Hey all!
I am new here
Does anyone know if there is rear strut brace for my polo GTi (1600 modell 2000)
Thanks in advance !
strut brace
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
polo2k
i have
ultimate upper (huge improvement)
omp lower (not a big change but more stable under heavy braking)
kw variante 2`s (to stress them all a bit)
this is on an 01 1.4i 5 door
i havnt found a rear but i dont know if id fit one cos im am over steer lover
p.s. i think the wiechers is a 6 point mounting
polo2k
i was thinking home made too all you need is a huge "I" with the top and bottom bits being the mountings then the vertical being the brace
when you mount it fit it nice and high up otherwise the rotational force that is exerted upon the towers will overcome the strut brace and it will flex wher as at the top there is more distance that is moved but at a much lower force
No problem!
Offtopic: You can also test anything you like in the testing forum, or have a signature test here:
http://www.tigerstyle.co.uk/poloforum/v ... 9aa9b377a9
