tdi chipping
Posted: Thu May 12, 2005 2:35 pm
by 13twelve
how much does this cane economy?
would a mk5 tdi give a gti a run for its money once its rolling?
Posted: Thu May 12, 2005 2:47 pm
by carmadaaron
i presume u have a mk5, 1.4 TDI 75hp
chip from Revo will give ~100hp
, get a better zorst/air intake,
strip the car and ull b looking at a close comp IMO
Posted: Fri May 13, 2005 3:11 pm
by 13twelve
s'what i thought
i can only imagine the economy would suffer though
the gti would have the edge on acceleration from 0 and with top speed though
Posted: Fri May 13, 2005 11:07 pm
by Tahrey1043
from 0, surely it depends how vicious you are with slipping the clutch?
maybe you could have a switchable mode chip put in that would crank the idle speed up a bit to remove both the diesel and the turbo lag...
(done deliveries in a diesel van, went like the clappers once rolling, but was hellish to get moving because of the almost binary clutch.. you'd either bark the tyres something rotten and look like a right herbert, or get bogged down at 1200rpm going nowhere... oh if only it was more easily slippable)
the economy, hmmm ...... well the diesel-cycle heat engine
is at its most efficient under full load / full acceleration, so it might not be as bad as all that...
Posted: Sat May 14, 2005 1:33 pm
by Gareth_GT_Hatch
you just have to get used to the "throttle lag." My TDI was pretty quick off the line and even better once moving. I don't think that chipping a diesel causes a big difference in fuel consumption (it may even improve if the map is "better")
