[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Anyone got 17s? - UK-POLOS.NET - THE VW Polo Forum
Hi all,
Has anyone actually got 17s on their mk 5. Im after some at the moment and want to know how big a gap is left between tyre and arch on standard suspension, if any.
Cheers for any help you can give,
Peanut.
tricky one this... i own a Mk4 (which i think are mechanical the same)
I have a set of 17s and a set 18s (for shows), both wheels would fit easily on standard supension but the amount of travel would mean that the wheels would scrub over the slightest bump.
-40mm springs with koni adjustables are probably your best bet - mine cost £250 fitted and balanced - so there not as expensive as coilovers but give the right look and stop scrubbing.
