Yesterday i decided as it was my day off, i'd take the front coilovers off my car and fit the standards back on. So i took a trip to Halfords to get some spring compressers and a couple of tools so i could do the job. Cost= £30.47
Get back home for 11am and pull my car into my small garage. Start to jack my car up and decide to it would be faster to do both side at same time so jack the other side up aswell. I took off both the alloys then set to work at taking off the coilies. BTW i put some axel stands next to the jacks just in case the car/jack slips. Once i've removed the drivers side i set to work at taking off the top mounts as i used my old ones. Things are going a little bit too well so its about time for the first miss-hap. As i'm compressing my standard spring, the compressers weren't exactly staying put. They kept twisting and slipping around the spring. After about 2 and a half hours, me and my bro have finally compressed the spring enough to add the top mount. Ok fitted back to the car, so now its time for a drink.
Next we take off the passengers side coilie which goes fine. Take off the top mount then set to work at compressing the spring. Yet again we have a pain in the ass of the spring compressers slipping. After about 6 attempts at trying to compress the spring, we decide that someone needs to hold the compressers. I volunteer which is a seriously bad idea. We realise that the compressers are in the wrong position so decide to loosen them off when suddenly they slip, and catch my thumb and squash it inbetween both the compressers. Ouch!
After about half an hour i've recovered enough to get back up off my bed. Decide to try and finish the job in the morning, which is done but by me using my feet with big shoes on to stop the compressers from slipping. I've now got an hour to fit these my old suspension back on and put my wheels back. With the suspension fitted i now need to jack the car up a little bit more so the alloy will go on. Time for the second mis-hap. As i start to jack the car up, it slips diagonally off of the jack This causes the drivers side side skirt to fall onto the axel stand and crumple it.
Anyway, all in all i trapped my thumb in the way of a coiled spring. (ouch my thumb hurts)
And also crumpled my side skirt when the car slipped off the jack. (ouch my wallet is gonna hurt)
Mat
