My left window works fine when you use the controls on the left door, but if i try and put the window down from the drivers side it does nothing. It goes up using the drivers side control but not down?
WTF?
Phill
Left window problems
hey hey, it could be a FUSE... sounds silly, but I accidently made a short once, when messing with the pins on the drivers control switch (made a lovely pop and burning smell hehe) and had the same problem.....
I was upset as you can imagine, esp. as was suggested by the vw parts man it could be the motor blown and this was like £100+, i was like no way... and so consulted the fuse key card... checked each window icon one and would you know it... found a blown one (30AMP WHITE)... replaced it and all was fine again. I had also messed up the locking from drivers side too, the fuse solved that too...
Might not be the same problem you are having... but worth checking? Hope helps
I been having a few problems with my passenger window too... meant to have one touch right?? the drivers side works, but passenger side doesnt..
also i get the problem that sometimes i cant control passenger window from double switch on drivers side??? that i have to lean over to use the passenger side button... *if that made any sense?* not essential to the running of the car.. but bloody annoying at times!
