaler
- I am going to post this on a couple of other forums as well, so we might not need 10 from here...
- The discount will be valid if product purchase is over $170 and includes at a minimum Sonus DAS Polisher Kit. Other products can be ordered with it
- Each persion will make their own individual order up and then apply the promotional code that I will supply
